Pyramid
  • NickZ
    Grili:
    Thanks for posting on this thread, I have been missing it, as we discussed many things here.
    I agree that the important point is the direction of the energy, from outside towards the center, and out the poles. That energy this energy is implosive and accumulative, but not destructive. The same force that is found acting inside a pyramid.
    If you make a pyramid like a diamond, the energy pattern is complete. But in any case there is always an invisible reverse polarity energy pyramid under a regular pyramid, that completes and balances the circuit. Same with the Russel coils.
    Who knows what is really under the Great Pyramid, but I'll bet that it is so important that we won't hear about it, for as long as possible. 2012,???
  • grizli
    it is not winding direction its "energy" direction
    Or better to say in "rusell world" there is not opposite like negative or positive...
    "?" is NOT wrong for compression , it goes from center to edges
    but winding is the same direction, so your assumption is correct
    Also other coil , from outer to center, it compress, and compression is marked as arrow
    So if you want to compress "magnet field" in the center you use opposite direction of winding for coil that is pointed in center
  • robur
    BC WHERE ARE YOU?
    I sent you several messages and you don't answer. Are you OK or God forbid something happened? I had depression for 3 weeks with my health it is normal and also PC BREAKING.
    Getting better now and back on the track.
    I am going to construct something related to JT Circuit if i find cores I need
  • NickZ
    The reason that we are sometimes talking about things that don't relate directly with a pyramids, is because indirectly they do relate...
    Even the Bashar antenna coil is meant to be part of something that fits inside a 3 foot pyramid, or tetrahedron.
    I have a 6.5 foot pyramid, and I'm am waiting for the result of the Bashar antenna coil tests. As it costs over a hundred dollars just for the copper wire alone to build the minimum 2 foot size antenna coils. I would probably have to make my antenna about 3 foot tall or so, to fit inside my pyramid.
  • interdesign21
  • blackchisel97
    Hi Alvaro, Yes, it is confusing and it almost looks like either Russell or someone else drew these arrows to hide a concept. I have no doubt that it was operational device if he tried to reach the president and got NORAD attention. To me Bashar antenna is only a half of the picture. Beside, I have a feeling that Bashar antenna alone is not "electrical device" (not meant to tap and convert energy into large amount of electricity. There may be potential appearing but it may not be a primary function. If I may use a similarity to ham antenna, stretched 20m above the ground; we can measure potential and quite a serious one during the storm but that's not the purpose of it. It is antenna designed to receive and/or transmit on certain band (freq).
    What if we're the receivers or transceiver in this case and Bashar device is an antenna per se, designed to make us sensitive to a certain "band"?
    I'm not trying to propagate ET communication here, just a thought.
    Vtech
  • NickZ
    @ Interdesign:
    I had seen the same thing in Russel's drawings. It impossible to say what is right. I would follow the Bashar antenna coil design, as it is simpler and easier to follow. They probably both function is similar way.
    There is a new video out now (3rd of May) by Morpher on YouTube with a new coil antenna, full size 2 foot tall model. I still have not heard of any power coming off of it, yet. I think that the Bashar antenna design is similar to a Tv antenna, in that without the rest of the Tv circuit, just the antenna by itself may be useless. Hopefully the needed information will be soon forthcoming...
    Good luck with your antenna coils, please let us know how it goes, and thanks for reactivating this thread, I was missing it.
    NickZ
  • interdesign21
    Last edited by interdesign21; 05-05-2011, 11:49 AM. Reason: I succeed in attaching image
  • NickZ
    Just took a pic of my sand and cement batteries, and I thought I'd pass it along. Just beach sand and cement mostly. The cans with the spiral copper tube and baking powder added will take a charge and hold it for a while.
    Guys, have you seen this device (second picture)? But will it fly?
    Anybody having any luck with their space antenna project???
  • NickZ
    I looks like the Hartley Occillator is the way to go with the cement batteries, as that occillator will work at very low current, which is what these batteries lack the most of. Blackchisel- your circuit sounds like a regular joule thief with pot, and different type of straight air core coil. I tried to make the coil on a ball point pen inside 1/8" tube, but have not got it right yet. I need more of the 30 gauge wire.
    The Hartley Occillator mentioned above can run on Micro Amps, and it looks like it feeds-back to the battery, so it can run on an AA for months. There are many versions of it, I'm still looking into it, but it does seam like the way to go, to make the best use of the cement batteries.
    This is one version of it:
    YouTube - hartley oscillator update.MOV
  • NickZ
    I seam to have picked up some kind of virus, and again did not sleep last night, also had a fever. The moon was not the cause, although I do have a problem sleeping on full moon nights.
    Sucahyo- yes, we get the same thing with the caterpillars here in Costa Rica, but they usually don't last too long. I reminds me of the locusts in some places that eat everything, sometimes including people, if true. Some of them can sting very hard, and hurts for a long time.
    The cement batteries are working better with the inverted coil, much more mAs. I also made a test using only 1/2 of the can and a straight copper tube, and that one only outputs half the voltage and one mA, but still works together with the others to produce a higher output.
    Maybe if several of cement batteries are connected together to produce 12 volts, although they drop down in output, they still may produce enough current to power things without dropping to dim level. I'll make some more when I feel better.
    The space antenna project reminds me of the many years spent trying to make the TPU work as in the Steven Mark videos. And still no cigar.
    I hope this antenna coil will be different, and not so much speculation, or guessing. I keep checking for an update.
  • sucahyo
    NickZ, I think cemenite can help reduce moon effect. I think you should make cemenite.
    For agriculture, the last time I bury it do not produce bad effect to dragon fruit plant, it still grow new branch. I don't have chance to observe it unfortunately. I bury it for other reason.
    Strange event happen just few days after I bury cemenite. Caterpilaar attack happen near the location where I bury cemenite. The caterpilar attack coincindentally never reach the vilage where I bury the cemenite even when the attack spread to some other places in Java Island.
    Millions of Caterpillars Attacking Citizens Probolinggo | 1001zones
    Caterpillars invasion in Probolinggo, East Java
    About cement battery, I still looking for clue about how to make it properly. Hopefully there will be waterless version in the future.
    I wonder when Bashar will release information about how to complete the space time antenna.
  • blackchisel97
    Originally posted by Golden Mean View Post
    What if we took the Bashar cone coils and put a bifiliar rodin coil in the around the intersection point. Then pulse one ciruit of the rodin coil as the input frequency and use the other as a pickup circuit after the pulse travels outward and collapses back inward to the intersection. The idea is to use the Bashar cone coil as an electromagnetic amplifier.
    This is more of a "brainstorm" idea than based on any particular experience, but it may be worth a shot.
    Good thinking As you can see on some of my pics with cones I have a Rodin in between or near. I also tried a starship. There is one unknown to me regarding Rodin in such setup; how it should be done? How many deg. apart? 45 - 90 - 105?
    Beside, I was imagining Rodin coil as a collector, not the input..but who knows?
    I had to leave them alone for couple of days to get my thinking straight but will do some more work and perhaps wind them bigger with more wire.
    Thanks for idea
    Vtech
  • Golden Mean
  • blackchisel97
    Thanks for the pictures sucahyo I had only couple of them. I'm hoping to get that book (Atomic Suicide) which may have more explanation on his experiment. To me Bashar coil is an antenna while Russell's suppose to be the device. We don't know what else is missing from this blueprint but Bashar coil appear to be the exact half of Russell's. Both say it has to be energized. I do believe that it needs DC pulse, not just a wire snap on the coil. Possibly two signals of different freq. It may require relatively small input but it will have to be supplied in continuous matter. It is just the way I suspect. I maybe totally wrong.
    Shauberger did read Russel's work. There are also similarities in thinking way in Ed's work and writings. Not to mention the pyramids with their messages engraved on the walls. Male and female energies represented by symbols as well as process of "giving" and "receiving" (or passing on). Russels were way too serious to call up Norad and request forwarding message to the president if it was only a hype. They got it. So did Schauberger, so did Ed. Who's next?
    I know that my coils are too small, not because of Bashar description but mere feeling.
    Vtech
