In my tests, the cap (22uf 250V, couldn't find a 12.5uf) made NO difference in anything, no matter which configuration it was wired in. I even changed the coil configuration to discharge - instead of +, still no good. Each time I flip on the inverter, the "continuous" spark at the plug just sits there going crazy. After about 5 seconds, the inverter starts to squeel so I flip it back off. I never even activated the discharge from the coil during this, since I instantly fried the inverter by discharging the coil into it yesterday. And does anyone know what kind of cap Mr. Bill is using in that video? That thing is huge. Is it a non-pollarized or something, or just really old? I didn't fry any inverters today, came close about 10 or 15 times though!
Maybe I need to wait for the 300 1N5408 diodes I ordered to come in before I go any further. If this circuit is to work, maybe it is completely dependant on those specific diodes, I don't know. To me, the schematic just does not make any sense. When I put in the diode to half rectify, in the direction on the schematic, the output from the diode is negative. I don't have a problem with that, reversed makes it measure positive. But the schematic shows to hook that lead to one side of the cap and the other side of the cap to 12V- negative of the battery cable. With both sides of the cap hooked to negative, how's that supposed to work? Also in that config, the main diodes are turned so that the HV+ discharge from the coil just barrells through there and the inverter seems to take a direct hit, pegged my meter each time I flipped it on anyways. If anyone is having any luck with this circuit, please let me know. I can't seem to make heads or tails out of it myself. I'm DONE for the day, I will try to post some pics of my mess on this table here in the morning. Maybe someone can see what my malfunction is. Till then, good day and good luck to all..............................Mike
hopefully if time permits, I will have the circuit assembled for testing this weekend.
