gravity waves found
  • david lambright
    sorry, i meant like digitally overlay a pix ..schlieren, with the same shot but using pinestone, of my device....to see more of whats going on.....a girl asked me last saturday, "what were you pouring out of that thing"....it does look odd for sure..[quartz+rotor+energy wave] any insight or ideas you want to share....no matter how "out there"or small it may seem, and the ones you know are good, are welcome in my ears!...we have never met but you are my friend....when we take what we know, use that to make new discoveries, ..then the only limit is our imagination...........joking with misty i said "i imagined all of this into existance" ....but it is true!...david
  • Harvey
  • david lambright
    model..
    what would we get if we over lay pinestone and/or magnetic warp, and/or schlieren etc,...what would the model look like?...david
  • Harvey
    Harvey,
    Thanks for posting that video.
    One of the best I have seen presenting the Schlieren technology yet!
    Do you have a similar source for "seeing" magnetic waves?
    IndianaBoys
    Your Welcome =)
    The best I've seen yet is the Pinestone apparatus:
    http://s81.photobucket.com/albums/j213/pinestone/?action=view&current=flux.jpg&newest=1#!oZZ1QQcurr entZZhttp%3A%2F%2Fs81.photobucket.com%2Falbums%2Fj 213%2Fpinestone%2F%3Faction%3Dview%26current%3Dweb addresstag.jpg%26newest%3D1
    For some reason his website has been taken offline and I can't find the kewl you-tube vids he once had up. But here is a link to some of the vids:
    Magnetic Warp (Three Magnet by Hand) | SciVee
    To see waves with his device would require an EM signal of reasonably large magnitude and low enough frequency for the oils to respond - but it does work well with magnets, and if you motorize a magnet you could probably test the frequency limitations.
    Ah I found it - it was sirzerp, not pinestone channel =)
    YouTube - SirZerp's Channel
  • david lambright
    harvey...
    thank you so much for getting this new technology aimed at all the applications this will advance also if you are getting those effects try the steel above the device...there is a point of "lock", for lack of a better word, at about 10 degrees off axis, north...this lock provides the best visual distortions....all the links you post are the sciences that will be affected / will affect this new energy... ...david
  • david lambright
    Harvey,
    IndianaBoys
    i would like to see that also...david
  • david lambright
    energy plume?
    the image testing so far show a definite energy plume coming off of my device..the videos are done with a 4" mirror! the vids show barely any thing...more vid soon
  • IndianaBoys
    Thanks David -
    Also here is a very good video describing the Schlieren stuff I thought I would share:
    YouTube - Schlieren photography of moving air
    Harvey,
    IndianaBoys
  • Harvey
    Originally posted by david lambright View Post
    you can see a flow at the upper left....you can see one of the zip ties on the side of the device..this was done using ians method, with a 4" mirror....ian uses an 18"....24 might work better...i said that before....greenpowerscience mylar+vacuum method ....that would make things easier...more soon...david...YouTube - schlieren & ian...thanks...
    Thanks David -
  • SuperCaviTationIstic
    You won't get much gravity effects until you spin the wheel with 2 bucking fields concentric to it, preferably in the middle. You need pulsed DC into the bucking coils with it spinning. a rotating magnetic field plus a linnear bucking field(preferably with a capacitor plate on each end connected to each coil) is the standard recipe for a wormhole. All the extra energy that Leedskalnin, Tesla, Schauberger, Stan Meyer and others used was energy from hyperspace accessed by a wormhole.
    If you don't believe me, perhaps you will take John Hutchison's word for it.
    When he made a working model of the ARK OF THE COVENANT, it created a small wormhole through which angelic beings came and went. These are his statements.
    Ark of the Covenant
  • Stealth
    Light
    Pure white light is made up of 7 different colors,7 different wavelenghts,7 different frequencies. You can see these after a rain,when the sun shines. It is called a rainbow.If you change just one of these wavelenghts, or frequencies, you can change the properties of light.If Dave's wheel is capable of changing gravity,more or less, then it may be capable also of changing light, or at least the way we see light. I propose that gravity does have an effect on light. Antigravity should make light invisible,at least to the naked eye.Gravity itself is not visible,neither is magnetism. These are wavelenghts far beyond our vision.I would ask David to use a fresnel lens above his machine to concentrate the light and possibly intensify the effect. This should either rule out light distortion or positively identify it as such. If you don't have a fresnel lens, put some water in a clear dish in order to view it from above.If it has no effect on light,then you may be dealing with another phonomena.Good Luck. Stealth
    David,
    Please research existing technology dealing with Gravity. A great place to start is John Quincy St. Clair john quincy st. clair - Google Patent Search
    Most devices by St. Clair and others have a few common themes. Bucking coils is one of them.
    Please also look into Ley lines.... They show how the Earth's magnetic field is really constructed. Along the way you'll find how gravity actually works. It's a reuniting of Magnetism and Electricity where they no longer occur at 90 degrees to each other, but rather are are 0 degrees off.
    Also, modern science is using this same design...
    look up Superconducting Gravity gradiometers
    they are used both for gravity detection and.....guess what else................
    brain activity mapping. Yes, our brain waves ARE GRAVITY WAVES
  • david lambright
    i like your descriptors.....i dont know if i said that right?...david....PS...new vid...YouTube - ian & schlieren
  • david lambright
    jet..
    how are your projects coming ...i have heard that others are getting results?...i know the ferrite thing works ...has any one got anything,elect., out of it yet?...i think someone else has but is keeping it low for now?...you guys are great...thanks for letting me post on your forum....thursday is coming.... ....david
  • david lambright
    terms...
    magnetic lock;..as in locking a PMH ..... energetic wave;.. the wave form seen distorting either light, space or air..... i know there are more words we have been using to describe this new energy.....what words do you want to use for ease of understanding.........david
