  • Dwane
    Hi guys,
    I like maybe a lot of others did not look hard at the Bridge at first glance! It is only when looking closely you realise that one side - negative - is getting ac. Would this be related to William Lyne's comments?
    These are nice bid Diodes, does anyone know their product number?
    Edit: I suppose what Don might be saying is that his method of extracting energy is to break through the harmony of the earth connection and it's balance with the electrostatic field. That is "+=-", disrupt this equation and there is an imbalance.
    Dwane
  • ilandtan
    Right, the schematic with not-correctly placed diode in diode bridge ? I don't know if it's a working device but I must reflect here many statements which are important. For many devices described in newspapers there is a note that electrician or scientist examined device and they said : it's impossible to be working that way. Like for example two coils completely not coupled inductively or diodes in wrong directions. You can find the same in Richard Willis patent.
    The energy that comes goes "the wrong way around" - that's that problem for all replicators, because excess energy is coming from other source.
    I saw that diode, LOL maybe he's telling us that the function is not a typical bridge. Don on one of schematics, said throw away the L1/L2 in the diagram, all you need is a disconnected negative output of the bridge (so it doesn't matter which way that diode points) He just uses the positive output to the cap.
    Don Smith: Bruce,The Device in question is the same one I demonstrated at the Tesla convention 5 years ago that caused such a ruckus. The Inverter circuit already has the necessary components required. Disconnect the main diode bridge negative output from the output capacitor bank. Then hook the disconnected negative capacitor to a separate circuit which powers the load and into an adjustable earth grounding. At this point you are tapped into the universal source of endless energy. There is a simple way which does not require the inverter. Any how let me know and will work it out. You already have all the required parts as does most everyone else.
    Regards, DS
    07-23-2004
  • Elcheapo
    my guess
    ilandtan,
    All I'm saying is that resonant circuits are the most practical and efficient way of obtaining the HV that we need.
    Everyone has a different idea as to how this system is supposed to work.
    My own guess is that the extra energy is the aether waves as described by Tesla.
    Our scientists call them neutrinos. So small that they can pass through steel.
    Mother nature always tries to keep things in balance by providing as many of
    these positive charged particles as there are negative ones.
    We need to upset this balance in order to bring some of these charges into our HV circuit.
    We can do this by creating a disturbance by sparking HV DC through a spark gap.
    Using a positive dc will attract the negative charges while using negative dc will attract the positive charges.
    There will be an attraction for each half-wave pulse coming through the spark gap, so
    the more often this happens (called frequency) the more energy we get.
    And the higher the voltage, the greater is the attraction as well.
    It should now be clear that we should only be attracting the positive charges
    as these are the ones which will flow through our HV circuit and back to negative ground which will put things back in balance.
    This current flow will be a combination of electrons (from our power supply) and neutrinos.
    If we could attract only 1/4 amp into a 9000 volt circuit, we'd get out 2200 watts of power by using a step-down transformer on the output side.
    Just my GUESS
  • ilandtan
    Originally posted by Elcheapo View Post
    Look at the bottom left of the picture and you will see a highly efficient
    toroid coil!
    That looks more like the output transformer for me. He's got the DC from the cap and he is pulsing the toroid with the black box controlling the gated thyristor. In essence that left module on the wood is transformation, basically the inverter to 60 Hz AC.
    EL, I'm not disagreeing with what you are saying, just to disagree. We have like 400+ pages of forum, that have the well traveled and worn road of resonant coils producing the effect. I'm offering other thoughts outside that box, because the road seems a dead end.
    I certainly don't know... but boguslaw does. Listen to him.
  • boguslaw
  • Elcheapo
    Originally posted by ilandtan View Post
    I'm saying the same thing. Why make assumptions when the evidence is to the contrary?
    Where are your coils here?
    toroid coil!
  • ilandtan
    ilandtan says" what really is important?"
    If you're trying to get a cop>1 then efficiency is very important.
    An nst rated at 4000 volts and 30ma is using 120 watts of power!
    When I drive my coil with just 10 watts from the old ham rig, I get 9000 volts out.
    (No,don't go buying a used rig as there are easier ways to to it)
    It's the resonant circuits that creates this efficiency, so we need coils to do it.
    Don had the financial interests of the investors to contend with,
    So everything he says should be "taken with a grain of salt"
    We should just be using our own brain to work things out and use just some of Don's theories that make some sense to us.
    We need to start by understanding how the system is supposed to work, and where the extra energy is coming from.
  • Elcheapo
    Dwane,
    Yes, that resonant input power is the way to go.
    Keep going, as you're on the right track.
  • Dwane
    1/4 wave
    Hi Elcheapo,
    Have just done the Don's resonance calculation with my ilantan replication. I am getting 584Khz from 234/397 feet. The frequency when running was showing up on the scope as 585Khz!. Amazing! I wind my coils by even weight!
    Thanks for the tip on resonance. I completely missed that with the corona discharge. I do not think in all of the papers I read, trying to get a handle on the process, was there once any mention of a resonant power supply. This is why my Tesla coil is coroning and the Mazilli is not. Somewhere new to start!!
    Once again many thanks.
    Dwane
  • ilandtan
    It may have nothing to do with the coils
    Hi Elcheapo,
    IMHO it may not have anything with the front end resonance. He eliminates the L1/L2 coil entirely in at least three different devices.
    • The "Commercial" with just a 60Hz NST to Diodes and Dry-Var Caps
    • The "Coke Machine" device; 12V NST to diodes to cap
    • The Tube Plasma device
    So if he created devices without resonant exciter coils... what really is important?
    I am starting to lean towards the resonant iron core primary, with the shunt variable capacitor/resistor to Earth ground. Don says in the 1994 video that the shunt dams up the energy. I imagine the capacitor and the primary oscillating to the standing wave, and radiating electrons continues to pump in from the ambient, like a whirlpool, and the drain is the Earth ground. So with the same analogy, too big a drain and the Ether flows to Earth nothing being harvested, just enough drain and the movement churns the magnetic Ether, which is basically flux, which can be converted to real current.
    My theory anyways...
    Don says the iron core is where over-unity happens.
  • Elcheapo
    quarter wave-length
    Hi guys,
    Glad to see people still trying to get things working on this thread.
    I've been doing some experimenting also and imho high voltage and radio frequencies (mhz) is the way to go.
    Remember that Don said " Doubling the voltage or frequency will quadruple
    the output"
    Don't see much talk here about 1/4 wave resonance.
    This is very.very important as I will give an example.
    I wound a single layer coil with 400 turns of #30 wire using a 1 in.diam.pvc coil form about 6 in. long. Wire length was 110 ft. 234/110= 2.1 mhz. as the 1/4 wave-length.
    Remember, this coil type has 2 resonant points. one is the 1/4 wave point
    and the other is the self-resonant LC tank frequency that uses the built-in
    coil capacitance.
    At the coil base was a loosely coupled coil of 6 turns. One end grounded and other end attached to output of an rf generator.
    Bottom end of hv coil also at ground.
    Top end of coil was connected to a hv rectifier with a 1000pf bypass cap.
    I then connected a volt meter to the output of rectifier.
    While watching the meter, I adjusted the generator freq. for maximum output. Output rose to a maximum of 195 volts.
    I again watched the meter while adjusting the freq. to see what the lower
    freq. of LC would be.
    I got maximum output of 9.7 volts at 740khz.
    Both readings using 1 volt output from generator.
    Hope this info might help somebody.
  • Dwane
    Corona
    Hi guys,
    In one of my previous posts I posted a shot of the corona coming from the end of the Tesla coil. I am setting up a corona discharge contraption for charging some material and subsequent tests. I am using the well worn Mazilli
    circuit. At the tip of the positive output, I am not getting any corona. I am at 12kv on my Beckman probe. But, I am getting a cold wind of sorts. Curious. Should I be using my Tesla coil as the source for the charging? Also, as I think I should be using the ionised air about the pointy output, should I put a capacitor in the circuit for current into the corona?
    the problem I see, is when reading technical papers describing the corona process I get mixed signals. Some say current, when I thought they should be saying voltage. Others say no current as this will kill the charge. Others have said you need current to encourage the mix!?!?! I am of course, looking at older papers for general information opportunities. Newer papers have moved into a whole new realm and exotic doped materials aiming at specific areas of industry.
    Dwane
  • Vinyasi
    Not good for powering an EV at these frequencies, but probably good for a UFO
    Rick definitely fails English Communication 101 class. Where plain, to the point wording is the goal. I think if Rick knew how to actually make a DS device, he would be able to give the recipe in a one well written paragraph.
    Rick does post these videos of Don, and I didn't realize they were available. We can thank master yawn for that.
    Don draws step by step through one of his devices in the 1994, and I realize that I haven't been building the harvesting side.
    [VIDEO]https://www.youtube.com/watch?v=BHr3eDELyHk[/VIDEO]
    There is also an actual hand drawing of the device that Don's help failed to fire up in 1994 at energyevo.com, and you realize why it didn't work right away.
    Also look at the 1995
    [VIDEO]https://www.youtube.com/watch?v=_8JwIlHLOUI[/VIDEO]
    My simulations of simple step up transformers in three distinct softwares: Micro Cap, LTSpice and numerous derivations of Paul Falstad take a drastic nosedive whenever I steer away from the magical frequency of one mega hz, higher or lower.
    William Lyne's thesis in his "Ether Physics" paperback on his theory and exposition of Tesla's UFO technology starts making sense when I consider the ridiculousness of powering an EV with this frequency.
    Thanks for these video links. They made my day!
    I stand corrected......
  • Dwane
    Black on black
    Hi ilandtan,
    In my dreams, I thought Rick was demonstrating his Tesla knowledge! He was using black to limit the reactive light on his sodium selenosulphate coated coils? Too much for me. Extreeeeemely toxic to use. But, if caution is the word of the day, a very useful compound when painted black!! Was it Einstein's Black Body radiation treatise? Completely different and off topic.
    I am back to where I was about 7-8 years ago when looking at this area. Very frustrating. Making samples that do not work!! I am going to concentrate on polypropylene as this is a recyclable polymer. Melting point around 100C and susceptible. Greatly reduces toxicity!!
    Thanks for the extra videos. I did look at Rick's online store and noticed a few references to the Don's videos', but thought I must have them. Obviously not. Maybe I should email him for his FREE copy to read his video?Perhaps the best videos I have watched are those from "The Old Scientist" I think he must remove them from time to time as I went looking for an excellent short video on Resonance. You know, 5 minutes as opposed to two hours!!! Professionalism at its best.
    I will view these tonight. Have the electrician coming in today to finish off the roughing out of the wiring. Then I can put the floor down, Plumber has done most of his roughing out. With the floor down I can get on with making the window frames. This particular building has taken its toll on me.
    One final thought. Tesla's aerial collection system. Could his collector plates have been coated with a Se compound, do you think?
    Edit: I will make comment on the usefulness of Sodium selenosulphte if used as a collector and that is 24/7 collection. It will harvest the UV component which can be reduced to DC! Better than Solar Panels?
    Once again thanks
    Dwane
  • ilandtan
