3 Battery Generating System
  • OK
    If its just rotor with magnets and coils on the stator, your just waisting a bunch of copper.
    Lenz Free Ecklin-Brown style generator is the only way to go.
    You gotta make everything real tight and put a little felt on your rotor so it never completely makes contact with the magnets while at low speeds. the attraction goes away though at higher speed.
    They need to be big magnets. 2" radius half in thick. So the rotor will want to stick. During storage you have to pin it away from the magnets.
    The rotor as shown in the pictures is an attachment blade for weed eaters. You can pick them up for 10 dollars or something.
    The coils do better when constructed short and fat with cores of soft iron welding rods. You can also premagnetize the rods in the opposite direction to get not only a small gain but a more radial sine wave. Do this by bundling the rods with bailing wire, heating the entire bundle up, adding magnets in the correct direction and cooling quickly. Then repeat Until you can pick up a paper clip with just the iron.
    When you store it you have to cover the magnets with something metal to prevent the constant saturation of the coils. Which will cause polarization in the wrong direction.
    Mount the magnets on a NON ferrous material. You can use both sides as well and daisy chain the thing together.
    This generator is only hard to start. Once its up and running you have little t know resistance and should have a very cold current that will run on small wire, as well as charge batteries negatively.
    Mind you it may not measure over unity but if you are slick and not consuming power to turn the motor you'll have real nice setup.
    And NO you cannot see mine, build your own.
      OK
      At long last!!! Once again someone mentions the proper method for building a MOTOR GENERATOR!!!! Personally I wouldn't go with the Eklin-Brown method, but it is definitly a step in the proper direction!!! If you have a little free time and spare parts, invest a little time in that direction.
      I second that! "NO you cannot see mine, build your own."
      • Originally posted by erfinder View Post
        Which way would you go!
        The only reason I do not want to show mine is it is duck tape and bailing wire. LOL its embarrassing to say the least.
        • Do you think it would be an advantage with an Ecklin-Brown style generator to use some mumetal for cutting flux between magnet and coil? Pieces of mumetal are fairly easy to find from old hard drives as well as some surplus sources and mumetal apparently blocks the magnet field better than regular metal.
          Dang is there any kind of motor Konehead hasn't built? LOL
          • Originally posted by ewizard View Post
            I am sure it might, its just a matter of how close you get everything together. At high speed (2000) rpm you just knock the field out of the way for short time. I do not know how much difference it would make.
              Hello Matt,
              I understand now, duck tape..can't say I have needed to use any in any of my contraptions.....yet...LOL...If that is the only reason for not showing it...show it off anyway! You of all people know that this is not a beauty contest it's about demonstrating working principles, and if your device does that then it's definitely worth demonstrating!
              To answer your question as to which direction I would go in, a year or two ago there was a guy who visited this forum. He demonstrated a very interesting Ecklin-Brown type setup, in my opinion, the design and performance of his setup was superior to what I have been able to find and test with regards to Ecklin-Brown. He had youtube videos, and was posting info about his device here. I asked him a few questions which I guess he wasn't ready to answer. Long story short, he vanished!!! He removed all of his videos on youtube and deleted his account!
              Thankfully, in keeping with the times and trends, this individual patented his device.
              5,191,258 - Electric Current Generator Including Torque Reducing Countermagnetic Field
              Very interesting device! The inventor calls it a generator but a few of you here know like I know that motors and generators are one!
              This is the preferred direction (mine), with a few twists of course......
              • Ya I remember that. Its just an Alternating Generator that he applies low voltage to the coils to prevent lenz. He doesn't get rid of it all together.
                PART 2 Motionless Plate Generator - YouTube
                This is Thane Hiens video of his attempt, why part 1 is missing I do not know.
                The thing about it (EB Gen) is how big you can make them. Then all you need is real big burst of torque on the start up and alot of speed after its going.
                If the motor doesn't cost anything to run....well
                I am building better one that actually puts out so when that done I'll show off.
                Its not just duck tape on the one now it really doesn't put out much power compared to what it uses. But It did show me a load with no lenz.
                  I remember that video. Always wondered if part 1 exists, what did he demonstrate in it.
                  Thanes device is probably the closest to the patent I mentioned, and was how I initially planned my device. I decided against the design as I do not want an external prime mover. I found that the magnet and coil can be mounted together and give better results, and further simplifies the machine.
                  In my replication, the device is its own prime mover with the lenzless generator being secondary. The cool thing is how the generator assists the prime mover when its loaded.
                  I like to think of this as a positive twist on the Kromrey.
                  • OK Erfinder,
                    Now you HAVE to show pictures! LOL
                      OK Erfinder,
                      Work in progress....
                      You have no choice but to wait!
                      I don't show my work till its finished! I will make this one exception so that you know I'm serious. I will not post any more images till the device is complete, and tested.
                      This is all there is for the moment.
                        Very nice I'll wait
                        Vtech
                        General D.Eisenhower
                        http://www.nvtronics.org
                        • This would be a great solution for those just getting started.
                          • You don't even want to imagine my build, flower pots ,speaker magnets, and old car fans
                            Matt,..you said something about putting the charge in the battery when its' off or when it's just being connected...?
                            That Eklin Brown only does 4 hits per rev...
                            My pmg is not the normal design....I get a couple 100 per rev..
                            I just need to know how often I should hit the batteries ,and at what values
                            Good stuff............shylo
                            • Ya but your not understanding my point. If you put load on a generator like yours it slows down. The EB does not. And it can have as many poles as you want it too.
                              But then again I really don't know what you have built. Maybe your gen does not load down.
