Capacitors overheating
Hi Mike,
I was thinking about the capacitors heating issue and I had this idea, maybe it'll do a difference maybe not but I think it worth the try, at least we will know more about it.
I would introduce in the circuit an inductive load by connecting (as an example) a MOT primary in series with the dumping capacitor and measure any change in plasma intensity and capacitor temp.
BEWARE of the MOT secondary there will be presence of High Voltage pulses!
All the numbers you are sharing with us is your kind contribution to everyone for a better understanding of what really happen in the circuit. Thank you.
Gibs
Originally posted by jstadwater
Hi Mike,
Gibs
I accidentally left the MOT primary hooked up as my resistor (only 1.1ohms resistence), spun the distributor shaft by hand and dang near blew the ends off the spark plugs!!!
Works fine. I used a 75w light bulb as a resistor. At first I made a test with no vexus circuit attached, no booster side, just an ordinary spark. I made the test for longer time to get more accurate results. The ordinary spark circuit did consume all the fuel in 45m40S. Then I attached the vexus circuit with a voltage doubler. I also attached a microwave diode connecting the ignition coils LV positive to the HV output. And I attached a diode string in series with the ignition coil secondary to prevent the booster cap discharge through the secondary in between the pulses. This is the circuit that I used:
