gravity waves found
  • david lambright
    hi
    ....i was using a small piece of calcite and what i feel now is similar to 2 opposing magnets...holding the calcite about 1/4" above the HDPE center...when i feel the push, i keep it in the same spot and the effect starts to grow, it pushes back harder....i cannot tell if it is being pushed or like Ed said about it being magnets that control muscle contraction...in any case it is a very strange sensation....the calcite splits light into 2 streams..Ed did say the streams had to be divided...and then run them against each other...that makes sense with what i have felt...with a convex mirror at the plane, i feel a pushing .but it is so small... just a part of this energy can be reflected...just as X and other waves penetrate materials, i believe this energy will do also..if the streams can be separated using calcite that would be interesting... to separate the N and S into streams, the PMH is used....gravity and levity are like a vortex to a point to vortex...temperature is the zero point ..the PMH is also at that point. ..lets say N = levity, S = gravity...L and G can only go one way so reversal of the polarity at the point and changing the dominant stream of magnetic current, with the PMH...is the how....when a PMH is energized ,an orbit starts...ring the bell a second time and dominance is reversed....if the dominant stream has been reversed properly, the PMH acts as the zero point ...now if the PMH is spun, the gravity does what it knows and goes to the plane but now its carrying the N ...and, levity at the pole and S...any pull of G + N results in a S + L push...these streams would prefer to travel in the metal....so put a S magnet at the plane, just like in the photo of Ed, and spin the device so gravity and the N at the plane...levity and S at the pole that can now be collected at the wire above the device, flowing upward [like heat convection] into the mass above...as the magnet and the rotor pull N and gravity, S and levity flow up the wire , from above the generator, to be used at the quarry..the S being attracted to the north, flows into the stone bringing L with it...i believe that weight, as we experience here on earth, is due to the gravity to levity ratio...this can be changed .every thing has a zero point...at the quarry, the wire that comes from the mass above the pole is copper...steel, i believe was used to cut the stone, but i think the wire was connected to the flat bar he used at the quarry...i also think that because the S attracts N. the flow of L+ S from the tool softened the stone making it easier to work?.......i am pretty sure that this is how it was done..... i have found that the PMH is multi functional and ...i want to prove that this, how Ed .built his castle....david
  • Van T Stride
    Replicated
    Originally posted by krzysiek View Post
    So, do we have any other people, in the past 60 pages or so, who have replicated this and felt / seen the same effect?
    I noticed one guy who got it from David said he did see/feel a small effect and he son and wife saw it too. Any other stories like this?
    As I stated before I felt a very similar push on a stone suspended over a spinning PMH (a simple circular / ovoid shape). I used a drill to create the spinning force in the vertical axis, and could see - barely - a glimmer as David described. I don't think the digital video I have seen on Youtube does it justice.
    What is needed is to observe the PMH / wheel from the side, and focus the eyes well beyond it, say 10-12 feet, and observe the upper edge of the device as it comes in close contact with a stone. David is using a (quartz ?) geode. I'm using a heavy dark-green (serpentine? ) crystalline stone. I have tried Quartz but have not had great success with it (so far) in my attempts - just bought a piece of Rose Quartz that I will be testing with. I don't have any quartz geodes. Tried an amethyst geode, but didn't detect the field with it. Planning to visit Dave at some point so I can try his wheel with the geode.
    Van
  • Van T Stride
    Disintegration of Magnets
    Hi. Recently I placed a small (alnico?) refrigerator magnet in physical contact with a locked PMH, and I think this may have caused the side of the magnet that touched the PMH to physically break-down?
    Basically this magnet was very small, might have been a rare earth magnet, I'm not sure, but when I took it away from the PMH the shiny metallic surface quickly began to wear off exposing the dull, grainy interior.
    I realize this is a not very scientific observation, but I'm wondering if others have observed similar results with composite magnets?
  • david lambright
    krzy
    so far their are at least five replications that have the same results ....but there are some who do not get results...i am compiling names and info, photos etc., and i will post everything on like 6 forums...right now, matt emery has the device that jetijs will get next...he should be done with it soon ?...i will inquire about that...this is important so thanks everyone for being interested...PS i do get sidetracked sometimes so bear with me please...david
  • krzysiek
    Forgive me, I saw this thread back when it started and read up to about page 15, but have since noticed a huge amount of posts made. I don't really have too much time today to sift through it all, but:
    Jetijs, it seems you were meant to get a working model? Have you received it yet or when is it due to arrive at your location?
    David you disappeared for a week it seems!
  • david lambright
    hi
    a new kind of visible radiant energy? i thought this post was pretty good.....david
  • Jetijs
    Hi David
    I was wondering where you disapeared
  • Harvey
    Originally posted by david lambright View Post
    hi ...i have done something interesting.....i was experimenting with some gold leaf and i succeeded in making it paramagnetic...i was able to pick it up with a magnet..this was done by putting the leaf between the junction of a PMH and energizing it...i left it like that a few hours and now part of the leaf sticks to a magnet...i am not sure of the impurities in my leaf....but in any case it worked.....david
    Someone suggested enclosing the metal with plastic prior to magnetizing it to ensure no microscopic iron dust is being transferred into the softer metal surface. That was back when we were doing the aluminum. I didn't try that. Plus, we wouldn't know what impact the extra dielectric thickness would have on the effect so it introduces a new unknown.
    But theoretically, the surface of the PMH and my magnets would collect those small dust particles and they could be transferred to the softer metal under the pressures applied by the magnetic locking.
    But magnetic gold certainly sounds interesting
  • david lambright
    gold!
  • david lambright
    hi
    i have been busy.....i will post the videos soon...david
  • Van T Stride
    @ David
    Lambright, you seem like a nice guy but you have been bumbling on this topic here and at Energetic Forum for a good part of a year with thousands of posts. I'm not sure you have much to 'boast' about as regards what 'your' device can or cannot do. Right now it cannot do a damn useful thing and you continue to play and post useless videos which don't really show the viewer anything...
    E-Goose...........sorry for wasting your time...david
    David-
    My whole reason for joining this site, and posting on this forum is YOUR work, not that of E-Goose or any other person. I saw your Youtube videos and had to know what you were up to - I am very interested in what Ed knew, and how humans can access that power for healing and for improving society. I don't fully trust any government or agency or instituion to disclose the information (if they had it - why on earth would they share it?) that you already know - and others will eventually stumble on to.
    I hope you will not let this deter you. I agree with E-Goose only in that I think your personal excitement over what you rediscovered, and desire to help others see it, has limited the discovery (up to this point). Hopefully all of us (readers of this thread) thinking and asking questions will help to draw out the truth of what Ed did with his wheel, and how we can make our own devices, too.
    Please read back over some of our questions on this thread, and help us (who are genuinely interested in seeing this info made public) test some of our ideas. I know you have many things you want to test, please keep the videos coming, and forget about any negativity you're getting from people who haven't personally felt the interaction between the stone and a PMH device.
    -Van
  • Aromaz
    @David, Jetijs & Harvey;
    do one of you have one the operating wheels of David on hand?
    I have a kind request, short test please - something is nagging.
    Van T Stride above is right; there were singing and sometimes an earie sound
    heard from E.L's place when he was working. Reminds me of the Tibet monks
    and their sound levitation of stones.
    Please try to use a microphone above or around the wheel; see if there is an
    acoustic/radio wave somehow involved? You might need to make use of an
    additional copper choke as pick up.
    would appreciate very much; curiousity can kill!
  • Jetijs
    If you wonder about star of David, then you MUST see Nassims video about sacred geometry. The star of David is a 2D representation of tetrahedron which is the base of everything. The videos are long, but very interesting and entertaining and leaves no questions unanswered
    (PART 1) Nassim Haramein at the Rogue Valley Metaphysical Library. 2003. (4 HRS)
  • Van T Stride
    What is missing in Ed's rig?
    I think Harvey has some great questions!
    If we consider that the form follows the function, then the clover-leaf shape on the top must do something. In my mind's eye I can imagine Ed's wheel producing something like what David saw - let's say a shimmering ripple of energy - that would either be projected upward or downward (as some have said... depending on the direction of rotation). Assuming that it's creating an "updraft" of this energy, the clover-shape (Quatrefoil) could catch some of that energy and create spirals, and eddies in the space between the wheel and whatever was situated above it.
    Most people who have read about Coral Castle come to the conclusion that Ed's device had one or more additional parts that were taken or misplaced. I have heard ideas such as a pyramid, but I don't think I beleive that - while a pyramid could sit on the 4 points of the "clover-leaf" it would be prone to slipping off, and the crank handle would have been in the way. I don't think his Castle contained any pyramid-shaped stones... that may be an indication of how his mind worked. I also wonder how the Latvian star or Mogen David may be important, since they appear in several locations and forms throughout the site.
    I have read that Ed strapped "bottle capacitors" (which can still be seen in his work area) to the wood bench next to the wheel, and used the rotating magnetic force to induce electrical current which he probably gathered in the bottles for later use (like a modern day rechargeable battery).
    I suspect that Ed's wheel had an audio component to it - I read somwhere that it "sang" or made a noise when he was using it. If the source of the audio input came from OUTSIDE the wheel, it could have been introduced by something as simple as a bronze bell. The bell he kept near the metal door, could have been temporarily suspended over the wheel and "rung" to create the addition of vibrational audio input. ("Ring twice.")
    PS. My Quatrefoil PMH design is about 50% complete, but I had a shaping tool break that is going to take some time to replace.
    -Van
  • Harvey
    If you look at the clover carefully, you will see that it is a leaf spring wrapped back on itself. The overlapping ends are in the lower left quadrant in the picture above.
    Also, you can see the wires that hold the clover to the stand bolts. At first I thought perhaps these were coils to energize the clover with, but in retrospect I have decided they are only to secure it. I base this decision on the nature in which the wire is twisted and terminated - it is a standard physical twist often used in farming and bale work. So I don't think they were there for electrical reasons.
    However, we cannot ignore the question as to why the special effort was made to bend the spring steel and form it inside the stand bolts, when it appears it would have encircled them fine with no extra work involved. Heating and bending this metal is no easy task, and the work involved intimates that the shape had some importance. Superficially, we could suggest that the bends were only to keep the 'ring' from slipping. But the shape (quatrefoil) itself is seen in freemason designs:
    +freemason +quatrefoil - Google Search
    And it has a very specific geometry:
    Could the 'Clover' in Ed's generator be 'PMH Locked'? From a scientific perspective the answer is yes. Any magnetic flux induced in the ring would remain in the ring unless the flux path were broken, even though the ring is not a real circle. Could the magnets themselves be 'PMH Locked' like David's rig? No. The reason is because the poles are inverted every other one and so the flux is countered. In David's rig, each element has a N and S pole, but the arrangement is N--SN---SN---SN---S all the way around. In Ed's generator, modern day readings show his magnets to be arranged N---SS---NN---SS----N all the way around, and stacked all NN vertically and all SS vertically five high. So I say with utmost confidence that Ed's magnets were not PMH locked. The PMH lock is no different than stringing a lot of magnets together in a circle - you cannot do that if the poles are inverted, the N must all face the same flux direction around the circle.
    Relativity:
    Once a magnetic flux is trapped in a PMH style circle, the question arises as to whether or not electrical energy is produced by that static arrangement. It is well known that 'moving' electrical charges have magnetic fields associated with them. Likewise, it is well known that if a magnetic field passes through an conductor, that it will induce electrical current in that conductor (provided a flux differential exists). But what if the flux is just there, trapped, static? What if the flux carrier (the clover) always moves with the flux, together with it - or does it? How would we know? Does magnetic flux have inertia? If we accelerate the flux conductor, is there a time lag for the flux to 'catch up'? And what is even more thought provoking; what constitutes 'moving'? These were the types of questions running through the minds of physicists at the end of the 19th century as the 1800's came to a close over 110 years ago. By the time Einstein came along in the beginning of the 20th century around 1912, work was already being done on trying to understand why electric and magnetic seem to be inexorably linked. The only thing that seems to make a difference is the point of view of the observer. Depending on the relative motion, one observer may see an electric charge and the other observer sees a magnetic field for the same event. Curious, that electromagnetic events seem to be relative to the observer. But could it be that there is an Aether that moves with the observers? Could it be that these events are relative to the Aether instead? A person being pulled along in a river by the currents may see a salmon swimming upstream and declare, "my look at how fast that salmon swam past me" - yet an observer on the shore my see the salmon actually swimming backwards as the current takes them down stream only because they cannot keep up. Without a point of reference, the observations can become meaningless. Perhaps we are like that person in the river and the Aether is moving us along at the same rate (or nearly so) as the Earth turns. So we 'think' what we see is because of us observing it, but perhaps the action is relative to the Aether, not us. Maybe we can 'stand on the shore' so to speak and see what is really happening.
    When Ed would spin his generator, the flux trapped inside the clover does not follow a continuous path, but instead it oscillates in and out from the center relative to the Aether. Personally, I believe "the Aether" is nothing more than space-time but that is another story, it can still be treated as a referential point like the water in a flowing river. Our problem is that there is no shoreline in sight, nothing to use as an overarching anchor. Nevertheless, let us suppose that the flux inside the clover begins interacting with space and time because it is both moving and migrating. If there is an inertial component (and I think there is) we may find an electrical charge formed in the material relative to Ed (and the Aether in which he stands). How could we test such a hypothesis?
    If two U-shaped PMH were 'locked' and suspended by some non conductive thread, and then caused to spin on that thread, would the material become charged? What if we spun them in opposite directions and then measured them with a voltmeter with one probe on one and the other probe on the other - would it show anything? Is there a minimum size or specific shape required to produce good results, if any?
