When playing with magnets I notice that the magnetic current can pass through everything, and also can effect the normal polarity of what it passes through, to a degree. Plastic may be an exception, as far as polarity effect, but it will still pass right through it, too.
But magnetic energy is only a part of what is Aether, and whatever Pyramid Power is , the magnetic part is not what I'm seeing in the pyramid, there is something else. Maybe it is gravitational waves, longitudinal waves, who knows, but it's not magnetic, electric, light , sound, or color waves. I belief there is something other than electromagnetic spectrum waves, but whatever it is, it is still being made or produced by the power of the vortex. Non electromagnetic field theory, or something of the sort...
Pyramid
I read somewhere that aether only stop with plastic, but flow trough wood, wool, resin, or other organic material. Never read rubber relation with aether though.Originally posted by robur View PostIf you sea them what you do is you prevent aether from entering. Aether cannot pass high K dialectrics exept if it is very very concentrated.
robur:
My feeling is that the altenative way of pulseing coils has not really provided much up to now, as it takes Energy to Pulse them.
And we have been pulsing coils, thousands of different types of coils, till the cows come home.
To create a strong vortex (using no moving parts) and using that device to suck in Aether like a drain in the sink. Then convert That force to usable electric power. That is what I'm looking into. The question remains: how to tap an Aether vortex to extract electric power therefrom. My thoughts are on capacitors.
Blackchisel thinks there are other ways to trap that elusive Aether flux. But not like Les Browns shocking pyramid test, as nobody has been able to get a similar result.
Some have mentioned water to hold or store Aether. Others mention antenna coils, or vortex coils with resonant feed-back, and so on.
I'm open to whatever works. My washed beach sand- cement batteries didn't work...
but, "Lidmotors" (YouTube video) beach sand batteries did work.
If you sea them what you do is you prevent aether from entering. Aether cannot pass high K dialectrics exept if it is very very concentrated.Originally posted by sucahyo View PostBedini said that alum prevent corrotion. I now fill gel battery with alum. It seems to hold voltage as good as new, but will kept using it to see if it really can be better. Maybe kept overchaging it too lol.
I see that you have a good time with testing Vtech lol.
I don't think sealing them with resin is a bad idea, that would make it more concentrated, kinda like orac where energy is absorbed by the resin or paper then being focused more inside the copper. It would strengthen it I think.
Very nice result of creating energy bubble that make environment noise dissapear. Nice result for the water too. Those are awesome achievement
@ - Nick. Perhaps capasitors can help, yes. But not till you osiliate Aether field with magnetic field
I tried to replicate LB experiment making sure I'll not hit anything sharp while flying. No luck. Of course I don't have and no intention to build such a big structure atm. but there is something missing from his experiment to make me believe it could happen just like that. Size matters, coil arrangement make sense, winding directions too. Piece of wool in between..fine butOriginally posted by NickZ View PostBlackchisel:
Normally Aether is not detectable. Only when it is converted into electricity by using capacitors to separate the polarities will you be able to see it's effects. Otherwise although it may be present, you will not be able to detect it, see it, or measure it, but you may be able to feel it, like feeling the wind. That is what I have found.
The trick is to create a vortex, and then be able to tap it. Earth's vortex already exists.
I tried something similar to what Les Brown did with his pyramid, when he got shocked. But I saw no results. Nor has anybody else been able to reproduce the effect.
I think that the capacitor is our best friend, that is why I'm playing with the one gallon cement -beach sand battery, that is now an effective capacitor. At least it's good for something. Sometime I'll connect it to my pyramid to see what happens.
Good luck with your tests...
Beside, his pyramid was a shape only, no solid walls. How possibly such energy could concentrate is beyond my imagination and I do posses such.
What I believe is that capacitor isn't the only device which can separate polarities. With such cones arrangement their apexes will become polarized.
Vtech
Bedini said that alum prevent corrotion. I now fill gel battery with alum. It seems to hold voltage as good as new, but will kept using it to see if it really can be better. Maybe kept overchaging it too lol.Originally posted by NickZ View PostLead acid type batteries are always going bad, I think that having an electrolyte is a poor system. I have a bunch of 12 volt Pc Back-up power supply batteries as well as many others batteries that are all bad. It is best not to have anything that will sulfate or corrode. The crystal batteries sounds interesting.
Blackchisel:
More thoughts and updates
I did run some tests with pyramid. Despite couple mistakes I was able to get some scope readings which look promising.
First of all; My cones were done on multilayer paper form laminated with polyester resin. Coils were sealed the same way. Well, it was a mistake. What I did was a result of conventional thinking and sealing/insulating/securing wire but..I encapsulated entire coils in resin which will diminish any effect of Aether upon. They should be made with bare copper (or gold ) wire, close to 1mm thick. They will be easier to wind and easier to secure without gluing entire coil. Nylon fishing line can be used to separate turns from shorting. There should be a gap in between both apexes (assuming that we're working with "hour glass" setup - bases of cones outside) of about 2-1/4" -2-3/8". This is expected Aether concentration area. I did some tests on this gap last night/early morning by placing 6 magnets in a tube, just big enough for them to fit inside and #18 wire wrapped around. Tube was placed between apexes and scope connected. Environmental 50Hz disappeared and I noticed much higher freq. oscillations in range of 35mA.
I also set another experiment for the night in attempt to see the effect on water. I have two cones, separated and sitting on their bases. Base wires are connected to a 6V battery. Apex wires not connected to anything (I did check them with a scope and there is a sin like wave of 5kHz with what appears to be harmonics going up in MHz range. There is no presence of environmental LF ). There is one shot glass sitting on the apex of one cone and other inside a second one. Both are filled with water. There should be an effect on the water. What I expect is that Aether will have an effect on matter and is capable of transforming it.
I was working until 6:30am and had to get up couple hour later. I need a nap before doing any more work but I'll provide more info later.
I couldn't resist checking: Water from the top (apex) of the cone has fluid shapes such as petals, balloons or something similar in shape to the little fan children attach to the handlebars of their bikes.
Water from inside a cone has defined geometric shapes; triangles (nets of triangles/diamonds) hexagons. There is a blue color in aura. Also, while holding hand over there are pulsing effect in other parts of the body. I'm freezing samples in hope to see something trapped in ice and... I need a break lol
Vtech
From other hand, those are the ones you can restore back to full capacity. I've done with several ranging in size from a motorcycle to a large, industrial. Also there are some changes inside done through cycling using radiant charger which case them to be charged in a fraction of time needed before, using conventional charger. They climb over 16V and settle near 13V. All of them were discarded by previous owners as a junk.Originally posted by NickZ View PostLead acid type batteries are always going bad, I think that having an electrolyte is a poor system. I have a bunch of 12 volt Pc Back-up power supply batteries as well as many others batteries that are all bad. It is best not to have anything that will sulfate or corrode. The crystal batteries sounds interesting.
However, idea of constructing a battery cell which can be used in series just like any other and climbing back on its own is pretty amazing. Even if it will provide just emergency light through an oscillator. 1W LED in total darkness is pretty bright.
Vtech
Thanks for the information on the Alum.
I think that in this case I'll try the salt water soaking instead for now. I was hoping beach sand would work as it did for "Lidmotor".
The big one gallon capacitor is still fun to play with. I'll connect it to the pyramid, also. I can also use it to study the polarity issue.
I got shocked from the smaller beer can size battery when I connected it to the joule thief.
I was once informed of an earthquake before it happened by a psychic, and it did turned out to be true. She had also told me about the full and new moon being times of the most intense seismic activity. She also mentioned that New Moon was the worse time for the Japan- China side of the world, as far as earthquakes go.
After 30 years I still remember that chat.
Alum is Amonium aluminium sulfat dodekahidrat, Ammonium Alum, NH4Al(SO4)2.12H2O, usually used to make pickle .
Link by bedini:
McCormick Alum 1 jar Ammonium Aluminum Sulfate on eBay.ca (item 180590058671 end time 20-Mar-11 05:58:58 EDT)
What I get is in shape of crystal shown on page 8.
Interesting that you can shock yourself with wrapped one.
Sucahyo: What is alum?
I only used washed beach sand, and cement. I liked the simplicity and availability of it.
I just wrapped the outside of the plastic gallon jug of the beach sand battery with Aluminum Foil, to see how it would work as a Capacitor. And it seams to work, I get bigger sparks too. Interesting the way that the polarity gets separated by the Leyden jar Capacitor Effect
I think that I made a good bunch of resistors at least, and a big capacitor, Ha. I was thinking of soaking them in sea water and letting them dry out.
I was just playing with one of the cement beer can batteries that was connected to the secondary of a joule thief. I was trying to get a 20 led bulb to light, and, I don't know what I did, but I got the strongest shock that I've felt yet...(from a Jt). The Jt was connected to the cement- sand battery. So, maybe there is something to the beach sand-cement battery idea.
Do you put alum in it?
If you did not, try to submerge them on alum water then leave them for a night and let them dry again.
Guys:
I finished some beach sand batteries. Three beer cans in series, copper 1/4 inch tube inside, gave me 0 volts, nor can I even light an led. It's been over 24 hours since making them, is that too soon? They are dry. I also tried to charge them at about 12 volts from a Jtc., although they do conduct the voltage through them all, they don't seam to hold any charge or output anything.
I also made a one gallon size cement battery, using washed beach sand with a copper spiral coil inside, and another thick copper wire also, which also gave me 0 volts output. Oh, well...
I see that you are not scared lol.
I suggest wire wrap because Egyptian do not build pyramid by carving a granite mountain which should be possible for them if they want, but they use squared rock instead.
I also see an energy device that use grid instead of wall. So maybe faraday cage like may work.
About layer, maybe double layer PCB is stronger. might as well see how much potential build up between the inner layer and the outer layer of copper, Ark of the covenant style ......
