Bedini Solid State Oscillators
  • Aluminum Magnet Wire Air Core Experiment
    Just an update, first trial run on the 4T SS SSG, with a 5 filar Aluminum Magnet Wire coil, no core. In this build i added a "coil sniffer" wind to the standard Air Core transformer. It was wound on with 30 AWG, 21-22 turns, then taped, and the letz'd 5 filar on top. Worked out pretty close to plan (hopes). The filar ended up being about 148 turns, the wires were 100' in length, equal trigger gauge. Thanks for the help, 49'er, Blackchisel and all, all of your tips helped a lot, she fired up first try, this time.
    No big conlcusions on the aluminum wire, other than it works, it was cheap, and the savings more than paid for all of the other components of the build. As 49'er had pointed out (but unfortunately I had bought it already... might have been better to buy a bigger gauge, slightly.. say 16 or 14 AWG, to negate higher resistance factors). It's all an experiment!
    SSG Aluminum Air Core Experiment PT. 3 - YouTube
    • Originally posted by kcarring View Post
      IMHO the higher resistance w/o a core is preferable - this is what I find most interesting about your build
      I think your charger will outdo mine.
      put a large FLAB bank on the charging side.
      were did you get your wire?
      Patrick
      • Mods
        Hey Patrick,
        I have a 5k 50W rheostat on order since the 5W potentiometer does heat up when I'm pushing double that through it
        I have played around with a few different variables of resistance and capacitance to the base of the transistor to control on/off time, more experimentation is needed. (I'm using leads to clip on the mods to the trigger circuit in parallel)
        I had not used a trigger as large as 18 gauge but will order a large roll to give a new 7 transistor SS SSG circuit a 100% effort, with the CPD mod and 2W or larger resistors. My aim is simple, eliminate all heat while fully saturating the coil.
        In the past 2 SS SSG circuit I have heat in the coil or pot that needs to be rectified, larger gauge output leads has eliminated most of the issue in the smaller builds, pushing 1-2A @ 12-24V is going to a new senario.
        Then can build a voltage regulator circuit/cap bank combo to hook up to a solar panel in place of the primary. Thus far, battery to battery is more efficient
        Zero
        • LAN Cable SS SSG - No resonance 240312
          Hi to all
          Using a 4 pair LAN cable, no resonance on my crt toroid either its loose or the wires too thin input 12 . 30 output 12.04 even I increase the current fromm 200 to 2 Amps.... need to go back to magnet wire
          From another area I was able to raise the voltage from a converted ALUMINUM battery 70 AH from 12.20 standing voltage now is 13.4 v dc with aluminum electrolyte
          Win some loose some
          totoalas
            How is the schematic exactly cause I cannot understand what you guys did here?
            Did you charge a cap from an SS and then running the SS with the cap?
            tHi
            the schematic is from the joule ringer Yes when I switched off the load the the voltage rise in the battery
            • Originally posted by mklimesh View Post
              Hi Patrick,
              I think that what you show with multiple spikes then a rest period, repeated over and over like you show is a very efficient way to charge a battery. The way you do it is way slicker than how I have been doing it. I've been using a seperate timer circuit to gate it on and off, I'll have to try your setup. Have you put a scope on JB's "10 Amp 12V Battery Charger (AC Power Input)" ? (+_+)
              Mike Klimesh
              Hi Mike,
              I came "this" close to purchasing that charger. then I started getting some fantastic results w/ my own chargers... I am curious though, I would love to see as much on the scope of that charger as you are willing to upload... :-)
              • Originally posted by ZeropointEnergy View Post
                Hey Patrick,
                Zero
                hey there Zero :-)
                I had some heat on my primary transistor and my pot with my 18 gauge 100' coil build, I added another 100' - no more heat. I'm still trying to find the balance, it's coming more clear each day.
                Guy's there is a spot where your coil and cap want to resonate naturally.
                if you remove the diode and get your pot close to the natural resonance, then remove the pot (no resistance parallel to cap) your cap and coil will resonate.
                this is not necessarily the ideal spot, you still have to have the right cap prior to the trigger ie the best "ON" time for your battery bank. once you get in this zone, however, put the diode back, drop the freq a bit and you're there.
                Patrick
                can anyone tell me where to get some of that enamel coated aluminum wire?
                • Originally posted by minoly View Post
                  hey there Zero :-)
                  Patrick
                  Patrick, this is Canadian seller, also has smaller quantities - 100, 200ft - 18 AWG Magnet Wire (Enameled Insulated Wire) 4.5 lb (2 kg), 1 mm diam, 3000 ft | eBay
                  Vtech
                  General D.Eisenhower
                  http://www.nvtronics.org
                  • Patrick, this is Canadian seller, also has smaller quantities - 100, 200ft - 18 AWG Magnet Wire (Enameled Insulated Wire) 4.5 lb (2 kg), 1 mm diam, 3000 ft | eBay
                    Vtech
                    This is the same aluminum wire as I used, same vendor. He also says 7500+ ft. or so for around $100 delivered. one thing that is nice about the aluminum is, when you letz it, it's stronger than you'd think. I imagined it snapping during the process, being AL and not CU. But it did letz pretty tight actually, and no breaks.
                    My roll was a bit short and he was very apologetic and said he would more than double make up for it next order, so I figured that was good enough.
                    One thing I learned though, if you want to use smaller spools like I did, you need to know how much is going to fit, and I would never order "1000 ft. for 10 * 100 ft. winds" again, in other words, I was 50 ft short, and the entire screw up forced me to go from 9 transistors to 4, because I thought I'd have 5 filar on coil, and another 5 filar on another... no such luck, ended up with 5 on one, and 4 on the other, (which changed the LETz'd gauage number of turns, impedence, inductance... everything...)so I just built a 5 filar 4T instead.
                    Moral of the story; buy at least an additional 100 ft or so when doing large builds. And try to have some kind of idea how much is going to fit on your spool before you wind it.
                    Live and Learn
                      Live and Learn
                      You got me thinking... I have unfinished 6 coiler with 6" rotor mainly because the cost of copper. I was planning to have 6 + 1 strands of AWG 18 on each. That's over 4,000' of copper.
                      Maybe I'll get just enough to make one coil and compare with the one I already have
                      Vtech
                      • I think it's worth a try. I'm glad I did. Haven't really built enough copper oscillators to truly know / compare. I'll have a look at the sniffer coil and C/E on the AC side tonight and make a short vid, have a look at the spike. Seems to charge good though, runs cool. i used all mechanical connections so I can't really tell you how it solders up.
                        • Aluminum Air Core SS (MSG) Tesla Switch Oscillator 3T
                          I finally got my head wrapped around the Tesla Switch variant by (Ossie Callanan is it?). Very nice mod to SS SSG. Can't see going back after this initial test.
                          SSG TS (SS MSG 3T) Aluminum Air Core Experiment Pt. 5 - YouTube
                          • Ritalie Hv Hho / Radiant Charger
                            hI TO ALL
                            Just want to know if someone had tried this circuit with off the shelf components
                            thanks
                            totoalas
                              It will not solder. No matter how well you clean aluminum it will attract an oxygen and form thin layer of oxide on the surface. It can be welded but in argon shield.
                              The only way is to connect in screw terminals.
                              Thanks for sharing vid
                              Vtech
                              • @blackchisel
                                Thank you, too, for all the assistance you have offered in the last couple of months, most helpful!
