Pyramid
  • NickZ
    Bc:
    Thanks for the ideas. I am far from civilization, as well as any stores like Radio Stack etz.. The beach sand batteries do work, so I will improve the next ones by adding baking power, and making the copper wire spiral though itself and up. I think that will help. I'll let you know how it goes.
    Thanks again for the support.
    I was watching Tomata's latest video on the Tesla Patent of drawing energy from the air by using a metal sheet 1 by 2 meters, placed 12 meters high and another sheet of 1 by 1 mt. buried in the ground. He has some amazing results. Suggest everyone check that out. 800 to 1000 volts radiant energy.
    The Bashar's space- time antenna has also finally made it to this forum, great. I've also been counting on that one...
    Below is a picture of where I access my beach sand.
  • blackchisel97
    @142857 This is very nice Thank you for sharing
    Vtech
  • 142857
    Treyeangle
ID:	450375 I've read some weird stuff in this thread.....just finished painting this....thought it somehow applied....
  • blackchisel97
    Darn thing wont let me edit, look at one of John Bedini youtube's about iron pyrite batteries. There is a circuit.
    V
  • blackchisel97
    Blackchisel and All:
    I finally was able to get some output from my beach sand cement batteries.
    They are now putting out about 1.3 volts each. Two beer cans will light an Led about 60 % brightness. I'm making a Jtc (with no resistor) for each can battery now, so that each can battery will light an Led. They are also taking and holding a charge to some degree. I cut a slit on one side of the cans so that the plastic coating wouldn't affect it as before. Now when they are shorted out they just bounce right back, so I know they are working.
    It's been about one month after they were made, and the are bone dry now.
    I just used beach sand, a straight 1/4 inch copper tube, beer can and cement.
    Lidmotors beach sand idea works! And this is my first free lighting led. Although it not the brightest led, it's on 24/7. I'll be adding more cans to increase the brightness, soon.
    Bc- I would probably have given up if you had not mentioned that you've got all of yours still working. Thanks.
    Glad it is finally working for you. Try slightly different oscillator, look in the "Earth Light" thread (first post). Use 20 -50k pot instead of fixed resistor. Coils is 35 bifilar #30 or close on piece of iron (welding rod). You can also do aircoil but increase wire length approx. 10 ft more. You'll see it on my vid's. It will light LED fully bright at 4 - 4.5mA and 0.75V. You'll notice that lowest resistance doesn't mean brightest LED. Each battery may have different resonant spot. 2N222 or similar.
    Vtech
  • NickZ
  • blackchisel97
    Originally posted by Crono View Post
    Also anyone think that Aether and the Higgs field are not necessarily the same thing but at least related in some way?
    Everything is related to Aether, in some way
    Davidson is a good read.
    Vtech
  • Crono
    thanks. Few things bring me greater joy than being spoon fed information. I'm assuming you've read Shape Power Dan A. Davidson, anyone that hasn't, it's a good read. If you have any slightly more... unorthodox liks, PM me.
  • NickZ
    Crono:
    No apologies needed. If you would like to try and replicate the space-time antenna, as looks as if it is fairly easy to do. Here is a link to the Basher antenna coil video:
    YouTube - Bashar - Free Energy Space-Time Antenna with Photos
    Also a link to their Yahoo Groups that is experimenting with that design:
    space-time-antenna : Free Energy Space-Time Antenna Research
    That should keep you busy for a while. Just need to find some insulated copper wire, and to make some kind of support for the coil.
  • Crono
  • Crono
  • NickZ
    Crono:
    Thanks for your ideas. However many times hunches may not work, as practically nobody's "ideas" have been able to produce any free electricity, other than solar, wind, and hydro. Most of which produce electricity by the same old method of passing magnets by coils, except for the solar cells. They are possibly the best example so far, of what can be achieved without any moving parts. But also have many drawbacks, such as requiring expensive battery banks, price, etz...
    The Bashar space antenna sound very interesting to me. I'm hoping to see it progress into what may become the best free energy source, yet.
  • Crono
  • NickZ
    Bc: That diagram of Russells is just what I was also talking about. We are referring to the same thing. There is much similarity in both designs.
    I think that there is something to this whole Aether conversion concept. Worth looking into.
  • NickZ
    Sucahyo:
    Walter Russell had a diagram of an inverted vortex coil design on paper, but the points of the conic coils are touching each other in the center and going out each way, instead.
    I was watching the Singing Tibetan Bowls videos and you can clearly hear that their produced sounds do resonate with one another, and due to this simpathetic resonance their tone(s) are amplified and kept re-ringing for a much longer duration before fading out. Thus adding many fold to the original tone, and can be kept ringing with just a slight additional effort.
    The space antenna is like ringing the bell, a bell that doesn't stop ringing once it's started, or like playing the Tibetan Bowls. Once resonance sets in, it self resonates, until... who knows...
    There is an new update on jump starting the space antenna coils with a battery now, but there is no more information out on that, yet. Connecting it to 120 volts wall outlet causes a direct short circuit, of course. So, that is not the way to go, in my opinion. But, I was wondering how a strong Jtc would do if connected to the space antenna coils, to jump start it. Just like I did with my 6 foot pyramid-Jt circuit test that I did the other day.
    It certainly got me jumpin'
    I think that I need to connect a salt water capacitor in with the pyramid -Jt circuit. As the salt water really adds to the capacitor effect to produce a much higher charging voltage , possibly similar to what spinning water does to help charge up faster.
    Looks like it's pretty easy to start on the building of the space antenna coils with just some thick insulated copper wire. Worth a try, at least.
