Rebus57 Tesla Device
  • Rebus57 Tesla Device
    This technology has been suppressed for a long time. We are making it available to you and for whatever reason, you appear to be ignoring it and/or rejecting it. Anyway, we will try again on this separate thread.
    This information was originally posted in the thread, "Don't Kill Dipole". I will attach a pdf file of all the Rebus57 posts shortly. Let's build this thing guys & gals.
    Compilation of Rebus57 Posts @ Energetic
    Compilation of Rebus57 Posts @ Energetic thru October 24, 2010.
      Could you start by telling us what this is and what Rebus achieved with it.
      It is a lot of stuff to read and understand without a proper understandable diagram. Could you neaten up that diagrams and use readable text on it?
        Readable Text
        Hi Nvisser,
        Good to hear from you. What this is, is a free energy power plant, approximately the size of a brief case, that will power your house with electricity. This is fairly old technology dating back to somewhere between the late 1800s and early 1900s. This information was all buried and suppressed by some of our FRIENDS who still exist today. Rebus wants to share this old tech with all of us but it's my understanding he doesn't want to get into how he came by the information and/or what his results with the device have been.
        I've just about got most of the text of the drawing in type written form. There were a few words I couldn't decipher, but will ask Rebus about them later. I will try to get some clarifications on aspects of the drawing as well.
        Best Regards,
        Slovenia
          Original Pics Supplied by Rebus57
          Rebus57 Additional Information
          This project is still under construction/ development. Several years ago I built a prototype to prove the basic theory and hardware, (conversion element switching tube), function and both proved positive results but were not right for final device so it was taken apart to use some parts for final design. Please note a few changes made that have not yet made it into the drawing, first the bobbin coils on ferrite cores are reduced to only three per core a center primary and a secondary at each end, all wound with one turn spacing,(about 31t ea.). Second, breakdown gaps will be 1/4 in. (.250) diameter hollow spheres. Third, I settled in on 1/4 in. dia. X 6.000 long ferrites for 100 HZ, (material). Finally FREE ENERGY SHOULD BE FREE please do not offer for sale this stuff. My goal all along this project has been to build it with easily available parts and materials so anyone with basic tools and skills can be successful in their build. Thanks again for the interest, Rebus57
            I just don't understand, one thing... if his goal is to make it easy, why wont he help figure out whats missing?
              Hi folks, Hi slovenia, this video of a ufo in Italy sure looks exactly like the lifter design you just posted. Looks like someone has built one and is demonstrating it here.
              around 5min. into video and other spots in video you can pause it and see the exact structure that you layout in your lifter diagram. Also in video, they say it chokes down the video camera and his computer in his home as if the craft is causing interference with the normal operation of electronic devices. Very interesting indeed.
              YouTube - Antonio Urzi UFO case, one of the most amazing vids.mp4
              peace love light
              Tyson
                Narrative on Rebus57 "Project X Drawing"
                Well, here is the narrative on the drawing below the diagrams of the short and long tube. I will give a more precise coverage of the entire drawing later.
                LIFTERS
                Quick Sum Up:
                Current collector ring is powered as on-back circuit except maybe higher voltage / frequency. Only one output tube per control surface, as tubes output directly energizes screen & creates a strong field around it. All tubes and surfaces running at same volt / frequency, stability is maintained & stable hover occurs. To move forward, voltage or frequency is lowered creating a void in field & craft moves into this void. Altitude & direction & speed are controlled in a similar manner.
                Note:
                This is drawn as a circle because it is easier to understand. However, I believe this would work just as well in a rectangle, flat with a tubular pressure vessel on top or inside.
                  Originally posted by Slovenia
                  Hi SkyWatcher,
                  Thank you for your post!! I do think that Rebus57 is a special fellow indeed and that this is not just coincidence.
                  Best Regards,
                  Slovenia
                  Hope so too! Lets wait than
                  i read it all and examined the images but could not conclude anything. However there are some interesting points on the reading...
                  nice ufos thought seems real=)
                    Project X Drawing (Redrawn Top Half)
                    Remember, additional information applies:
                    Narrative from Lower Half of drawing:
                    LIFTERS
                    Quick Sum Up:
                    Note:
                    Special Note
                    New Changes to Setup:
                    Please note a few changes made that have not yet made it into the drawing.
                    #1) The bobbin coils on ferrite cores are reduced to only three per core a center primary and a secondary at each end, all wound with one turn spacing,(about 31t ea.).
                    #2) Breakdown gaps will be 1/4 in. (.250) diameter hollow spheres.
                    #3) I settled in on 1/4 in. dia. X 6.000 long ferrites for 100 HZ, (material).
                      Spark Gap Tubes
                      Tube without copper mesh screen in place.
                      Tube with copper mesh screen in place.
                        Configuration of Copper Mesh Screen Used in Tubes
                        Diagram is meant to give you a better idea of the configuration of the copper mesh screen.
                          Why not?
                          Originally posted by Slovenia View Post
                          There are some powerful people who don't want you to have access to this information. We are making it available to you and for whatever reason, you appear to be ignoring it and/or rejecting it. Anyway, we will try again on this separate thread.
                          Hi friend Slovenia,
                          I'm interested on your device and I'm from Italy and not so far from you.
                          Can you contact me on private mail?
                          • #14
                            Update (Breakdown Gap)
                            I mislabeled a drawing and referred to a breakdown gap as a spark gap. This is not correct. According to Rebus57, this is a BREAKDOWN GAP and not a spark gap. I will change this information on my drawing as soon as possible. Thanks and sorry for my mistake.
                            • #15
                              spark gap
                              Hi Slovenia thanks to share this. Can you ask Rebus if it's true regarding spark gaps that they can emit X rays which are not healthy to us?
