erfinder,
I am working on the generator all day today while I run these tests for Skeptic. The motor I was using to run my gen locked up for some reason, so I have to pull it apart and figure that out, and may have to wind a new motor. Also, I just got a bunch of the right sized coils of wire that fit in the gen in the mail yesterday along with other parts, so will be using them. They are 680 ft of #23 awg. That's under 20 ohms. I was going to rewind those coils with several strands and do some experimenting to see what produces the most power.
I have already SEEN the effect we discussed when the coils are wound and connected the right way.
I had the gen working for several days before this recent motor lock up.
What I am seeing is that when you pulse a motor with big aluminum rotors and magnets out near the rim, you get that flywheel effect, and when the motor speeds up under the load put on a lenz free generator, (your design, Thaine Heinz, or Matt's) you get significantly more power out than in...and when you run the motor in the 3BGS configuration so you get extended run times without the primaries drawing down...you have the beginnings of something very, very, VERY special.
Skeptic,
If you take the amp hours contained in one good battery and multiply that by 3, that is the MAX amp hours of power you should be able to get out of the system. Over the last five years I have gotten that many amp hours per day and been able to run the setup for several days without drawing down on the primaries. So I can tell you from experience, and I think others can verify this, that what we unleash in battery three is more than just the potential that may be behind the sulfated plates! LOL
If you build it, you will see.
Anyway, back to the basement.
Skeptic,
he is not an English speaker as a first language although pretty bloody good in it.
and so obviously the first thing he wanted to see regarding the 3BGS is a rough schematic. Indeed he's asking to be linked to one on his you tube channel. So he can get the gist, I did try to find a basic schematic not a link or a thumbnail (because of course you need to be “a member to use those) I ended up directing to one I posted on page 52 (52??)
here
…. we'll see
I was writing this obviously as Carroll was writing his post its pretty much ditto
