Barbosa and Leal Devices - Info and Replication Details
  • Originally posted by vrand View Post
    Hi level,
    My test setup confirms what you and Luc are saying. Unless there is some new info, there is not much I can do. Spent over to $2k on this project, but it was alot of fun!
    Do you see anything out there that looks promising to getting free electricity simply?
    My continuing multi-decade project, splitting water ala Brown's gas/hydroxy gas, and then fueling a motor/genset to creating electricity. It is not simple like this B&L project was, taking only 2 months to build!
    Thanks for posting your honest results vrand.
    Sorry to hear it cost you $2,000. to find out it doesn't work and came to the same conclusion as I have recently come to and what level has been trying to communicate for over 2 years.
    Lucky for me it didn't cost me anything since I used what I already had on hand to confirm the measurement error.
    Often experimenters just walk away when they see the negative results. However, by posting your bad results will helps others and I decided to take the time to make video demos so others may re-think before spending thousands of dollars on something that's clear to fail.
    It's interesting to see attacks from some when all I'm doing is trying to help bring a better understanding.
    You would think that with the 10 years of me sharing free energy experiments and videos people would trust that I'm not just a naysayer and am truly a OU researcher, experimenter.
    I do this full time 40 hours a week with zero income in hopes to find something useful for our world. However, even after all this time I still haven't found something real or useful.
    I'm saying this to help answer your question if there's something else out there you can build that will give you positive results.
    All I can say is be careful!... my 10 years of testing most every claims out there have not yet provided any proof of OU let alone a device that works as claimed.
    99% of OU claims out there are measurement error, an oversight, lack of understanding or purposeful deception for monetary gain.
    That's why before testing any claims I look for a reliable a replication with good measurement data to back it up which in most cases you won't find it if you know what to look for.
    There may be a way to use ground to assist in a circuit but it's not the case as you have found here.
    Hope this helps you and others.
    Kind regards and thanks again for sharing your true test results.
    Luc
      Perfect example of another pack dog not following instructions. Notice
      how the focus on a few bucks but no mention or plea on how to fix
      his setup. He never intended to get it working since he can not show his
      array of grounding rods.
      He is calling us liars when it is him who has lied about his setup.
      It's like Hillary saying Trump is selling Uranium to the Russians when
      it was her all along.
      The rusty nail trick is easy to spot, you just follow the bouncing ball
      that always lands in his buddies court. Bad-mittens or dirty hands?
      This is the same ole tactic so people won't try.
      Hi Bromikey,
      Would like to see Clarence photos of his inverter/battery connection to his device. Maybe I missed it, did you see it? He showed his utility connected device.
      Replicated his utility connections and readings but not his inverter/battery setup, as unknown how he did it. Not calling anyone a liar.
        Luc
        Hi Luc,
        Thank you for your many years of videos, interviews, world travels, energy conferences, forums, (this forum!) for energy researchers to share their experiments to others, maybe someone will hit the Jackpot and share their results with others to replicate!
        THat is what was hoping for on this device, but lack of info on the inverter/battery connection, can not continue.
        Keep up the good work Luc!
          Hi Bromikey,
          But you say he is misleading folks. Yes you are. When you are thru
          with those inverters and watt meters just resell them and you won't
          be out any money. However if you want to complete this test
          the instructions call for starting with 10 or more rods and build
          up as needed. In other words as more rods were installed, more amps
          were available.
          You must show your grounding rods which is the hardest to accomplish.
          Without that you should buy some batteries and use them with your
          inverter and watt meter. Buy a solar panel also. The watt meter can also
          be used to check your draw.
          Do you have a parcel that can be devoted to an array of copper coated
          rods? The captor collects energy from the ground so you need some
          surface area to do that. And BTW all that whining people do about
          spending their chicken feed allowance on a few trinkets is hilarious.
          While some of these disinformation monkeys are moaning about price
          they are getting kick backs in the thousands weekly. Beware of who
          you chum with.
          Yes the grounding rods setup was shown way back when, people who
          are serious need to at least read thru the material. We have given you
          more than the B&L boys have so follow the instructions.
          The reference one gentlemen made to following the yellow brick road
          is a code message like "everything turning to gold" these people are
          sent and paid to disrupt.
            Hi Luc,
            Thanks vrand for your supportive post
            I've recently been interested and looking into ground related devices and why I've looked into this topic.
            I'll definitely post anything I find interesting or related to ground.
            Kind regards
            Luc
              were available.
              you chum with.
              more than the B&B boys have so follow the instructions.
              Hi Bromiky,
              Not even saying his is misleading. Not saying anything really, just asking for more info on his inverter/battery setup so can continue replication of this B&L device.
                Hi Bromiky,
                Fair enough I guess that quote was from ole smooth lips, not you.
                Originally posted by level View Post
                Unfortunately Clarence has been misleading people in this thread for 2 1/2 years
                • Hello vrand. Unfortunately I do not know of any type of free energy devices which hold a lot of promise and for which all of the replication details are known, and where one or more people have been able to independently replicate the over unity results. I think at least some devices out there do seem to hold some promise however. I do my own experimenting as well, but haven't tested with any setup I can say is definitely over unity so far. I spent a few years on Don Smith's stuff and various other types of setups since then as well, but no luck so far.
                  BroMikey does not know what he is talking about when he says having a lot of ground rods will make these B&L captor loop devices over unity. It will lower the overall ground rod array resistance to ground current, but I don't know of anyone who has ever demonstrated anything relating to these B&L captor loop setups and who has shown some proper measurements that indicate anything unusual happening. That is just a fair and honest assessment from what I have seen over the last couple of years or so. Unfortunately a few people here seem to think that if someone is honest about any particular setup that they must be 'suppression agents'. Of course that is silly. If someone wants any hope of ever finding real over unity, it is unlikely they can do so if they are unwilling to fairly and honestly look at and consider all the facts.
                  Anyway, as I have mentioned, I emailed B&L a couple of months ago and pointed out the major problem of testing the B&L 'captor loop' setups using the mains, and asked if their captor loop setups could produce over unity if powered with a battery and inverter to eliminate the mains ground loop problem. They answered "Not yet". They said they stopped working with those 'captor loop' setups back in Oct. 2013, but they are currently working on a new idea they have for a new type of over unity device. It seems pretty clear to me from what they replied to me that they no longer believe those 'captor loop' type devices are over unity. Otherwise I see no reason why they would have answered me with "not yet" in regards to whether their devices are over unity, and stopped working with the captor loop devices for several years already, and are now working on a new type of over unity device idea. If they were suppressed by their government or whatever, then they likely wouldn't have answered my emails, and wouldn't have told me they are now working on a new idea for a new type of over unity device.
                  level
                  • Hi level,
                    Thanks for the updated info on B&L THe battery/inverter connection is where B&L was stuck, can add me to the list!
                    • Hi Vrand
                      I live in a house with only solar energy thus I was forced from the begining to use inverter and no way. Perhaps there is some configuraation I dont know but... The easiestt way now is go solar , panels are cheaper than ever and some maglev windmill.
                      • Why trust non builders??
                        Vrand,
                        Those that have NOT built this setup and installed the ground grid can't know what they are talking about. All any of us including me has is just an opinion. Nobody here has installed 20 or more grounding rods in the ground to even have an idea if this B&L setup works or not. Only Clarence has installed 60 rods in the ground to power this device.
                        So I'll not tell my opinion here cause I've no proof. But I know Clarence has and only he can have a true opinion on this matter.
                        These others have just opinions and no basic tests or experiments that carry any value on this forum. If fact one of these big mouths harnesses other threads as well.
                        Be wise people. Listen to true builders that actually post pictures and show proof of builds. It's a waste of time and space to argue with non builders.
                        Opinions are like arm pits, everyone has two and they both stink !!!!!!
                        wantomake
                        PS: I built this setup but don't have finances for the 20+ rods. And posted pictures of all my builds.
                        • Hi
                          Hello all
                          now I have two toroidal transformers, very big transformers, they are 800 watts each one
                          I understood the copper rods have to be placed in a circle in the ground
                          let me know if it is right
                          and do you think that coper pipes could be used instead of the rods, because the rods are more expensive
                          please let me know thanks
                          • Originally posted by FRANKLIN View Post
                            Hello all
                            Like WANTOMAKE has pointed out, I have no build, but what I do have
                            is a working understanding of this setup as I am the one who drew up
                            the diagram. The rods are not pure copper and yes pipes will work but
                            are to pricey. Use IRON RODS COATED WITHE COPPER this has been
                            given and I now have repeated it. The iron rod coated in copper is
                            cheap.
                            Depending on mineral content the coating my be eaten away after 10
                            years or so, this has been mentioned, i am repeating this fact. Rods
                            need to be experimented with first, this has been stated.
                            Drive 2 rods in the ground at 3 foot apart then do the test at 2
                            foot apart to find the best collection spacing for your ground. This
                            is not hard and needs to be done by each individual. Start with
                            a few cheap-O rods and add latter using you launch money.
                            • and the charade continues...
                              level
                                cheap.
                                Hello, thanks for your answer.
                                I have a 800 watts toroidal transformer, but when I added the secundary turns, they started to be melt, due to the high temperature, I think due to the ampers.
                                I connected the secundary to the earth system but the problem continued
                                could you please tell me what I could do
                                thanks
