  • Bodkins
    or half it
  • Xenomorph
    I will repeat the experiment (if the circuit will react in the same way again, you never know hehe)
    and try doubling the salt like bodkins suggested.
    Shortly before ending the experiment for today i have also put a water glass with sugar inside next to the coil and it seemed to have the same effect as the salt.
    I also wanna see what happens if i use inanimate organic "material" instead of my hand to touch the bulb, for instance a piece of steak or so.
    That would prove that the effect is dependent on a quality that only animate beings have/emit. (radiant energy field in humans).
    I will ask my girlfriend when she will be around to touch the bulb too and see if there is differences between individuals.
    The thing is that i have a 2nd degree in the radiance technique which is also called Reiki, so my hands automatically "create" radiant (healing) energy when i touch organic objects (according to the books) and this might influence the effect on the bulb somehow ,who knows? I want to investigate that possibility.
    I remember luc pointing out in one of his videos that the injury that the radiant energy burned into his finger healed amazingly fast!
    "Maybe the crystal became 'conditioned' like the transistors do"
    Hmm, i am just pondering : "What if we become conditioned too?"
    We will be quite "out of phase" for christmas ...
    Or the aetheric field tuned itself to the crystal frequency and since these circuits swap frequencies periodically (like Aromaz pointed out) maybe the
    frequency of the total field is a combination of all individual fields` frequencies that are involved in the experiment.
    Anyone have a radiant fieldforce-meter?
  • Bodkins
    Crytrals make sence to me they are oscillating at the local ferquence.
    Brilliant
    I think time is locked in them
  • Inquorate
    Ha!
    @ xenomorph - that's amazing. And very much confirmation that radiant events travel better through wood and people than air.
    Very interesting that a crystal in salt water works. How about just the crystal, or just the water? I was going to put one of my baby chickens in a jar on my table
    Perhaps this is why tesla said that crystals were a form of life?? I'll not look at one the same way again...
    Thanks for sharing your observations, never irrelevant. Must admit, I'm stumped why your touch has the reverse effect, unless the crystal and you are absorbing and thus transmitting the radiant energy exactly out of phase, creating a null wave in the aether.. !? Maybe the crystal became 'conditioned' like the transistors do. Probably cause they're made of the same stuff. That might explain why 180 degrees out of phase?
    @ everybody - Any ideas? More answers we get the clearer the picture becomes :-)
  • Bodkins
    After about 7 hours of the experiment, the bulb started flickering again.
    Only upon touching it, the flickering would stop and the brightness would slightly increase.
    I came to the idea to put a glass filled with himalalya salt and a crystal next to the ignition coil, hoping that they would create a comparable field to a human field , so i would not have to keep touching the bulb
    well done this is a really good idea,
    I like the the term human field. what about doubling the salt and crystal once the first stage has past (you drop the light with your field)?
  • Xenomorph
    CFL circuit Observations
    Hello gentlemen,
    i have managed to replicate the radiant oscillator circuit with 1 2N2222 and 2 2N3055s, an ignition coil, a modified CFL lamp and neon tube running from a 12 V lead battery. It was difficult to achieve the results of the kick-starter circuit, for some reason it would not work and after the trying it with a master 2N2222 for a while, i went back to the 3055-2-Trannies-only circuit and it worked (with a strong flickering of the lights however).
    An interesting observation (that has been made in this thread before so better confirmation) is that the leads of the kick-starter cables had to firmly touch the wood plate on which i have built the circuit. Only then it would work and directly connecting the kick-starter cables would kill the lights, so wood has different material attributes related to radiant energy definitely.
    I have been running the experiment for about 9 hours and had a voltage drop of about 1 Volt at the source battery. I could not measure the current due to my multimeter being fried for current measurements. (
    I am sure that using shorter leads and introducing resistors for better voltage control at the transistors can improve the power-loss.
    Maybe i should go with a MOSFET-setup for future experiments.
    @gotoluc: Can you share your MOSFET-circuit (if i have not overlooked it)?
    I don't have a stand-alone signal processor however.
    I want to share here now a peculiarity that occured during the experiment:
    And indeed it had the same effect as touching the bulb, so i was able
    to exit the field of the experiment and the light remained bright.
    Now 1 hour later i touched the bulb again and to my surprise the effect of
    my touch had the opposite effect than an hour ago !!!
    It introduced flickering and the bulb eventually turned off.
    I made a video of it:
    YouTube - OrganicEnergyDimming
    So something must have changed in the experiment, an effect over time related to the crystal/water that changed the stability of the CFL ignition or the polarity (?) of the effect of my touch.
    Maybe that gives some of you guys some food for thought or maybe it is irrelevant
    Keep up the amazing pioneer-work people.
  • Bodkins
    YouTube - bodkins 46 one wire charging
    one wire charging scr neon.
  • Inquorate
    Derr moment
    'oh, THAT nat diagram'
  • Inquorate
    Scr cap pulse
    nat's diagram? I must have missed that. Found some more cap dump links..
    OS:Radiant Energy Antenna System - PESWiki
    Yeah, love Bill Bailey. Seen him once, and watched all his dvd's.
    posting a video or schematic of your setup when you get home? Go on, ya know you want to.. :-)
  • Bodkins
    Ben i have the Scr's with a neon pulsing two GIANT battery with the davidE thing going on Two.I only had sort time to do stuff so the balance with be all wroung but I just whated to get it going. I Use Nat diagram works a treat Cheers Nat.
    You like Bill Bailey LOL seen him loads
    Last edited by Bodkins; 12-20-2008, 10:32 PM. Reason: Look and you will see Ben LOL balance right it will flash
  • Inquorate
    Cap charge to battery by scr triggered by neon
    Found some info on this page, interesting how pot before neon changes cap discharge timing thru scr.
    Free Energy
  • Inquorate
    Found some Scr's
    I've got Scr's now so can work out a cap pulser to battery.. Got everything just need some time now to do it in :-)
    Thanks to ren for the tl494 signal gen, and tips re sharp points for spark gap getting a longer spark.. Didn't know that.. and I've fudged together a 555 signal gen as well..
    More from me soon, I'm going to spend ALL of tuesday in my lab.
    @bodkins, nice mugshot ;-) coil looks pretty sweet too.
  • Bodkins
    Too right carl start from the top
    Here a picture of my coil
    and hello everone my names Richard
  • hh1341
    Gentlemen,
    When winding cone shaped coils, start from the small end, you will have an easer time of it.
    Carl
  • broli
    TinselKoala at OU.com did some research a while back with destructive discharges of a capacitor with a thin wire. His results where really intriguing!
    Phenomenon observed by Tesla
    But I also should point out that he nearly died! The cap exploded, caught fire. And if that wasn't enough when he settled everything down and accidentally touched the remaining cap he got knocked out . I admire his courage though.
    This experiment made me think about something. If the extremely high short current impulse was unleashed like that. Wouldn't you think it would destroy the the beginning of the cable and leave most of it intact? His experiment shows that the wire exploded all the way to the end. I don't think this is a current explosion. I think the coil in front of it had an insanely high BEMF and choked out the thin wire till it exploded.
