Randys New Setup
Two bits to add about two things:
1. Try a good Earth ground tied to the two positives between the transducer batteries.
2. If that doesn't help then move the motor to run across both source batteries (provided you can run 24 volts.
Just a thought....
Still trying to adjust to the viewpoint that the scalar is just a waste byproduct and isn't really needed here.
That any motor works is proof of that.
I have no idea what we are looking for? parallel aetheric sympathetic resonance? We live in a strange dimension and universe, unbelievable actually.
I like your bridge analogy Duncan.... #2 above makes the circuit symmetrical like a bridge.
Just a thought....
That any motor works is proof of that.I have no idea what we are looking for? parallel aetheric sympathetic resonance? We live in a strange dimension and universe, unbelievable actually.
not yet.
as I say above no one as far as I know has had any luck with anything other than a brushed motor. However when it happens in front of you .. and it surly will if you persist, you will know it instantly .. and you'll never forget it. Like the song “It takes your breath away”
I drew
. The other is exactly the same. I'm going to try to match them up better. When I started with them one was at .1 volt and the other at 6v. I have a different one at 1v to replace the 6, now 9v batt.
, here's a something worth a try perhaps and the reason why.. with a few guesses of course … I'm going to assume its ground current there seems some evidence for that as battery terminals are melting.
