No Oscilloscope
The neon on the relay or the neon on the fan? I don't have an Oscilloscope either and it's like being blind eh. Sounds worthy of note though. I wonder what frequency the system is running at?
Hi all,
I'm using this fan quite successfully - HVACR > Fans > Axial Fans > Fan,Axial,107 CFM,12 V : Grainger Industrial Supply
It is the best so far and it only has 2 coils which makes life easier. Tonight I've been playing with the setup and got something rather interesting. I've added a self-oscillating relay (Imhotep's idea) in line with the running battery. The bad thing is the fan cannot sustain rotation, i.e. dies in a few seconds tops. The puzzling outcome is that the neon bulb comes on VERY brightly even with the load attached! I don't have a scope right now to see what is actually happening but I've never seen neon coming on with the load...
Thought it's worth sharing,
ABC
Now i am a bit confused about Trigger and Powercoil.
I did usual name the one, what is at the base as the Trigger. Anyway.
Black and Red is one Coil, and there dont go current through, when it dont runs.
You need to measure between the Case from Transistor and your Minus from Batt.
Thats Collector and Minus.
There is current, at the moment, when the Transistor switch.
If there is current without running, then its wrong connected.
But, can you measure the Ohms from the Coils?
And what Resistor & Pot do you use.
I think, either your Resistor is to high, or your Ohms at the Bifilar is to low.
Does the Coils swinging in a high frequency or low.
The right Resistance at the Base do control the Strenght of the repell.
And dont forget to put 5 Diodes in parallel for charge
Joit,
Thank you. Its very strange though.
In my video, YouTube - Bedini Motor you can see where I attach the fan to the board, the following setup is how I have it..
Black = PC -
Red = PC +
Blue = TC -
Green = TC +
It works fine with the fan but when I hook up the BiFilar in the following combination...
Black = PC - Outside Wrapped Wire
Red = PC + Inside Wrapped Wire
Blue = TC - Inside Wrapped Wire
Green = TC + Outside Wrapped Wire
This doesnt work on the BiFilar.
I put the multimeter across Black PC- and Red PC + on the board an I am not reading a voltage, which I presume I should be, I do get a reading If I connect...
Black(PC-) and Green(TC+) = 11.50v
Red(PC+) and Green(TC+) = 11.05v
Green is positive.
I think I may have been just lucky with the fan. I dont think the circuit I have is correct, but I have checked and rechecked it using this pic http://imhotepslabs.freeforums.org/d...file.php?id=13
Hi
No, the the Circuit is fine, same as original, just some more illustrated.
Usual most use bifilar Coils, when they self build one. That should be ok.
What Coil did you make, a new one, or did you rewire your Fan?
At Coils its like this.
There is a outer End, and a inner start.
The Coil works usual best, when you lead Plus from outside to inner End.
Thats why the outer End from a Coil becomes the Plus, and Minus is inside.
And now something to think :P
At a Bedini Circuit, you get 2 Coils, like your bifilar.
One is the Power Coil, and the second the Trigger Coil.
The Powercoil get Current from Plus from the Coil, so from outside to inside.
The N- Pole of a Electromagneticfield is allways opposite where the Current goes.
So, Current goes into your Powercoil, but the Triggercoil get the Signal earlier from the End from inside, the Minus.
The Circuit only works mostly, when you connect the Coils in opposite Way,
Actually, you only need to switch the Ends of one Coil and it should mostly work.
The N pole will be there, in what direction the Current goes.
Then you can find the end at your Coil, what will repel.
But it will work in attraction mode also.
Only for me, my Coils stuck mostly at the Rotor, when they are in Attraction.
But an easy way is too, just put a Magnet there, or a Compass.
You can try also , to adjust the Rotor to the Coil, and put short Power on it, that you can see, if your Coil got enough Power for repel.
Hi Guys,
I spent the weekend setting up a BiFilar coil.
I wrapped a 32swg and a 26swg together and tested the polarity by hooking the battery up to each wire and seeing which end attracted the magnets on my new rotar.
From what I guessed, I marked the end of the coil that attracted the magnets as positive and the other end as negative.
I hooked it up to my Bedini circuit which is laid out exactly as this diagram...
The diagram is for a fan version but I am presuming it is the same for a bifilar? Is it different?
It started osciallating. I spun the rotar and it nothing happened, the oscillation stopped.
Really dont know what it could be only that there may be a different bedini circuit for a bifilar coil.
Appreciate any help.
Splay
It is, anyhowOriginally posted by splay View PostJust another one Im thinking.
Looking around youtube, I am seeing different variations producing some high voltages into capacitors and such.
Why cant any of this voltage be passed back in to replace the source battery and the unit become self running.
Hope this is not another silly question
Splay
First, Batteries dont like it, when they are charged and discharged all time same time.
Usual you need to load them complete, and then use.
Then, Voltage dont means Power, you can have high Voltage, ie,
i can make with 2 silly Coils at a Fan with a U-core 40V, but no ampere.
But the Ampere is, what you need, to get Power.
There is a calculation anywhere, how you can count Joules, and what is usable Energy from it.
High Voltage and less amps takes more time to load a Cap.
There been attemps, to put a ne555 timer in, to charge and discharge Caps or Batteries. it is like switch the connections and charge once this one, and the second one.
But i dont know, what happend to these.
One replication is the Window Motor, it are Coils what are without Core around the Rotor.
This one is a selfrunner, but less did replicate it now.
And the Energy what is feeded at charge is to slow, that why you cant use it.
i tried by myself to see, what i can get from a Coil close to it,
had a Cap across, and the cap did allways load some lesser, as the Coils did need.
It has something to do with Lenz Law also.
I wish, you would be an Electrician
There are a lot things to understand, what happens with the Circuit and the Current.
But we are going slightly offtopic, maybe we should move back to your first thread :P
Splay
Inquorate Thanks,
Hmmm, time, waits for no man.
This will have to be a long term plan, if in theory it will work then I think it is worth the time investment.
What about if there was an inverter load on the batteries draining all the time?
This would probably mean more fans to compensate I presume.
Splay
Fast charge
Logic predicts higher amps in higher charge..
So several fans in parallel would do it. But if you make several fans (i made two, then moved on) perhaps try them being run in series, and charging in series, or series run, charging parallel etc, and time voltage rise from same starting point of charge battery. Also, time drop to starting level voltage using light globe as load, for each setup..
And share the results!
That's if you have the time :-) Alas, I don't.
Thanks Inquorate,
I posted before really thinking about that one
Here is what I have been trying to figure out.
I have two 12v deep cycle batteries 30ah.
What confuguration would I need to charge these as fast as possible?
Fan amps and source battery amps?
Splay
Back to source
Nope, can't charge a battery that is being used. Reasons of chemistry.
I was checking out some charge regulators and I found this one that handles two batteries...
www.SolarEquip.co.uk - Flex 7A Charge Dual Battery Charge Controller / Solar Regulator
That has got me thinking, can the power be diverted back to the source battery while it is running the circuit?
Splay
Guys,
There is something then I would like to do and thats create an automatic switch between charge and source.
Has anyone done this?
I imagine the source will drain to a certain level and then a relay or so kicks in and switches the batteries so that the charge now becomes the source.
Has this been done before?
Any pointers?
Splay
Hi, No i didnt see this Video before.
But Output Power depends allways at the wires you use.
Thinner Wire gives more Voltage, but lesser Amps.
The Newman Motor is some different, i think, there is a Dc device inside the Coils. Commutator with Coils, the Bedini runs by repell the Magnets.
The Newman motor is controversial, he claims to have OU,
much did replicate it, but didnt have the same success.
But a very simple Bedini Motor can be made with 2 buyed Coils, place them together, a Wheel in the Middle, or a Fan, where the Magnets are glued on.
Connected to the Circuit it will work.
But the Motor dont makes much Torque, the Energy is generated at the Coils and from Bemf.
No way for now to get the Power for it from the Fan back :=)
