Could you tell me where to order one of those variable power resistors like you have? I keep thinking that I'm going to flip the power on one time too many and this light bulb is going to kick the bucket.
Thanks..................................Mike
with a 22uF cap instead, but it heated up enough to feel it just spinning it by hand. Spun at 4,200 rpm for 30 seconds w/22uF, cap was 155 deg. F, diodes were 97 deg. F, bulb (as resistor) was really bright. Could this be due to a real need for a variable resistor? I think I will go back to the 4.7uF bank and see exactly how hot it gets. The caps I got are rated for 5,000 hours at 105 deg. Celcius (221 Fahrenheit). Ordered the best ones I could find. Back in a few........................Mike
So the spark is a bit weaker than it will be when my ordered parts arrive. I will change to a 4.7uF as soon as they arrive via UPS, should be tomorrow. I am using a voltage doubler circuit with a pair of 120uF 330V flash caps, output is 326VDC. This test was performed at 5,800 RPM, decided to go ahead and step it up. I figure it will either GO or BLOW!
I am charging at 326V, no "storage" cap (I will add one later), 1.06uf MW cap for discharge (will change to four 4.7uf caps, 2 ea. wired series then paralleled together), and a 100 watt light bulb as the resistor (only thing I have on hand). One 12KV microwave diode per spark plug. I ran the test for a few minutes, way longer than my other tests, and there was NO detectable heat anywhere throughout the components!!
