dave
The electric field of a magnet
Thought Id throw this in here. An Ice record.
Working record made from ice - Boing Boing
Somewhat related.
Dave45, This caught my eye and reminded me of earlier posts:
Voyager’s long goodbye : Nature News & Comment
Voyager is hitting electric fields not predicted...hmmmm.
I have a pet theory that there is some sort of lens effect and that we are going to find out that everything is much closer and FTL is not needed! Its in the same box as my "dinosaur civilization" wiped out by the ice age.
This incorporates both cw and ccw coils into a system, having both coils integrated into a magnetic system is the Key.
It looks as though Hubbard was doing it right the opposite, using the center coil to remove energy from the system.
Index of /ftp/Inventors/Hubbard-Coil
A sine wave into the primary will flip the poles of the primary inducing a sine wave into the secondary's.
The secondary's being wound in this fashion will not work with each other because their poles are the same but will work with the primary individually.
I need a scope in a bad way, maybe after the holiday's.Last edited by Dave45; 12-13-2012, 01:58 PM.
I may have upset a thread with my pretty pictures so I'll get back over here in my corner
I ran across this in a vid and has peaked my interest.
The sign wave path from one side of the galactic plane to the other is very interesting, if we think of the planet as an electron when it crosses the plane it will gain energy but with and opposite polarity.
This is a slow process in the macro but on the micro scale
very interesting my dear Watson very interesting..
Same coil same connections but with 12v ac,
more activity as expected
Hey Bob glad you liked the pics, I hope they help.
I'll get pics of the cell with ac later and post, next Im going to put the pmh in, well its a wire toroid wound with the pmh coils.
The toroid's coils are wound bifilar as well but connected to increase the magnetic field not cancel it.
later
dave
Hey Dave,
I'm right in there with MM, enjoying the visuals you provide.
You've probably seen this link about the Tesla bifilar coils (see figure on the right), where the serial wound pancake coil cancels out mag fields, hugely increases coil capacitance and voltage (low current):
Tesla Bifilar Coil patent - Bedini Bifilar Coil usage in Schoolgirl Radiant Motor Charging devices | MERLib.orgNikola Tesla explains that a standard coil of 1000 turns with a potential of 100 volts across it will have a difference of 0.1 volt between turns. A similar BIFILAR coil will have a potential of 50 volts between turns.
In that the stored energy is a function of the square of the voltages the energy in the BIFILAR will be ... 50 squared / .1 squared = 2500 / .01 = 250,000 times greater than the standard coil
I believe the coil also generates scalar vectors, but that's perhaps something for the Don Smith thread. Anyhow, perhaps the links on this page will shed some light on the magnetic mysteries you are expounding...
Oops, gotta go. Wife just got off phone...
Bob
Hey MM good to read you too bro
I wound a six filar and connected them individually so as to cancel the magnetic field, the resistance went way up I havent done any measurements but running 12 volts at 2 amps barely lights a 12 volt bulb, if I bypass the coil the light shines bright.
I may play with this a bit, I thought of winding a secondary over this coil and pulse through the secondary with a function gen just to see what I can pick up.
I put the cell back in with 12 volts ac, should be ready tomorrow.
later
dave
Originally posted by Dave45 View PostThe coil is not exactly wound bifilar all cw winds are separated and connected together and all ccw winds are separated and connected together.
When you wind a coil back and forth as with normal wound coils every other wind is cw and every other wind is ccw, Im sure a normal wound bifilar is the same, or is it
So much to do
later
as always Bro .... nothing better than visualizing what you are dealing with
Good Reading you Dave
