Hi Praveen
In my setup I replaced 2kOhm base resistor with potentiometer in series with a small light bulb (60mA). I can adjust input mA from 150mA up. Right now I operate between 200 - 250mA. I'm running this circuit continuously for the past couple of months and it's the best of Bedini's chargers I've built so far. My coil is 3x450 of twisted AWG#23 with welding rods core. Coil is 3 inch by 3 inch dia and is full of wire. Between 7 and 2&6 of 555 I put 100kOhm pot to adjust waveform. Also, I put LED in series between 3 of 555 and 1 of H11D2 (I got them cheap instead of H11D1). I tuned 555 for lowest input mA and the moment when LED gets slightly dimmer. I used HV bridge and 80uF capacitor from disposable camera(I couldn't find around any low uF/ HV. Capacitor between 1 and 2&6 of 555 are two 470nF/630V parallel. Output current around 70mA. Circuit works great. I restored 8 SLA (gel acid) 7 - 12Ah batteries, marine HD and currently working on one of the two heavy duty Magnum 1000CCA lead acid. She couldn't be charged conventionally - showing as fully charged but measured only 11.05V. When connected to my SS voltage quickly went to 13.8 but after 12hrs dropped to 11.20. After another 12 hours went up to 11.50 and tonight (36hrs) reading 12.08.
As a source I'm using 1A stabilized power supply with additional 10 000uF capacitor on the output. I use circuit by John Bedini from page 47 FEG book.
I still don't know ideal input. I asked question on Monopole Group but nobody answered. Circuit oscillates @ approx. 1kHz. I have no way to see the wave form, yet. Let me know if I can be any more of help with your project.
Vtech
Vtech
