The bistander thread
  • For Mr. Bystander's comments I appreciate your suggestions
    I comment the above
    I think the best thing is to do the experiment, and see the results, who has done it? What results did I get?
    Otherwise we are going to spend commenting and commenting, it is better to do the test, do the tests and that will be the best.
    There are already users who are conducting these tests, and they have the results, but ask them to show it, in the end they will not accept it, they will continue with the same system of postulates, schemes, theories (I do not discredit them), but without having done the tests, I want to refrute, invalidate an experiment, I have to perform the experimental check.
    I respectfully tell you, to be in favor or against without performing the tests, so we do not have the verification of the result, as I can validate or invalidate it, we must go to the field of experimental tests and according to any result, it helps me to redirect what I am experiencing.
    Every theoretical scheme is important to guide us, but they can fail at a given moment, new given conditions can be presented, or new and different results can be obtained, and hence renew the theoretical scheme, but it comes from experimental verification.
    • .... not worth the argument....
      • Well, not even your arguments are worth it, if it solves things that way, how will other simpler things solve it.
        Well, they have no arguments, that's why they go to the disqualifying
        • The process I have used since day one to adjust the neutralizing magnets is the same. I have talked about it many times. Back the adjustment magnets off all the way so they are having NO effect on the motor and no interaction with the rotor magnets. Install a coil pair (snake sure the coils have cores in them) and let the machine reach speed. Using the adjustments, move the opposition magnets closer to the rotor magnets and watch the amp draw of the motor. When you get the best possible amp draw by adjusting back and forth, you are ready to insert a second pair of coils (don’t forget the cores!) and repeat the process. If there were NO CHANGE in the amp draw of the motor, this process wouldn’t work, but I have been doing it this way for YEARS.
          • The important thing is that you have done it dozens of times, always obtaining the reduction in motor consumption, and you have also bought when you did not have the neutralization magnets, the motor would burn, well this way you reduce motor consumption by having more cores and avoid the engine burns out.
            You have commented on all this dozens of times, and you have checked over and over again your proposal for neutralization magnets.
            I have also already verified that it is functional, but whoever does not accept it, because its postulate systems indicate something else, it is easy to investigate it, but in practice.
            • As I said, a 7th grade science experiment would prove whether I am right or wrong. Anyone could do it. How many "researchers" have taken the HOUR it would take to put it together? bi certainly hasn't, and he has been around here forever, whining about my responsibility to prove this if it is real because of" all the lives it would save." But he takes no responsibility for lying about my work and refusing to do a simple experiment that would confirm or debunk. All talk and no action. Hiding in the dark and constantly attacking my work when he hasn't built anything CLOSE to what I have built. Pathetic. COWARDLY/
                I'll get to it when I get to it. Or maybe I could pull a Turion and say "I have the evidence but choose not to show it". But really, it doesn't matter with regards to your extraordinary claim. Just show that proof like you promised you'd do on January 6th, 2020. 14 months and still waiting. A few weeks delay on a little demo from me pales in comparison to your timeline.
                bi ps.
                "he takes no responsibility for lying about my work" Prove that. It is just another false statement from you.
                • That’s like asking me to prove you’re a COWARD. I don’t need to. Everybody knows. And now they know you’re too afraid to do that experiment and show the results. Why is that? Because....wait for it... you’re a COWARD.
                    No. I've asked you to prove an extraordinary claim which you made publicly multiple times over the past few years. Kind of like that, right? It's just BS from you. No proof. No evidence. No logic. No scientific reference. Just BS, insults, ridicule and name-calling.
                    If Greyland has those instruments why doesn't he run the output/input test? Or he hasn't thought of that? Or can't get data that you want?
                    Are your coils loaded when you do this?
                      ... My magnetic neutralization does NOT reduce the B field. It has NOTHING to DO with the generator cores or the magnets moving past them. There is a separate set of magnets on the rotor and a separate set of magnets on the stator that are adjustable. When two magnets of the same polarity are forced together, it "Neutralizes" the attraction of the rotor magnets to the core of the coils. That attraction is still there and as strong as ever, and so is the effect of the magnet on the core of the coil, but there is now an OPPOSITE reaction that is just as strong. ...
                      • LOL. Draw out what you just blabbered and you will see why everything you say comes out sounding so stupid.
                        I have ALWAYS said that the attraction of the rotor magnet TO the coil (core) was equal to the attraction of the coil (core) to the magnet as the magnet moves away. But that there is a split second in time where the magnet is neither approaching nor leaving that is not offset by ANYTHING except the neutralizing magnet. You, as usual, went through your hocus pocus explanation of why that isn’t so, but the facts speak for themselves. Next Sat Greyland and the guys will shoot a video of the machine running unloaded with all 12 coils in place and show the amp draw. You can then compare it to the video I already posted of the motor just turning the rotor and the motor turning the rotor with only four coils in place where the amp draw nearly doubled. What will you do then?
                          I'll ask the same as always. Show proof of your claim of 2000 watts real power output using 300 watts input. Should be easy to do with all those meters.
                          And, "there is a split second in time where the magnet is neither approaching nor leaving that is not offset by ANYTHING except the neutralizing magnet."
                          What direction is that force? If you can deal with force vectors, maybe you can understand what I'm talking about. But probably not, as you don't agree with Sir Isaac Newton either. Why learn physics when you can just make up your own rules, right?
                          • There's only one way to settle this as far as I can see.....I'll make a coil and test it. There's one small problem and that is how do I do it? If anyone can provide instructions I'll have a go. I really have been following the ideas for years and started off with a Bedini design. Does anyone remember PESwiki and Sterling Allen? Sadly Sterling turned out to be some sort of a weirdo and was removed from circulation I believe.
                              That'd be great. Turion claims he's given all construction details freely. Hopefully he or someone can direct you. However what I'm talking about, cogging and magnetic drag, is independent of copper. Just magnets and core(s) are required.
                                Here's how you can build it:
                                This thread could cover a wide range of what seems to be popping up all over the web. The new more efficient magnet motors and generators seems to hold real promise. TUBE VIDEO's are better than your lying news outlets such as CNN,ABC, NBC, FOX NEWS, and all of the rest of the bought and paid for agencies who are funded by
                                Look for Turion's comments.
                                Right decision, make the prototype and experiment, any questions or suggestions I will gladly support you
