Cap Dump Circuit
  • BroMikey
    Sweet Double Jewel
    Sure is bright
    How many miliamps do ya figure?
    You weren't kiddin when you said you were ready to rumble
    Those Leds are rated at 20 ma I think right?
    Happy experimenting. Great machine.
    Mike
    Ok guys here it is
    [/IMG]
  • Dave45
    Ok guys here it is
    I hooked the two circuits together using only one AA battery I also did not put the cap in just hooked the outputs to each side of a one watt led.
    This circuit works great the led will blind you, Im still seeing spots.
  • Dave45
    Hi Dupe
    Yes there is no synchronization between the two stages but there really doesnt have to be since each is charging the opposite side of the cap.
    Iv thought alot on this myself, but just for testing I think it will do, maybe later we could work on synchronizing the two.
    Strange you brought up the 2n3055 and the 2n2955 thats what I ordered, they came in a few days ago.
    I still havent got my wire so Im going to wire up the small joule thief circuits and see what I can get from a 1.5 battery just out of curiosity.
  • Dupe
    Hey Dupe
    Yea thats the circuit Bedini made popular, we can take it a step further.
    Its so simple it has been overlooked
    We tend to overcomplicated, our mind tells us it just cant be that simple.
    Separate the pos and neg and boost both.
    All the best
    dave
    What transistors are you planning on using Dave? The NPN types are plenty full but I'm not sure about PNP HV types! If the popular 2N3055 is chosen then 2N2955 is it's complementary.
    The other query I have is with the configuration, should ideally operate in push pull so to speak, but there's no synchronism between the two stages to switch the bases alternatively, only the outputs are paired.
    Certainly worth investigating though.
  • Dave45
    Hey Dupe
    We tend to overcomplicate, our mind tells us it just cant be that simple.
    All the best
    dave
  • Dupe
    Camp Dump circuit
    Hey Dupe
    Which circuit are you referring too.
    Hi Dave
    the npn circuit in #342 diode anode to collector, cathode to battery + and battery - connected positive of source.
  • Dave45
  • BroMikey
    Sheet Just got Real, HUH? (A Mr Clean Quote)
    This will be the next test, wound a core for it today.
    Im slow but will get it done soon.
    Looks like more than paper shuffling to me. Way to go Dave. Keep running those open end coils so I can find out what they do.
    I watched the video. Hypothetically just went orbital into the ionosphere
    I watched a few do some of these JT circuits and doubles but you are able to exceed the some of them all.
    Can't wait till your next release comes.
    Mike
  • Dave45
  • Dave45
    Hey Dupe
  • Dupe
    Cap Dump Circuit
    I use an identical circuit for one of my battery pulse chargers. The transistor is a BU208 TV line scan output. I junked several heavy duty commercial battery charger boards fitted with very large copper wound inductors on ferrite air cores. A few turns added around the existing windings provided the feedback.
  • Dave45
    Just to let you know Im not all talk
  • Dave45
    Mike you may have already seen this but thought I would bring it to your attention, Allen posted a vid here you may find interesting http://www.energeticforum.com/renewa...tput-coil.html
    You could probably do the same thing with your cap dump circuit, a piggy back coil to charge the source battery.
    Anyway all the best, Im still working on the original pos neg circuit when I have time, will post when I get it working.
    dave
  • Dave45
  • BroMikey
    Of Sorts?
    Yep, looks like the coils are wound bifilar.
    If you think about it pos in one winding neg in the other the bifilar coil is a capacitor of sorts.
    Yeah the dot is on the top on one coil and the dot is on the bottom of the other.
    That is the cap bank that the circuit is filling.
    Mike
