Originally posted by Mr_M
I'm up for anything really. The inverter was chosen as an 'off the shelf' item because it was convenient to make medium to HVDC using the car's 12VDC.
For the original Gotoluc water spark plug circuit the voltage source (in this case the inverter) is isolated from the spark event because the HVDC source is isolated, it charges a capacitor, is isolated again and then the capacitor is discharged to the plasma circuit. I built a solid state version of this, installed it in my Bug and it worked flawlessly, no problems at all and I still have that complete system sitting on a desk ...actually on a chair.
There seems to be problems with the sensitive electronics in today's inverters that make it inconvenient to use them in the latest craze of piggybacking the plasma event on the standard spark which requires them to operate in real-time with the plasma event ... inconvenient meaning the inverters FRY!
All we need is a rugged 250 - 350 VDC source (pumped up from the car's 12 VDC system) and we're done. There is more to doing this than meets the eye because of the VDC source's interplay with the rest of the plasma circuit.
I seem to have partially overcome this by using a rather generic 2 - transistor (or even four transistor) inverter circuit as that voltage pump and it works and does not sag upon the demand from high speed ignition frequencies (voltage doesn't drop ...stays self regulated)
I'm open to everything though, and thanks for your input.
Peace,
Greg (VexUs's daddy)
The water is admitted to the cylinder to convert heat energy into pressure and it is pressure which drives the engine not heat---A good example is an air engine is has no heat persay. One problem I encountered was that the water mist could flash into steam when it hit the hot valves and cylinder-----before compression, in this case the rising piston must compress air and already expanded steam and the expanded steam lowers efficiency, we want all of the water to flash into steam near TDC. So yes the perfect system would inject water mist into the cylinder just before ignition to pre-expand the water into steam and cool the engine components. Next ignition occurs and whatever water remains will instantly flash to steam and cylinder pressure will rise. It's kind of funny that this system worked great and was relatively easy to build but there was "One" problem that kept popping up, that is at very lean mixtures I would have misfires and I was looking for a better way to ignite the fuel/air mixture----and you have solved this problem for me in this very thread. From the moment I read this thread I knew you guys had solved the single biggest problem I had with my constant temperature engine and when I replicated your circuit I knew as fact you had solved this problem.
I do believe this would be the correct direction we need to take.
it does not produce extreme pressures nor extreme heat and cannot hurt the engine--the forces have balanced, cylinder pressure with load.
