  • hh1341
    Hi Carl,
    start out with 450 turns bi filar on an air core. Thats what the original SS plans called for if I remember correctly.
    Thanks Ren,
    I have made a bi-filar 450 turn air coil.(would have been more versatile had I made it 3 wire)
    It works but the transistor is getting hot and seems to have degraded.(it's a 2n3055....am wondering if a MJL21194G would be more robust)
    JB says to use the parts one has at hand and tune the resulting creation.
    I need some guidance on the logical way to go about tuning.
    I have a 1K and 5K wire wound pot as well as a 75 ohm 25 watt reo to work with.
    Carl
  • Bodkins
    Got the wrong end of the stick Ren,
    I go crosseyed looking at that schematic, So much to learn.
    Wheres the matrix when you need a big download!!!!!!
  • ren
    ??? Bodkins, I am in no way pointing fingers at anyone with that remark
    I simply saw no need in cross posting info from one thread to another. I, or someone else can, that is their choice, or quote from it if you need to.
    It also encourages a little constructive research, I had to learn this way, along with a big pile of components . I am happy to help or clarify if people need it.
  • Bodkins
    [QUOTE=ren;28002]here is the schematic I am using. Some parts are left out on the 555, you have to do your homework if you want them. Start here -> http://www.energeticforum.com/renewa...html#post20480
    Plenty of other places to go, I am not going to go through cap pulsing setups here so the thread doesnt get cluttered. Post in the other one above if you need a hand with the cap pulsing.
    really Sorry Ren a need to be more focused in my approach to this tread.
  • Bodkins
    Originally posted by **~Imhotep~** View Post
    you are using the fan as your pulse ? interesting arrangement ,cool effects
    The setup is same as last video the fan oscillating is not moving the iginition coil primary up in parallel to the power + winding the negative is on the collector.
    will be trying to making a Bedini Solid State oscillator from the fan coil, air core with lidmotor setup.
    Would like to run it from 9v rechargeables which i can charge from a 24v imhotep fan setup. three battery sets in total. need to do some test to see if the ignition coil will run well on 18volt the fan coil is 24v anyway.
    i think The reason for the brightness even though your amps are going down is because of me hitting resonance.
    Resonance is the most efficient freq. to operate.
  • ren
    Schematic
    All components can be changed or altered, but please note it IS John Bedinis schematic and is copyrighted/patented etc.
    The ignition coil is paralleled to the power coil of the oscillator, no cap across it, doesnt work for me if there is.
    Can use 2n3440 or mje340 or 2n3584 or any small npn rated for high voltage probably.
    Try different cap sizes if you like, just make sure if they are low uF that they are HV. Nothing under 50v if smaller than 10000uF.
    In my opinion a smaller transistor for the main oscillator works better. JB suggests the BD234c (?) I have used an MJL21194, but a mj3055 or 2n3055 would work, probably even better.
    Bridge needs to be HV too, use 4 1n4007's, its alot cheaper.
  • **~Imhotep~**
    Well I took a picture of the circuit drawing and downloaded it into my documents but I can't figure out how to insert it here. HELP!! . I guess some of the easiest things in life can be very hard if you don't know the tricks. I'll get it posted ASAP as soon as someone tells me how. Thanks
    Lidmotor ------ OK got I it! Thanks Ren. Great job with the solid state . You will have to show us how the cap pulser works.
    been busy replicating all versions and am getting ready to box it up
  • **~Imhotep~**
    Bedini Solid State oscillator with adjustable cap pulser recovery. Got rid of the homemade secondary, didnt light as bright and would switch off when the cap pulsed. Good for a safety light as its constantly blinking but not much else.
    Shown here running on a 12v 12 amp hour @ 300-350ma. Charging 12v 14 amp hour (parallel pair of 7 amp hours).
    Charges really well, light is useable. Ignition coil doesnt have the cap across it yet, may or may not make a difference. I will do a vid and draw a schematic up soon.
    Well done guys
    love the circuit great job !!
  • **~Imhotep~**
    Originally posted by Bodkins View Post
    Hi All
    Another video for the scopeshot and a interseting effect at high frequescy.
    Note. dont need to take scope off for the neo to light up had a just bad conection .
    Enjoy
    YouTube - Imhotep Lite Solid State fan scopeshots
    Imhotep Lite Solid State fan scopeshots - EnergeticTube.com*-*Where technology goes LIVE!
  • Bodkins
    Lidmotor, you should see a little button at the bottom called "manage attachments" the rest is self explainatory.
    Bodkins, once you have the SS coil oscillating and charging (you can hook it up Bedini SG style to start with, doesnt have to be cap pulser) all you need to do is hook the iginition coil primary up in parallel to the power winding. That means one end to the positive of source and the other end to the collector of the transistor. You dont even need a diode off the Ignition coil because there is one off the collector. Light goes to the HV of the ignition coil.
    Im running it parallel with a oscillating fan at the moment. my understanding was that the pulse charge is better! is that the case?
    Lidmotor cheers will start workin on it
  • ren
  • Lidmotor
    Lidmotor LB circuit photo
    Lidmotor but is it possible to put up a photo of the circuit find it hard to see what going where.
    Sorry for being a pain
  • ren
    Well done guys
  • Bodkins
    Hey guys I blink and this thing has morphed into another more interesting direction . Imhotep and Peter you should be very happy with all the effort that is going into this and the terrific ideas that people are coming up with. Ren I think that you have the best idea yet by combining the solid state oscillator circuit and the lighting circuit into a single one. Anyway here is a video of the LB circuit diagram and explanation of how it all goes together.
    YouTube - Imhotep Lite--Lidmotor LB Circuit
    Lidmotor
  • Bodkins
    Hi All
    Enjoy
