Pyramid
  • sucahyo
    Thanks NickZ.
    Thanks for the explaining of how the rods works.
    It is very interesting how the flow change 180 degree at after 1/3. If we consider the energy move in a spin, maybe what you detect is the outer flow of the spin. So when you detect the energy turning south it is possible that you are detecting counter clockwise spin, some consider as male polarity. Where directing north the energy is spin clockwise.
    But this assume you measure from west of the pyramid.....Lol, I am prepared to be wrong ....
    I think you will find quote bellow interesting:
    The trees in the northern hemisphere that are not evergreens alter the spin direction and it's field diameters twice yearly.
    On march 18( aprox)
    and Sept 22nd( aprox)
    During the winter the dominant above surface field spin direction is clockwise, on march the 18th this slowly stops and reverses totally, as does the field below surface, then the dominant field is focussed above the tree, the water FALLS to the top of the tree, on Sept 22nd they again reverse and all the water is then attracted back underground to a point below the tree.
    I consider every branch and root as antennae, then i assume that the tree alters the shape of the resonant structure, thus reversing the field flows.
    The positive flow nearest the earth has fallen by halve, the trees are electricly based and thus know that winter is arriving, they are altering the field spin direction about themselves and the water is falling back towards the earth under the normal what we call gravity domain, in summer the trees totally turn this around and the water falls to the top of the tree, because gravity is a consequence not a force, it is about attraction of one state of spin to the other.
    This is why the trees suddenly all react and the leaves dry out fast, and it all happens on a measurable grid, as blake painted.
    What I mean by detecting polarity is if you feel change of energy, not movement, but sensation from your hand or heart.
    Let's hope all will goes well. I somehow hope my current female/male energy research can protect me from earthquake and typhoon.....
  • NickZ
    Sucahyo:
    I have not yet noticed any changes from the current solar flare activity here, other than the normal intense effects of the Feb. full moon. But, there have been many earthquakes, all over the world, and it may not be over yet, but just starting... Solar flares are very important to our uncertain future, as the whole solar system is Amping up. The overload in the Sun, is released in the form of solar flares, this last one is the size of Jupiter. But, it depends on which direction they go towards.
    Pyramid test: I can detect changes of the direction of energy flow, (or polarity), from the 1/3 to 2/3 from the top. I also can see the direction of the force of energy from the outside towards the inside, then from the inside center to the outside. As these things are invisible, the rods only tell me the direction, and strength of force or currents.
    I checked the polarity or direction of force...
    of the 1/3 King's chamber area, the direction of force is towards the north. That is, the rod stops and point to the north.
    The 2/3 area is south direction polarity flow, The rod stops and points to the south, 180 degree difference.
    So, it does look like there is kind of a polarity, or at least a difference in the direction of the flow of the energy, at different levels or areas inside the pyramid. This could be the cause some your different effects, yes...
  • sucahyo
    Thank you. Can you detect the energy type? Sensation of power or calmness? DO you detect change of type between 1/3 and 2/3?
    Thank you for the warning, I see some bad thing already happening in Australia. I hope I can do something to ease the effect. Or to know if it is not working.
    Isn't solar flare the best time to test energy of radiant circuit?
  • NickZ
    Sucahyo:
    Using a divining rod in relation to the pyramid, is not like using a volt meter. What I notice more than anything else is the direction of the flow and where it is located. It shows that the top and corners is where energy is flowing out. You can also feel that there is more force on the frame. But I have not spent much time on that, as I already know those things. If there is something that you'd like for me to try, just let me know.
    There days there is a huge solar flare activity. Bigger and stronger than in the last several years. Your side of the world may be more affected. At least there is some signs of the solar activity affecting China.
    As the pyramid is also somewhat like a cosmic antenna, it should respond to the increased plasma energy streams. I'll let you know if I can notice anything different in the readings these days. So far I have not noticed anything different here in relation to this current solar flare.
  • sucahyo
    NickZ, what kind of reading can you get from a pyramid, compare to a battery for instance?
    Do you always get consistent reading from pyramid? or differ from time to time?
  • NickZ
    Sucahyo and All:
    I am good at using divining rods, of Any kind, as in looking for underground water veins for drilling wells, etz... There are field energies that can be felt by using these rods, that otherwise you would never be able to detect or feel, especially by using multi-meters, or scopes. There is more than just electromagnetic energy. The pyramid is an example of a different kind of energy, that is not magnetic or electrical. Nothing can be detected by connecting our meters to a pyramid. Although it can contain both electric and magnetic force, and other forces as well, that we can't measure either. Crystaline frequencies are another example.
    By tapping magnetic flux lines, we can convert magnetic to electric currents, as magnetic and electric energy are two sides of the same coin. What you call polarity may be the separation of not just + or - current, but also one type of energy from another. The idea is to tap the dipole, without killing it, as a closed system will never be able to produce endlessly, no matter how hard we try. Like a dog barking up the wrong tree.
  • sucahyo
    Agree, at least able to detect them without tool can be a big help. Would love to get a reading of flow on my circuit .
  • NickZ
    Sucahyo and All:
    As strange as it may sounds to us, psychic insight and psychic energy may be just what is needed to tune into and make some of these type of devices work. If that is how they were designed, in part by using the human energy field as a additional input source.
    It is what is called "Mind technologies" that may ultimately advance us into the next phase of inventions uniting the physical with the non physical worlds. Corporal with non corporal, or, Non- technological mind sciences.
    All in all it has to do with the not so popular Vortex Theory. What holds everything in place, is a vortex within a vortex, within a vortex etc... which we can see everywhere, and in everything made by nature, like Natures footprint.
    To use this vortex energy is to use the power of nature itself.
    Even if Keely and other don't recognize it as such, they are still using vortex geometries and frequencies, as that is all there is, and everything come from that same source.
    NickZ
  • sucahyo
    Thanks for the link.
    User esaruoho seems to had order from Witts, you may ask his experience:
    The result from ATTREE replication it seems still bellow 1 volts in overunity.com.
    Maybe you have to be a psychic like Marcell vogel to tune ATTREE to 36V output at >1 Amp.
  • NickZ
    Guys:
    For those of you that are not familiar with the Witts Dome device. Here are a couple of their videos:
    YouTube - Hemisphere Quantum Fuelless Generator - Demo #1
    YouTube - Hemisphere Generator Starts Jeep - Quantum Electric Demo
    They mention that a pyramid shape could also be used, instead of the dome, and they have made several devices of various sizes, and voltages. 12v, 120v, 220 volts etz...
    The videos were made in 1993, or so. A lot of time has past since then. We can only imagine what they might have improved on, by now.
    They mention Harmonic and 1/3 wave Inharmonic frequencies are used to separate the Positron from the Electron, thus producing power. But again, they are not showing or telling any more... same old story. But, it's enough information shown, to gives us hope that such a thing is possible. What other portable device can start a car?
  • NickZ
    Sucahyo:
    I agree, but, there has to be a way to tap this radiant, or Aether energy directly. We just have not hit on it yet.
    The 10 inch Dome device by MITTS is the closest thing (I've seen) to usable energy from a very small device, not just fluffly voltage. It is small and portable, and can even start a car motor if connected to the battery terminals. But again, nobody has been able to replicate it...
    Or, have they????
  • sucahyo
    NickZ, yes, it seems the guys at overunity.com (in that page link) who try to replicate do not obtain significant voltage. It seems the way it work still not understood. It seems everyone giving up when they theory fail.
  • NickZ
    Sucahyo and All:
    Thank you for bringing up that idea. Until it is proven and replicated it is just another idea. The pattent office is full of such "working" ideas, that nobody can replicate. We don't know how much voltage or current it can produce, or if it even works as stated. It does look interesting, but why has it not been put to use?
    It is still hard to compete with solar panels, as they also output a lot of Current. And are fairly cheap for the smaller size ones, and very available.
    Current is also needed to properly light Leds, and run motors etz, not just fluffy voltage, although just voltage can be used sometimes, but not for any real work.
    Voltage only devices are still impractical...
    I still think that the SM type toroid devices or the WITTS Dome, do work as has been shown in their videos, and the small 10 inch Dome can even start a car motor. That is where I'm headed as soon as it becomes a replicable reality. Both devices are small and powerful. The secret form of operation is still undiscovered. Black Science?
    The WITTS people mention that the trick is to separate the negative Electron from the Positron, and that their device does that. The Dome uses a toroid, a capacitor, or sometimes a battery to operate. Too bad they are also so materialistic, and won't really share their ideas, unless you pay to play their game. Even then, they also say that their devices were not ready for the market yet. That was mentioned years ago. The Dome looked like it had been sitting in a closet for at least 30 years, even back then. But, nobody has been able to replicate it yet, either, at least that we know about.
  • sucahyo
    NickZ, have you ever read this:
    Peter Markovich: Apparatus To Rectify Ether Energy (ATREE)
    It is a device that said to convert aether to electricity. Now that I look it close, it seems the invento put it under a copper pyramid?
  • sucahyo
    Sucahyo and All:
    What comes to mind was to wind a bifilar coil around a small 6 inch copper tube pyramid frame, for now, just to test the idea.
    Connecting both ends of the bifilar coil just like a normal joule thief. The copper tube pyramid frame would then be acting as the core, with the bifilar wrapping all the way around the frame. Using one or two AA batteries would turn on the Jtc transistor such as a TIP3055, thus pulsing the pyramid shaped core. Output could be taken off the E and C of the transistor, or off a secondary wound on top of the primary bifilar coil.
    A simple test unit like that would not be hard to build.
    What do you think, worth trying? Yes, no?
    No. If there are voltage generation from the pyramid, I think it would be from the different polarization inside the pyramid space (1/3, 2/3 location, etc) or from the frame it self.
    See if there are voltage differential on the frame, and use the bifilar gating different pyramid inside block.
    See if pulsed coil produce different output on different pyramid inside space.
    Try imageshack to upload image, use embed thumbnail for forum1.
