Uncovering the Missing Secrets of Magnetism. 92 pages. Free new book
  • TheoriaApophasis
    Originally posted by tachyon View Post
    isnt this ferrofluid that shows the green and red color? and why do the poles switch colors?
    Ill explain that in the video tonight, its because of inverse CW and CCW spin
    The entire magnet system is forcing one pole to be "painted" either RED, or GREEN
    >>>>>>>>>ALSO why NO POLE is BLUE, because the wavelength is so short.......blue is only at the point of MAX dielectric attraction!!
    blue has higher dielectric capacitance as I state at the end of the book!!
    which is WHY IT IS NOT at either pole!
    also only ALL 3 colors at the inertial plane to which all three colors are drawn
    ALSO all 3 ONLY at the centripetal, so on each pole you can see either RED or GREEN centrifugal
    ......but the centripetal has a couple RGB lines visible just as it should be
  • tachyon
  • sadang
    I follow very carefully all your posts here on overunity, as well as your youtube channel and I'm familiar with all recommendations and videos made ​​by you. I admit I have not read so much about magnetism nor I can afford such a scale experiments, but seek to understand the magnetism for many years, and went through all the Titans of the turn of the century, before the imposition of GR and QM scientific religion, you recommend them.
    Magnetism can not create iteself, you say. Agree! But the same can be said about electricity, gravity, interatomic forces, and so on! This is the reason I think it is essential to be proved the dielectric inertial plane is the generator of magnetism. mainly because dielectricity is most closest to the Ether. And I mean in a practical way, trough an controlled experiment. I even don't know right now if this can be achieved, or how can be realised, without using a physical magnet! Maybe in a gas chamber with a DC high voltage and a special matrix of cells! I really don't know! But I know for sure this is a crucial point for your theory, otherwise anything can be explained or described using the terms and concepts in the actual science.
    I will think for myself to find a way to practically prove the inertial dielectric plane has the role of generator for the magnetic fields. It's hard because all terms and current concepts are interpreted and grounded exactly opposite compared to intrinsic nature of the observable phenomenology.
  • TheoriaApophasis
    Originally posted by sadang View Post
    You are unstoppable. Congratulations! I think the next step would be to proved without any doubt that the dielectric inertial plane is the generator of magnetism, and not vice versa.
    Ive already proved that 100 ways to Sunday.
    I made a video about that here:
    But, I have MORE videos, and MORE proof, and 2 devices I am seeking potential patents on, including "laser(s) based device" to demonstrate all aspects of field flow
    Magnetism is definitionally radiation, Magnetism does not, cannot create itself.
    Tesla , Steinmetz, JJ Thomson, Faraday, Maxwell all said this.
    Faraday called magnetism the "dielectric field" , which it is, its the discharge of dielectricity as a spatial Ether field modality.
  • sadang
  • TheoriaApophasis
    NEW DISCOVERY FIRST TIME EVER SEEN ON EARTH!
    COPYRIGHT 7-2014 KEN L. WHEELER
    MAJOR DISCOVERY TONIGHT!!!!!! using multiple LED frequencies (R G B) to create white light ONLY ALONG THE DIELECTRIC INERTIAL PLANE and CENTRIPETAL with DEVICE!!
    AND.................I CAN ONLY CREATE ONE COLOR ON ONE POLE AT ONE TIME, S IS GREEN, THEN N IS RED ;D ;D
    PROVING CW AND CCW SPIN
    IF N IS GREEN, THEN S IS RED
    etc etc
    RGB LED 5mm cells (each LED contains ALL 3 colors) .....colors exactly all spaced evenly at exact same locations around the cell.
    Using magnetic and dielectric deflection of LIGHT
    to prove CW and CCW vortex spin EM deflection!!!! AND, RGB concentration (looks like a rainbow) / WHITE LIGHT ONLY ALONG THE DIELECTRIC INERTIAL PLANE AND CENTRIPETAL RETURN
    Proves my entire theory
  • TheoriaApophasis
    TIME TO BUY A PIZZA TOMORROW TO CELEBRATE!!!!!!!!!!!!! WOOO HOOOOO MAJOR DISCOVERY TONIGHT!!!!!!!!!!!! using multiple LED frequencies (R G B) at once to create white light ONLY ALONG THE DIELECTRIC INERTIAL PLANE with "X" DEVICE) !!
  • Siggi1974
    Hi Theo,
    Do you think a sphere magnet would orbit around the centrifugal
    border of a toroid magnet, when positioned with the correct
    precession angles and the correct distance to the border?
    Best regards
    Siggi
  • TheoriaApophasis
  • TheoriaApophasis
    wtf is this?
    your statement has NO reference.......
  • TheoriaApophasis
    Result of the method you say Tesla would use to find the needle. What if the needle was a bone needle which were common at one time. It would then be destroyed along with the hay and the remains likely would not be found.
    Maybe you forgot that all needles are not made from metal. And steel needles would be damaged by fire. And you would still need to search the ashes for the blackened needle.
    Thats a fallacy called "taking the ANALOGY TOO FAR"
    Nobody has seen a bone needle in AGES
    Its analogy of THINKING METHODOLOGY, you're taking things literally
    In the "needle ANALOGY", the point is you have already RETRODUCED that the "needle is metal"
    Or bone, in which case you FLOAT everything in water, and the hay sinks, and the bone needle FLOATS.
    If that's your solution it leaves a lot to be desired. I don't think Tesla would do that. ..
    Tesla DID do that (not the needle analogy), but the METHOD, retroduction, he got it from his "BIBLE" , THEORY OF NATURAL PHILOSOPHY by Boskovich
  • Farmhand
    Originally posted by TheoriaApophasis View Post
    Tesla said something like (paraphrasing here) ........"Poor Edison!!! All those years trying to perfect a light bulb, if he (only used my method of logic) he could have done it all in no time!!!"
    Tesla , his guru Boskovich and others used a wholly lost art of retroductive thinking / approach.
    useful but inferior:
    Deduction:
    I heard so and so say she dropped the needle over there, and bob said the needle was 4" long, so we know what to look for, wind speed indicates since it was dropped from 5 feet up, it should have fallen on THAT side of the haystack.
    Induction:
    Well, theres a needle in a haystack, it was last seen over there on that side, needles are heavy, so Im going to go looking over there for it
    Superior in every way: (Tesla's method)
    RETRODUCTION / ABDUCTION:
    I know the properties of a needle, I know the properties of Hay...... watch this!
    lights a match......POOOF......!! All is gone in a second in a giant flame
    Theres the &@**$& needle!!!! Hay burns, metal needles dont.
    Problem solved
    ..........(deduction and induction are still looking in the hay)
    Deduction and induction are looking in a murky tub for a gold coin (wisdom, insight, invention, solution).
    Retroduction says "scr3w all this nonsense" and pulls the plug and taa-daa, there's the coin.
    Peace, lux et veritas
    I remember having this conversation with AllCanadian, If Tesla didn't mind destroying a stack of hay and re -hardening and polishing the needle then
    he might have used that method. But it seems the only use to that method is to damage a needle and destroy a stack of hay in order to find the needle.
    It would be much better to not take and use needles while sitting on a haystack, especially don't drop it.
    No one want's his haystack burned up either, generally speaking.
  • tachyon
    wtf is this?
  • TheoriaApophasis
    Originally posted by machinealive View Post
    Ken, those last pictures...wow.
    Very impressive!
    Thanks so much for sharing those.
    New video using that device I just made:
    See the ones I JUST MADE:
    Just made my VIDEO VIEWER SETUP
    Tons more to come, and "crap" that will roll your head off its axis
  • machinealive
    Very impressive!
