Water Sparkplug
  • GotGas
    Binary logigic -vs- analog thought
    Just found another old video and put it on youtube.
    Shows what appears to be an implosion effect from this plasma ignition.
    YouTube - Plasma Spark Implosion
    I believed for months that the sound is an implosive clap and not from the explosion.
    Aaron,
    Things are rarely one thing OR the other. Rather, they are usually one thing AND the other.
    There are two reactions taking place. One is a chemical reaction and the other is an atomic reaction. The loud bang is the sound of cavitation and what makes all free energy machines work.
    I wrote something to help AllCanadian that better explains the process starting here.
  • Aaron
    possible implosion video
  • ashtweth
    Okay now Jeff may be machining us some Ball tips i think these are going to do better, don't forget we experienced no more wear with Revizal's taking the caps down so some good news , will take a look at the end of the week and compare. So far Greg's finesse is looking like the answer
  • gotoluc
    Well we were trying not to be part of the fried inverter club or blow any thing up , but some times S happens
    Okay the report i got back from Andrew was he used the doubler with:
    100 watt light bulb in series on the AC side
    voltage doubler - 2 X 30uf 400 volts
    50 uf 800 volts storage cap
    There was a 3Kohm 30 watt resistor in series between the storage and dump cap
    5uf 800 volts dump cap they charge 600 volts
    240 volt inverter but was running at 60 hertz
    Dump cap exploded after 10 minutes driving And there was no significant difference in engine performance. The explosion of the dump caps may have been a result of an insufficient current surge rating on first stage of every discharge. May need an electric motor starter rated capacitor.Also Andrew has dropped down the cap values in Rev's circuit and states there has not been any ore wear then normal after week of driving, , i will take a closer look at the plugs at the end of the weeks guys.
    More to come.
    Thanks Ash for the Double Voltage Test update ... interesting a 800v cap blows up with a 600 volt charge... we are experiencing many unusual behaviors with these circuits
    Thanks for sharing.
    Luc
  • gotoluc
    Originally posted by jstadwater View Post
    Yes Luc,
    It is Naples Florida, and I would love to have you come down and visit ANYTIME! We could make a whole day of it, and kick around all sorts of plans and ideas. How cool it is that you are so close by! I will PM you.
    Thanks.........................Mike
    Thanks Mike for the invite. I will go by to see you and the great work you have done at some time next week.
    Luc
  • ashtweth
    More to come.
  • jstadwater
    Yes Luc,
  • gotoluc
    @ Luc
    Yes, I will try the skull mister with water, of course. But that video opens doors to more possible liquids to "fog", than just water. I don't think this will require a semi GEET to function, keep reading below.................
    @ ALL
    Does anyone here know the auto-ignition temp of gasoline? How about deisel fuel? What I'm thinking is the same principle of heating the water to make it easier to go to vapor, as Luc stated. Applications already exist that heat the gasoline before it gets to the engine. You follow me? Some of us already feed a "vaporous" gas into the intake, HHO, what would it hurt to feed in a little extra? Even if we need to use a LP carb instead of a gasoline carb, or throttle body, big deal if it works, right? They make adapter plates to change a mulitude of fuel injected and carbed vehicles over to LP (just modify it for low pressure). I know guys here in Naples that run their fleet trucks on LP as we speak, they are in the GREEN category.
    Still use the fuel tank in the car as the supply, feed the gasoline (or deisel fuel,) from the tank into a "created" unit to heat it to the right temp, making it easier to vaporize, but well below auto-ignition temp. Engine size would dictate the number of small sonic transducer units required to change the heated liquid to vapor, "on demand" (could be electronically controlled via throttle position). Still use the return line to the fuel tank (may need to be bigger diameter for all that excess liquid the engine won't be using ). It's not as simple to make as it is to write.......but I think it can be done for sure. Hence my signature at the bottom of my posts, it's also my motto, "IF IT DOESN'T EXIST, CREATE IT!".
    Then maybe use a heat exchanger from the exhaust system to create a steam feed, and a booster to add HHO..........and ignite it all with a plasma blast from the spark plug!!! VIOLA!!! And they call me a redneck......I'll show them! I share this idea with all of you, to kick around, give feedback, try to build one before I do, what do you think? Later.............................Mike
    Hi jstadwater,
    hey, I see you're located in Naples? is that Naples, Florida? if so I ain't too far from you since I'm in St. Petersburg, FL. for another week. Maybe I can drive down to see your setup?
    Good ideas you have there.
    Thanks for sharing
    Luc
  • Ansis Freimanis
    To Jetijs
    Thank, You for INFO.
    YouTube - Powerful x-rays made from sticky tape here is the video.
    I am not a nuclear physicist, and I don’t think to use Scotch like shirt...
  • jstadwater
  • jstadwater
    Hey Greg,
    I don't know about the actual voltage, but my spark does not seem to suffer any at higher rpm, at least visually on the bench. I'm still working on getting a transformer, I will have more data once I get your newest circuit built. Later.............................Mike
    My present config uses a voltage tripler circuit..........................
  • jstadwater
    @ Luc
    @ Luc
    @ ALL
  • gmeast
    voltage multiplier
    Hi all,
    Has anyone that is using a voltage multiplier on the spark plug circuit put the circuit on a scope to see if the multiplier maintains its high voltage at high spark rate? Every one I have built sags miserably at higher frequency (power demand).
    Greg
  • Jetijs
    Ansis, check this out:
    But lets not go into offtopic here
  • Ansis Freimanis
    to GotGas
    Do you think static electricity (body+ Scotch+ flour) can make X-Rays? I think- there is too small current and if I remember correct for X-Rays we need a electrons with high energy (AC) to hit an special metal material in 45 degree angle, for gamma rays. Alfa and Beta is soft X-rays. With Scotch and flour you can "take" a static electricity (it is like Capacitor) and nothing can happen- You’ll be OK.
    P.S. I think you worried too much.
