Originally posted by Sephiroth
The voltage at the capacitor is observed at around 170-200 volts without load. As soon as I connect the charging bettery then the voltage get dropped to around 1-2 volts above the battery voltage.
Mostly today I will source the capacitors having 5000 mfd or above then will test the same.
Praveen
While ago I was doing well rejuvenating Lithium battery pack for a drill and decided to give a try with SS. I was on call and gone for 12 hrs. Since then I cannot charge more than 9V. (It suppose to be 14.4V). Lesson learned.
Just won a scope few minutes ago
) I would try to terminate at 13.5 -13.8V than let it rest overnight and discharge with C20. Don't go too low! Try to measure time. Let it rest and charge again - measure time too. You may have to repeat this charging/discharging cycle several times to format battery but each charging cycle should take less time and each discharge time should increase. This will prove that battery capacitance is increasing too. I'll be away tomorrow but will think about your multicoil idea.
