  • Dear Mr Clean.
    Following my insight upon Don Smith's device, I'm so curious that Farmhand could develop
    -THE TRICK IS NOT IN THE SPARK GAPS !
    • Originally posted by mr.clean View Post
      hehe distracted? i need to be doing multiple projects at once, so when my attention nods off, i can go to the next and stay interested, otherwise i'd never finish a single thing
      but by ferrite rods maybe the LMD analog? those rods are .5" dia 3" long, from Digikey i believe, comes in a huge box of like 100
      coils were wound end to end, 30 gauge mag wire, then measured to find lowest inductance, and removed turns to the rest to make them all 2.133mH and all same direction (the coils will find their own polarities in the process)
      As for the Smith build, in case of plain ole good info..
      -copper tubing for primary (but it was an old coil, used it cause its dia and turns worked out, but was CCW) shouldve been same direction as secondaries (to my knowledge)
      -B&W coil cut in half (didnt have the 4turn/inch so bought the 6 turn/inch)
      better inductance anyway
      -avoid large capacitances, as Don used, based on projects Nemesis, and Zeus popular Tesla coils a huge amount of info was documented and referenced to Colorado Springs notes as guidance, along with conventional transmission line theory being possible. the intention was to construct ~the Magnifier~ but not to follow anyone elses notions on wireless power or vindication of Tesla even...
      ....it was for unravelling the operation of the Magnifier, and MAX terminal output
      PERIOD
      ..."when larger primary inductances are used, more tolerable caps can be used at smaller capacitance, and massive secondary inductances can be brought into play..."
      i weighed the coils to get an idea of needed primary tubing, then compared the lengths, actually wasnt far off from 1/4, but as discovered from the above, systems can be far out of balance and still work if compensated with small enough capacitance
      --and that the spark rate is a small fraction of the tuned frequency (not in most people's ability, unless rotary gap) so im just saying go as small L1 capacitance as you can without having to modify your coil too much
      -dont buy huge output storage caps like Don did, yes they fill right up but just tuning caps where needed and maybe diodes just before load, to act as kind of a resonance barrier in a way, or your tuning will tend to change with different loads. you generally dont want anything robbing power, and untill the big output caps fill up, a load cant be placed onto them ive found.
      gotta run, hope that helps
      Hi Mr Clean.
      Thanks for sharing this
      I see that there is a bit of a spark gap topic I have found some useful information about spark gaps on these sites, I hope it would be helpful.
      Multi-Spark Gap Experiments
      Electrical Discharges
      Best To all
      • Originally posted by African View Post
        Hi Mr Clean.
        Best To all
        Hello African,
        Clarence ,
        thanks for that info you posted, I definitely saved those items! and my personal search (me) immediately virtualized one of DON,s photos from some ones past posting ( I believe it was listed as photo C34 ) which showed TWO GDT spark GAPS attached to his demo device terminal strip for that device!!! I wish I could remember that posting so I could re-save that photo back to my pc!
        All of this was interesting since the GAP experiment showed that the two combo spark gaps VS the single or three gap config. gave the way higher COP value!!!! (gigantic higher).
        thanks again, mike, onward!
        • TMT tuning vid
          hi all quick update on the Magnifying Transmitter
          TMT: Tesla Magnifying Transmitter (Pat #1,119,732) - YouTube
          -Shunryu Suzuki
            Hi Mr Clean.
            Best To all
            hi buddy, yes ive seen this document, and it looks really good,
            but im curious, wouldn't Intalek be pumped to hook up multi-kilo watt lights to really show the output?
            I do think spark gaps are important, and I do hope this is true
            thanks
            -Shunryu Suzuki
            • Pulsed DC to AC
              Hi All,
              Just remembered one of the circumstantial if not direct evidence of pulsed DC to AC by Don Smith himself.
              The Intermediate Device with the adjustable L1 illustrates this beautifully.
              Pulsed DC to L1 and fullwave rectification (of AC current)at L2.Yes, as you know, diodes on both ends of the coil and the centre tap. Good stuff!
              Ged
              • Spark Gap Power
                Originally posted by clarence View Post
                Hello Deggers,
                @Gedfire,
                OOOPPS!- forgot to say that true to DON'S style he did not show the spark gap (GDT) in the center terminal connection inside the toroid.
                @ALL - cheers
                cheers, mike onward!
                Hi,
                Loved the discussion re: SparkGaps in the subsequent posts.
                However my main question may have been unanswered perhaps because of how I stated it.
                I am curious as to the use of the SparkGap in this device.In this case does the Spark Gap also act as a voltage limiter?
                To answer this I went back to Don Videos,
                In the 1996 Conference and the Interview Video where he tells how to build a device, he does imply another use of sparkgaps as voltage limiters.
                I am theorising that Xrays are one of the components in SG discharges that does stimlulate electron flow in metal.Maybe that was why Tesla had an Xray tube stimulating a shiny insulated metal in his aerial device.In fact I plan to try just that many month from now.(Yes,I will observe the precautions).
                At Xray frequencies I can imagine the excess power gained compared to Radio Frequencies.
                Ged
                • Not only XRays, but all frequencies above the UV are eligibles, the higher frequency, the higher energy.
                  Placing the gap nearby the secondary coil may reinforce capture and increase the efficiency. Don may have found this point experimentally by practicing. Nevertheless, all these clues seem confirming the theoretical insight about photons creation triggered on by an abrupt dU/dt.
                  • Spark Gap Power 2
                    Thanks for commenting and I agree 100%. Don had the Gray tube illustrations in his archives.The Moray Valve may have operated on similar principle using the sparking capacitor.
                    Ged
                    • Originally posted by quantumfuel View Post
                      There is no OU in this : you can also place a RF transmitter and a set of receivers and by recover part of energy spent by transmitter you would state it is OU....I saw that kind of effect with Katcher Brovin circuit when all around is full of electrostatic charge and I can recover part of energy with Avramenko plug back to power source (battery) : current consumption fallen a lot but it was still far below COP=1
                      • OK, let's restart from the beginning.
                        I don't reinvent here RF emission, I'm not at this level of gullibility.
                        You misunderstand because so-called photons at RF level are no particle but just regular spherical waves. Furthermore mainstream physics hasn't understood this fundamental difference.
                        What does an abrupt dU/dt is to provoke aether compression waves (variation of the local permittivity). Compression waves are the kind of waves that serve as TEM wave reflector and that catch inside the ambient ether waves. The ambient waves are those evidenced by the Casimir force and also those that correspond to the ZPE.
                        Therefore, you have a net matter creation upon space under the form of high energy photons. Just capture them back and you've got OU. Theoretically you provide one 1/2h.nu per photon and space provides you the other half.
                        • Thought Experiment
                          While we are on this may I hear your thoughts on the following experiment:
                          Using a very still pool of water.Say 5 feet in diameter and 2 feet deep .I install several miniature linear wave generators.Say eight and put them in an regular octagonal formation say 6 inches from the centre of the said pool.I then rhythmically disturbing the centre using maybe, a tapering pendulum suspended at the end of an elastic support.Now I am taking to care to use the least energy as possible and also "tune" the "pulsings" to not oversplash and to not break the elastic support.
                          Given the linear wave generators are made from the best conductors, wound bifilar, have strong neodymiums, and have sufficient surfaces exposed for receiving the incoming waves would it be feasible that you may get more out than in?
                          Thought experimenting.(Yes, I know, I would do it myself if I had the time and resources... )
                          @Quantum, interesting expansion on your orginal post.Lets see where the discussion goes next.
                          Ged
                          • Crowd Fund For Don's Tech Peek
                            I'm sorry if this seems a bit criminal but,I wonder if we could crowd fund a careful
                            techy on a trip to Japan to take a video peek into at one of the vending machines
                            Don's powering with one of his devices? It will be the one that's not plugged in.
                            • You got it dude!
                              Very nice and detailed explanation of what really is happening on tesla coil. Many thanks.
                              • Tx Stupify12 and others.
                                I published more detailed explanations in French here.
                                I also have its English translation, just ask it.
