Hi Vtech,
Thanks for your reply.
Further moved ahead and put the circuit on my power supply with 19.7 volts. Unfortunately there was no improvement in the input and output current as well as on the output voltage. In anticipation of some result kept the battery for charging on 19.7 volts but no significant improvement is observed on the battery.
So far i have made around 6-7 such circuits but only one had delivered the result to me. Unfortunately I had burned out some of the part while I was trying to hook it on power supply. This circuit was taking 1-1.2 amps at input and 0.2 amps with 220 volts at output. The vibration with neo magnet was observed at around 3-4 inch distance.
Some how I could preserve the BD243C of that successful circuit. But when i have installed this on the current circuit then the output voltage is getting dropped drastically.
To my mind it is all necessary to have good input current [between 1-2 amps] and output should be around 0.2-0.3 amps with 260-280 volts. I dont know how to increase the current draw by the circuit because I feel if we can increase the current draw at input and can maintain the output with 0.2-0.3 amps with over 250 volts then it can give good charging. The same i have read somewhere and it was going like this
'For getting a good charging the circuit should take around 2 Amps. For doing so you can increase the input voltage'
Also read at one of the post where one member has got around 0.62 Amps with 200 volts at output and his circuit was performing pretty well.
BUT DONT KNOW HOW TO INCREASE THE CURRENT DRAW.
I know Ash has a successful device with him and sent the pictures to him too. He only advised me to operate the circuit on around 24 volts. Dont know about Aaron.
Praveen
Praveen
I have couple different variations of J.B. charger and C value at the Greatz Bridge varies from 3uF - 10uF - 10 000uF. In the book it shows 3uF. I tried 80uF photo cap before. They're fast but I didn't notice any benefit.
Is this a result of fluoridation in early age
