I hope you can find a way to solve your problem. My best wish for you.
Pyramid
Thanks for the compass info robur
Neighbors can be a pain when you're trying to do something they cannot grasp. If you try to explain, they won't believe but at the same time may cause a problems. Reason I like not to have neighbors. Law enforcement officials can be worked with, depending where you live. There is nothing illegal in doing science experiments at home. Of course after 9/11 things changed. I was doing some reading and working on new pyramid. Also starting to wind cone coils. Still not entirely clear on their direction and wire thickness. Winding cones with thin wire isn't easy.Originally posted by robur View PostI am sorry for my abscense. I am very very depressed now.
Things for me got worse. I might loose my housing due to neighbours reporting me to police and my landlord. I did some alchemy experiments 4 days ago. I do all sorts of things from time to time what are easy.
Neighbours reported me. Police came and confiscated some things.
Now might loose the housing as a result. Feeling soo bad.
Another builder had left me. He cursed me and wished me to ''drop dead as soon as possible'' I guess he sent me some negative energys as well.
He was supposed to do tests with cones. He did nothing.He made cones, yes. He claimed they affected electronic goods in his house.
Then cursed me and wrote on his forum i am a delusional guy who must be banned.
You can detect Aether Vortex with a compass. If you place a compass onto place where the vortex is most concentrated it would affect the magnetic needle - it would start to spin. The direction of the spin and it's speed would indicate you the direction of flow and how fast it is spinning.
I be back with more in a few days.
To blackchisel: Please come online. I haven't seen you online ever since we first spoke.
I'll be online later. Need to get some work done.
Don't let people mess with your life. You have the same rights as they do.
I'll talk to you soon
Thank you
Vtech
Yes, but it can also from our own body too. Our body generate energy too.Originally posted by NickZ View PostInsomnia may be a result of absorbing more energy than you can handle. You can't turn off all the the input your mind is receiving, like a video receiver 24/7, no off switch.
Shielding external influence can help but I think creating monopole to absorb the excess energy help it better.
For material property, wool (also used by Reichenbach) seems has the ability to absorb orgone and maybe trasfer it, but maybe less than silk (used by Keely and Tesla).
For energy, I do believe big spiral coil has health effect. But I think as sensitive, Tesla surely now how to utilize it in a good way. He has insomnia, and later in his life he make himself sleeping aid with disrupter
(mentioned by vassilatos)
When I get low signal, I place my cellphone near my cemenite, seems to increase the signal.
I see the pyramid more as focusing the EM wave so, there is side that has more EM wave and side that has less EM wave. People can see aura, I think strong aether device will have influence on EM wave too.
Blackchisel:
Glad that you see some usefulness with the coil resonance antenna idea.
It seams something similar to a radio transmitter, but you are instead transmitting through a coil, or pyramid, at a certain frequency (current Earth Pulse) and are then receiving through the tuned circuit reamplification of the original pulses to a higher voltage and current through a resonant effect with the earth pulse frequency.
You are tapping the Earths Pulse, and extracting power, by pulsing a tuned coil at that same exact same frequency, which causes it to resonate, yielding a higher output.
I know it may have been tried before, but maybe not quite like this. Reminds me of a Tv antenna signal boaster, but for amplifying electric power instead.
BTW very nice blue crystal.
I does make sense. I don't have a TV for the past several years. I found scope screen more entertainingOriginally posted by NickZ View PostBlackchisel:
If you connect your frame pyramid to a Tv antenna wire and then to the antenna input on a Tv, you'll find that it does work as an antenna to a degree. And it can be tuned in by turning it around.
I was just reading on another forum that when a coil is pulsed with the right frequency, it will act as an antenna. Both transmitting and receiving signals at the same time. While transmitting at the same resonant frequency as the earths pulse, it will at the same time be caused to receive an additional input that will amplify the original wave sent out, while providing more power back than the original voltage sent or used.
So, it looks like coils are antennas, also. And if pulsed with the right frequency, can act like an Tv antenna boaster, that will amplify the weak earths pulse and cause it to be amplified back much stronger. It is done by transmitting at the same resonant frequency that you want to receive.
Pyramids may work as resonant Aether antennas.
I don't know if that makes sense as I've put it, I've tried to explain it as best as I could. Although not my ideas, they make some sense to me.
We'll see if it works...
I highlighted your words to stress further their importance and link to what I have said earlier as well as your question about Aether.
Most coils are spirals of different kind. Spirals are likely to resonate with Aether and guides, directing on certain path. To me Aether is superior, fluid like basic substrate of the Universe which can be interacted with. Those interaction will produce energy disturbance and propagation/flow. There are natural forms resonating, thus being in harmony with Aether. I believe that Pyramid(s) were built according to the same architect and same principle. We need to find a medium (coil-crystal or combination of such) arranged in shape which will allow to interact with Aether and cause to respond in controllable manner. Energy in general, magnetism, gravity, they're all related and interconnected with Aether. Resonance is the key.
Some may disagree but that's the way I see it.
Answering your question from previous post about detectable energy in my new pyramid shape; there is quite strong field near all four corners (outside) as well as apex area, outside as well. I was busy with couple other test/ preparations and didn't finish yet.
Vtech
Blackchisel:
Blackchisel and Sucahyo.
You mentioned that your new pyramids energy is detectable. What do you mean by that?
Sucahyo: Les Brown was thrown 20 feet through the air. Whatever that force is, we need to know about it. Too bad he's dead now. His death may have been caused by the negative energy that you spoke of, producing cancer.
He did mention that it can drain the life out of you. He left his video for us. I trust that what he was saying is true, and that he was a true Light, and very inspired, like Tesla. And that they were both Lighting the way, for us.
Strips of sheepskin is what Les used to connect the pancake coil to the antenna coil on the top. No additional power or components were used. Can that effect be reproduced to any degree?
Tesla had been seen in fotos showing him sitting next to the big vertical pancake coil, possibly absorbing the energy therefrom.
Anyone know more about that?
I am interested in Electromedicine, also a new science called Astromedicine, as well as the anti-aging aspect.
It seams to me that although Tesla was naturally smart, he may have been further influenced by absorbing the additional radiant energy that was surrounding him at times. He did live to be quite old. If we could only talk to him now. Maybe someone can still do that, telepathecally.
I feel that healing or energy balancing is in part a matter of first adjusting the body's etheric field, so that the physical body can it can heal itself. As that can sometimes be the cause of many but not all of the physical problems. As some people can sometimes make themselves physically, mentally, entirely sick, by just a single negative thought or emotion. Possibly a medical instrument or electromagnetic machine or sorts can help. But do they really work? Not like some devices.
What we call miracles, are things we just don't understand, yet.
Aether, or etheric. Same thing. Not detectable by normal instruments and meters? Like the energy in the pyramid. It is not electrical or magnetic. What is it? Both, or neither? Or something else?
The question is:
What is Aether, or etheric?
Energy creates matter, and matter is subject to its laws, not the other way around.
The story of "Merlin the Magician" has always fascinated me. Making flowers out of thin air, etz..
Nice pyramid
. I will look forward for your result
The crystal look beautifull.
I wonder if what I have now is alum or not lol, it seems that everyone use powder, and I can only find crystalize version, but not sure if it is ammonium....
Will plan to use it for my next one. Currently use it to fill weak gel battery.
My new pyramid, coming. I'm waiting for copper sheets but this shape alone has detectable energy. I'll try to test whatever I can. Just finished mold for cone coils.
[IMG]
[/IMG]
and some home grown crystals - [IMG]
[/IMG]
@sucahyo interesting link
Vtech
Mythbuster experiment on apple is interesting. But it is unfair to put the control just outside the pyramid. The control should be next to the box.
Very interesting story about being thrown 20 meters. But is that electricity?
Everyone interested in three times cooked and freezed beach sand to make bions?
HOW TO MAKE BIONITE & BION GENERATORS - Orgonite Gifting
I wonder if it make stronger battery, or just make a strong cemenite lol. My crystal battery has some insulated copper coil in it ....
For output current of crystal battery, I wonder if it related to surface area of negative vs the positive electrode.
I have to shock my self with my 3V stingo whenever I want to use it as zapper, before I use it to my family, it is strong enough to freeze my arm. Don't underestimate radiant circuit
I will do a test with adding salt to the sand on just one of the beach sand batteries, to compare with the ones without salt. I'll also wash some sand, and see how that works. All other variables will be the same.
I was reading more about Les Brown, trying to find his second book, or at least more information. But maybe he died before it was printed. He seamed to have a lot of insight.
Actually, you may want to wash beach sand to get rid of salt if you want to try making battery without electrolyte. Salt will increase performance such as voltage and amperage but will eventually consume your electrodes. Nice thing about beach sand is high quartz content but also some calcium particles - sea shells. I can't get this stuff atm. I wish I could live somewhere where is no snow. I really hate that stuffOriginally posted by NickZ View PostBlackchisel and Sucahyo:
I just finished watching both your videos on cement batteries, or crystal batteries. I can't wait to try it myself, just need to get some cement. I got plenty of beach sand just a few yards away. It is made of mostly quartz. There are many types and grades of beach sand also, and so some may work better than others.
I was thinking of making a dozen can batteries to see it I can get around 12 volts. I wonder how they will further charge up if connected to a solar panel or wall adapter. As these cans make them look more like capacitors, than batteries. If this works using just beach sand and cement, people can make them in the areas where there is no electric power, or when one can't afford to pay for it. The nice part is that they can be connected in series (like a solar cells) to make the voltage you want, or the current needed, and any one can make them, even with no experience.
I just got the biggest shock from one of my Joule thiefs, just now. I could not take the shock as it really hurts. The Jt only puts out about 15 volts, but must have some watts to it also. It's just a one inch toroid, with a 76 turns of 26 guage magnet wire, TIP3055 trans. The secondary wire (one wire) touched the under part of my arm, and shocked my whole body, as I was sweating and my arm had salt on it from the beach. Surprised that my device could shock the heck out of me, as it never happened like that before. Makes me think that maybe adding a bit more Salt might help to increase the voltage in the beach sand batteries.
Your experience with JT reminded me when I was trying to secure terminal clamp on one of the batteries I was charging from one of my rejuvenators. I was touching exposed metal part when clamp lost connection with terminal for a brief moment. This charger when not shorted with battery will deliver over 700V 1kHz pulse. My arm went numb all the way to the elbow. Funniest part is that I was driving truck with 53' reefer and this incident happened when going through Bronx Expressway
Vtech
