  • Bodkins
    Will done Aromaz really like the idea of the ground triggering the transistor. Potential in the the planet is big and we are just scratching the surface, Please Amoraz can you put your scope on your ground and check the signal and frequence just maybe if you match it things May start happening.
    I will try and redo some experiment that have given me spark coming from the ground.
    @Nat this is the brick one
    Lokke
    been reading the Biefeld-Brown Effect i dont now if it is or not but what i think is that the HV only plays a small part in the lighting of the bulb because without the bulbs the amp draw is the same
    @Ren i aggree i dont think its resonance effect but if we get resonance with the planet it will be?
    quote ren
    there is one element in the simplest tesla coil that most of us here still arent using in our builds.
    Im trying its blood hard
  • ren
    Originally posted by Inquorate View Post
    Wanna switch off on but with huge power input?
    This is what I'm getting nxt week on payday..
    Jaycar Electronics
    Jaycar Electronics
    Hmm, Aussie?
    @ Aromaz, Teslas photo in his lab was a double exposure Im pretty sure. There is nothing safe about Tesla coils at all. Sure if one understands the HV/HF one can protect oneself in various ways, but there are plenty of things that can go horribly wrong! We are dabbling with HV off the ignition coil, but not enough current to do much harm. Still enough to burn you if you are its path to ground, I had a few blisters from that.
    1 transistor can be done easily, you've picked up that a quick kickstart can get the thing running in a self-oscillation mode. At the beginning of this thread we utilized John Bedinis circuit in self oscillation mode with an extra coil and the ignition coil in parallel with this coil to get a continous oscillation. Look at this post here http://www.energeticforum.com/renewa...html#post27291 and you will see what I am talking about. The ignition coils primary is in parallel to the power coil.
    I only say this to better your education, so please dont take it the wrong way. You should look up resonance, learn about the conditions it creates, what influences it etc. I hate to say it, but I dont think any of these builds are truely resonant. There is the nature of oscillatory systems, and then there is the nature of resonance. Tesla coil builds (like the musical ones posted above) will teach you all about resonance, there is one element in the simplest tesla coil that most of us here still arent using in our builds. Look up LC circuits if you are interested... here is a start: LC Oscillations and Resonance Alot of resonant pages talk about AC resonance, but there can be resonance in a DC system too.
    Regarding 2n3055. My setup wont work as well with other transistors, even MLJ21194. Seems there is something in this little gem. I also found that with the darlington configuration I could place the MOT coil in the negative leg of the circuit and get results, without the darlington I couldnt. There is something in that darlington configuration (2n2222/2n3055 or in my case h11d1/2n3055) that allows the coil in the negative leg, and outputs light.
  • Inquorate
    Valves
    Jaycar Electronics
    Jaycar Electronics
  • lokke
    Hello all.
    I have followed this thread since the start.
    I wonder hmm.
    It might be the opposite of the Biefeld-Brown Effect we see. But the energy is coming to us instead of vice versa. if you understand what I mean.
    Excuse me, I find it difficult to write in English. I have tried to use google translate. But it is still not quite right.
    The main thing is that I understand what you write.
    Thank Aromaz, Lidmotor, Bodkins, Nat and all the others. which allows me to imitate your experiment. Thank you also for all your educational videos
    Lokke.
  • Lidmotor
    One transistor is doing the JOB!!!!!!!--Aromaz 12/2/08
    Aromaz-- (1) 2n3055 GREAT!!!! Everybody should watch 16b and then step back and ask yourself----What the heck is going on here? Now what?
    Lidmotor
  • mlurye
    Here is what I'm planning to test today. I will use 2 MW transformers. Any thoughts or recommendations would be greatly appreciated.
    Aromaz keep trying And we'll get there.
  • Aromaz
    YouTube - Aromaz 016a - DRE changed or shoot me!.MP4http://ca.youtube.com/watch?v=rbFKZNJBunk
  • Aromaz
    Do not depair,
    Nice learning experience but fart and it turns off.
    Searching a great many hours on the net for an oscillator that can generate a signal for transistor - that won't blow up - has led me to this page.....
    square wave test signal generator
    Hold on, sit down get a glass of cold water.
    I was wondering if I should or should no upload now. 016a and 016b
    My next video's will shake you like a quake.
  • Inquorate
    This system too damn touchy.
  • Inquorate
    Got it working!
    I scrapped the 2n2222 (a) and put imhotep fan - oscillates at 99.9 hz - and ground wire on base of 2n3055 which runs 3 Tip35c's, and she started! Then I took fan off base and she kept on going.
    Maybe the parts you guys using have already been 'conditioned' by radiant energy?
    Mine ran erratically, chewing .3 to .4 amps, made voltage supply jump from 11 to 14 volts, oscillating between 1000 and 1500 hz.
    After an hour, running at c2500 hz and only using 1/4 of .1 amp.
  • elias
    Thanks!
    Just jumped in to thank you for making this document, it really sums it all/ up! I have not been able to track the thread for a while and this would be quite useful.
  • Aromaz
    Tesla Coils on a lighter note
    This is something to appreciate.
    YouTube - Tesla Coil Concert!! University of Illnois..
    YouTube - Ghostbusters on the Giant Singing Tesla Coils
    YouTube - Dr Zeus w LightSabers vs Twin Musical Tesla Coils
    Shows you - Same thing, many ideas and many uses!
    BTW! Not the Faraday cage / protective armour around man between coils - look carefull !
    Though impressive, this is not the 'real' TESLA coil. The real Tesla coil was in his Colorado workshop
    and when in full operation he was sitting in the middle of the thing, sparks all over - and no harm.
    Or is it that I understand so many of his writings and lectures wrong?
    THAT my friends is what we should target, in Master Tesla's word "Safe energy" meaning it does
    NOT shock, hurt or kill - can safely be 'transmitted' in unlimited quantity.
  • stringguy
    Aromaz, video13, very very good indeed. to be witnessing you guys on the edge of this huge discovery is just great. well done indeed! it sure gives one hope for the future.
    thank you
  • Aromaz
    Excellent
  • ashtweth
    PDF updated with all latest results any probs let me know
    Ash
