Crystal Set Scenario
HEADWATERS:
In a sense we have a crystal set tuned at say 76hz, picked up from maybe the sun or the vibration of the earth rotating or moving through space. We don’t know which but the sun puts out the full radio spectrum, so I suspect a suitable device could be built to pick it up.
Method of Extraction
To extract this and make it usable we use instead of a gang tuning capacitor the following:
1) we wind “bobbin coils” on two separate ferrite iron cores,
2) these core’s, parallel to each other, are moved closer or farther apart until tuning is achieved between coils.
While acting as capacitance the coils also step up the voltage and impart this onto the iron core. The coils are wound on cores in opposite directions to achieve a polyphase effect between the two cores. Now, the resultant “ringing” of the iron core’s at 76hz with a now stepped up to say 25 or 35 volts will cause the random flying atoms near each iron core to be imparted with the 76hz at 30v and will be placed in an orderly orbit around iron cores to be collected for our use. Lets say each iron cores bobbin coil consist of: Primaries say 4, and two sets of secondaries, 2 coils for controls, and 8 coils for our main “CURRENT COLLECTOR TUBE“, and this is per iron core. The 2 control coils run the variable trigger 30v oscillator. The 8 CURRENT COLLECTOR TUBE coils provide our high voltage (2 to 4 thousand volt’s) needed to collect sufficient current to run motors or “lifters” grids through the devices OUTPUT TUBES. This is our VOLTAGE. This covers the two "rod's" that were "pushed in" to turn on the device. They were nothing more than simple ferrite iron rods, transformer cores call them. These cores can be partially inserted into the primary to bring crystal device up, at the same time into control coil for a load, then when controls were up the core's are pushed all the way in to finally couple in high voltage secondary to bring current collector tube on line. Inductive coupling no "magic".
HEADWATERS:
This is the information I promised to locate for you on the crystal set scenario likeness. Anyway, this information was taken directly out of Rebus57's first post on the Pierce Arrow. So, you may want to go back and study that narrative again.
