gravity waves found
  • david lambright
    a new video
    Leedskalnin's generator & the visible flow of magnetic current - YouTube let me know what you think
  • david lambright
    coral deforming
    coral deformation - YouTube you have to watch pretty close
  • david lambright
    what i have found
    What i have found is that Eds PMH held this energy forever, till the core loop is broken. His generator at coral castle is a PMH, the magnetism is residual, left over from being energized like any iron PMH will do. The field that PMH makes can be oriented by gravity, artificial or natural. The artificial way Ed used was centrifugal so that the center line [axis] and equatorial plane are opposite sides of the energy he termed magnetic current. I have also found that this energy is absolutely and completely visible. https://www.youtube.com/watch?v=KsyUU0fPxeo and https://www.youtube.com/watch?v=uRgcC_mK97k are a couple of examples of just how visible this field can be. I am still trying to get usable video of a piece of coral deforming in this field, what i mean by that is i can push down on the coral and it bends ever so slightly but even a deformation of hundredths or even thousandths would be significant, wouldn't it ? And the way a PMH can induce giant paramagnetism in MANY metals, [aluminum, LEAD, magnesium etc.] and even heating the lead to melting did not cause the metal to loose its newfound property, just showing that this energy is profound in its abilities. With the coral, it is like the density is being manipulated, making it become softer and lighter. There is another thing i have noticed, is that at times, certain objects SEEM to loose some of their opaque-ness, but movement, or another form of energy has to be added to get that effect. I have seen a video from John Hutchinson that has many similarities to what I and many others are experiencing with the devices I make. I believe John makes something similar but with HF radio and other waves as the extra energy needed, added to a PMH type field, to obtain his effects. I believe that he looses a lot in controlability of the effect, using electrically produced fields and that Ed made the same type of field using magnetics as its source so he gained a better control of the energy fields . Edward Leedskalnin cut and placed many tons of stone. He said he used the generator, at his castle, to accomplish this feat, i believe he did just that and it is those same energy fields that I have rediscovered.
  • Iotayodi
    Good to see your still working with this Dave!
  • david lambright
    I have a new video on my YouTube channel that is alright, it could be better though.
  • Iotayodi
    i am reflecting sunlight off a CD....why? i don`tknow
    Lol!
    I would still try a prism with the separated spectrums.
    I use an old color crt monitor to check remanence on rods. Might be interesting to see what the wheel and tube patterns look like on it.
  • david lambright
    https://www.youtube.com/watch?v=ml_anVVlYAg check this video out
  • Iotayodi
    Dave heres a prism idea. Take a right angle prism,or equilateral, and use a white light source or even the sun to see any possible interactions with the individual spectrums or frequencies. You could also try the laser to it.
  • Harvey
    Originally posted by david lambright View Post
    laser video # 1 - YouTube this video is crude at best, but please check it out
    This may be caused by your heartbeat which slightly deflects the beam by changing the pressure in your arm, hand and digits.
    Try swinging the laser on a pendulum instead
  • david lambright
    new video
  • Harvey
    I agree with David here - the attraction could be quite small so a very sensitive scale may be necessary.
    Then we also have to ensure that the device does not act as a squirrel-cage fan creating a suction in the center that would draw the crystal toward itself by air pressure.
    I had envisaged a balance beam (easy to make with a bag of sand, a fulcrum and a stiff pipe or conduit) that would have one end hover above the device. Then it is just a matter of sliding the device under it and starting it spinning - but then I realized that we have to address the air flow . . .
    . . . perhaps a plastic sheet between the two to block the air flow
    The fulcrum can be a hanging wire or fishing line; or even a knife edge under the pipe.
    Accurate to one grain of sand
  • david lambright
    curious one
    it is not that easy. how long did it take me to finally get good images of the the visible distortion that i see? i will find a way to demonstrate the weight reduction i feel. i will not rest until i do
  • curious one
    David I watched your youtube vid with a rock you said was levitating. If so all you would have to do to demonstrate this would be to hold the rock above the generator with a spring scale attached, even a fish scale would work, if gravity was reduced on the rock weight on the spring scale would decrease.
  • Iotayodi
    Thanks David!
  • david lambright
    Fe3O4
    alpha chemical, black iron oxide, Fe3O4. the rock has shell fragments, sedimentary i think. if you make one, energize it like a PMH, and you will see what i have been talking about this whole time.
