Hi again,
Numbers:
The small 12 volt Bosch car fan motor uses 25 watts disconnected from the wheel.
Connected it will spin the out of balance wheel up to 328 RPM for an addition 11 watts, (36 watts total)
Increasing the speed (RPM) requires an additional input, eg; 436 RPM for 48 watts
However when one loads the wheel the input draw goes up such that to output 25 watts requires an input of 75 watts.
Just common sense
I have removed the reference to vectors as i was in error. They occur sequentially so do not apply.
Ron
Open discussion for projects on this forum.
Hello everyone,
I feel that the math has failed to identify how this works.
I will give some numbers in the next post.
Ron
https://www.youtube.com/watch?v=q2th...ature=youtu.be
The difference between Weight and Mass (On Earth)
Hello again,
I would like to expand a bit about previous post, but here, in order not to make it too long...then this important comment would be missed.
We all know that Mass and Weight of any object are "different" when existing under the influence of Earth Gravitational Field...and so, depending on the spatial distance of an object to Earth Center, the object's weight would vary, while mass remains constant no matter the distance.
A known Physical example is a hovering Helicopter above the surface of Earth...
When Helicopter takes off, it requires A FULL THROTTLE Acceleration of its Main ICE Shaft which directly (or clutched, to be more specific) effect its Main Rotor Blades, as the blade angles must be at a critical pitch...and so, as it elevates from Earth's surface it no longer requires a full RPM rotation of its main blades...this "Deceleration" continues to apply as it gains altitude...to a point that the ICE is almost "IDLING" while Helicopter is almost "floating" on higher layers of the atmosphere while main blade pitch could be almost at a flat angle...
Above example reminds Us that a body closer to Earth's Surface is heavier (weights more) than the same object set at a higher-elevated point in space, where obviously is "much lighter"...However, its Mass is exactly the same no matter where is its space location.
And so, according to all above facts, mass and weight could be the same for an object set at a relative short distance to Earth's Gravitational Field, however, at "certain" elevation in space both parameters start to become "automatically" different. And here it is completely dependent upon object's weight, where lighter objects would need shorter distances to become "lighter" while heavier objects will need higher distances to be considerably lighter.
Now, applying above facts to the Feather and Canon Ball experiment...where both objects are set exactly at the same distance from Earth surface...and both have no other affecting factors, like Air drag or Spatial Densities...but Vacuum in the whole chamber.
I would just add here...that we can not literally "divide" Weight by Mass of each objects and expect the result to be a "perfect" unity result...since mass would remain the same BUT Weight would be different at every millisecond of the falling time/distance range.
Gravity
Hi Ufo,
Perhaps it will help hearing it from someone else.
Of course the images didn't copy and paste, so go here: How to Calculate the Force of Gravity on the Earth’s Surface - dummies
Compare the mass of the Earth to the mass of the ball. The ball is like 10 with 24 zeros following it times smaller. That is the magnitude of error introduced by using a constant acceleration for objects nears the Earth's surface. So it isn't 100.00000000...000% correct, but pretty darn close. So in free fall near Earth's surface, the 'a' in your F=m*a equation can't change. 'a' is constant. So F is only dependent on m, Force depends on mass.
Hi Bistander,Originally posted by bistander View PostIn
Hi Ufo,
The acceleration due to gravity is constant on or near the surface of the Earth because the mass of the Earth is so much greater than the mass of the subject object on its surface and the center to center distance between the two masses is essentially constant.
So according to you and basically the underlined statement above...due to Earth Mass being so much greater than any other falling object towards it, or essentially a FREE FALL, We all should "neglect" the moving and falling object's mass?
The Equation I have used is exactly the one that has been spread and taught all along, and the one you have given here as well...or:Originally posted by bistander View PostThe true gravitational force equation is a the product of the two masses divided by the centers distance squared times a constant. The equation you used is just a convenient simplification.
F= m*a
Where we can see that mass(m) and acceleration(a) are DIRECTLY PROPORTIONAL between each others, which simply means that the greater ANY ONE of them both, will increase the total resulting Force (F) on the other side of the equation.
Exactly!...but then why, if they posses so HUGE different forces while falling down...WHY they both reach their traveling down path equally?Originally posted by bistander View PostThe acceleration of the ball and feather are equal but the forces are not.
And the point here is that I do not believe that we can just "neglect" or assume both body masses or weights are equal to "1"...in order that Math finds a "satisfying" answer/result to justify this radical experiment effected by Galileo Galilei way back in time?
Remember that at that time, Aristotle's Theory included mass on a free fall equation...and after Galileo's experiment Aristotle's theories became non trusted any more...
Newtonian Laws came after this has occur...so, IMO, He created this "patch" on the free fall calculations just to come up with a satisfying mathematical result...
But in reality, I believe IMHO this issue has not been deeply solved in either way, mathematically Nor physically...and so, I am pretty sure there must be "another component" missing here...which is NOT Density of the environment, Nor Air Resistance...but other hidden but actively acting "element" which makes this "magical" GRAVITATIONAL COMPENSATION, which obviously have absolutely nothing to do with Objects Physical Mass or Weights.
Bistander, with all due respect to you and all your knowledge...what you have written above...makes absolutely NO sense at all.Originally posted by bistander View PostSo regardless of the acceleration or speed of the two objects, the more massive one will have greater force. Obviously a greater force will cause more damage to a face on impact. Newton never said otherwise.
Again maybe it's the language, but I don't understand what you disagree with.
How can you admit one heavier object posses much stronger force than a lighter -in weight and volume- one...and still "makes it" in exact timing on their way down?
How can we all, deliberately take off the Huge Force difference between the two objects from the mathematical equation?
Only way that Sir Newton did this "miracle"...was by deliberately "converting" both objects massive weight/mass differential to a very simple "number one"...or in other words, getting rid of mass-weight so that force would be identical, since both are NOW under the same Gravitational Acceleration Force.
To me, that is called "A Forced Change in the Equation" to "make it fit or work out" giving a -momentary- satisfactory solution to the still unsolved dilemma between a feather and steel ball experiment...or simply "a patch" in History.
And please, do not take me wrong, I know this is the way we all have been "forced" or "patched" to understand this phenomena over all our generations, to the point it seems ridiculous trying to bring it up...like just starting questioning historical facts on the Bible with a Religious Person or Multitude...so, do not take it as just my personal opinion towards yours...but a critic in general to the way we have learned about it.
Kind Regards
UfopoliticsLast edited by Ufopolitics; 01-27-2018, 03:34 PM.
Gravity
InHi Ufo,Originally posted by Ufopolitics View PostHello,
If someone have not seen the video below...and had some doubts about the discovery from Italian Scientist Galileo Galilei related to Free Falling Objects of different Mass and Volume...I highly recommend to watch it.
[VIDEO]https://www.youtube.com/watch?v=E43-CfukEgs[/VIDEO]
Now according to the repeatedly mentioned before formula from Newton:
F=m*a
Applied to the two objects on video:
The two objects falling on that video, the heavy steel canon ball and the subtle, almost weightless feathers are BOTH under the ONLY INFLUENCE of Gravity Force ACCELERATION, since chamber is at vacuum levels, so NO OTHER FORCES are acting on any of the two objects.
Now, if we say that the steel ball mass=weight=80 Lbs (Pounds)
And feathers, all together are 0.05 Pounds (and that's heavy for the actual weight of those feathers)
Now, find the Force on the Steel Ball, let's take 80 pounds to kilograms= 36.28= 36.28X9.8=355.544 N
Force on Ball is 355.5 Newtons
And so those subtle feathers Newtonian's Forces calculations are:
0.022679Kg X 9.8= 0.2222542 N
Newtonian Force acting on the feathers are:
0.22679 Newtons
Obviously, according to that formula we could throw ONE THOUSAND STEEL BALLS and still the feathers would be floating in the air...
But that is NOT REAL, both objects fall at exactly same speed, just like if they both would have IDENTICAL MASSES or Weight (same deal different names) and so, what does Sir Isaac Newton "PATCH" to "JUSTIFY MATHEMATICALLY" the Galilean proof where MASS IS NOT INCLUDED ON FREE FALLS?
In other words...on the Second Newtonian Law, the Free Fall Calculations completely EXCLUDE Weight-Mass Parameters.
How did he figured that out?...simple, no matter how much the falling object weight would be, IF DIVIDED by its own mass, which would ALWAYS BE EXACTLY THE SAME NUMBERS...THEN, the result ALWAYS comes out to a nice number "1", no matter if they are feathers or canon balls...
Then the Formula to find the Force on Fall objects only considers Gravity Acceleration constant...multiplied by another constant which is the number 1?...Nope, actually we do not even need to show it.
Do you all agree with that?...and so can we all apply it to reality?...I do not think so!!!
And so, Bistander, if you agree with "Sir Isaac Newton" Free Fall Formula above, then please agree to stand under the Steel Ball falling down...and so I will choose to let the feathers fall on my face...
After all their weight divided by its mass has been "magically diminished" to exactly just a number one to both...so both would be exactly the same impacting force...correct?
Whenever You are ready let me know and I will contact Brian Cox in London... to repeat that experiment with you under the ball...
EDIT NOTE: You can NOT wear any special impact suits, nor helmets as I would not wear nothing to let feathers hit me...
You can stick your face wherever you want. I'll keep mine right here. The acceleration due to gravity is constant on or near the surface of the Earth because the mass of the Earth is so much greater than the mass of the subject object on its surface and the center to center distance between the two masses is essentially constant. The true gravitational force equation is a the product of the two masses divided by the centers distance squared times a constant. The equation you used is just a convenient simplification.
The acceleration of the ball and feather are equal but the forces are not. So regardless of the acceleration or speed of the two objects, the more massive one will have greater force. Obviously a greater force will cause more damage to a face on impact. Newton never said otherwise.
biLast edited by bistander; 01-27-2018, 04:14 AM.
Hello,Originally posted by gsmsslsb View PostUfo
Thanks for your insight.
I haven't been able to find Kevins posts on FB.
Only used it for the firs time the other day.
I found lots of photos including the ones on your post above but cant find kevins writing about them.
I will look again when I get the chance.
Could you explain this a bit more
radius must be scaled up properly as to balance all forces.
Thanks again
Well you must be logged in at FB in order to watch his posts and images.
Plus you need to be friends in order to exchange info over either PM or in the open, you could post on his page or wall.
There is no secret about balancing a system when making such arrangement as he has based on spinning wheels counter rotating, levers and fulcrums at different levels.
Just like balancing the crankshaft in an ICE...or the counterweights based on cylinders weight and compression-exhaust forces etc,etc.
Only thing I have noticed about Kevin's place at FB...is that it is not organized by ALBUMS, which is the only way to set orderly all his different set up models, plus articles etc.
That way we do not find a crazy mix of all kind of different things all blend up...unless he wants it like that for other reasons...
UfopoliticsLast edited by Ufopolitics; 01-26-2018, 10:41 PM.
Sorry, my bad, meant velocity (v)Originally posted by bistander View PostHi Ufo,
There is a difference between speed and velocity. So speed can be constant while velocity is changing, constituting acceleration. I don't think Sir Newton had a problem with this.
I know v is a vector and speed is a scalar number, no direction...I do not have a problem with this either.
In the case of the rotary wheel (like on topic here) Velocities are angular-tangential vectors to wheel circumference given a displacement over time plus changing directions every displacement... and centripetal acceleration would be following a vector towards center of wheel (could say center axis).
Speed vs velocity
Hi Ufo,Originally posted by Ufopolitics View PostI did not said that you said it...it is written in all Newtonians and calculations of Centripetal/Centrifugal Forces sites, and it is basic math understanding.
If Speed (v) is constant then acceleration is zero (a=0)
No tricks, and no weird situations where axis is static while wheel spins...
It is exactly based on our mathematical formulas...if acceleration is dependent on velocity, just because acceleration is equal to Change in Velocity over time, and so whenever there is no change in v (steady velocity) over time, then acceleration is zero.
Ok
UfoOriginally posted by Ufopolitics View PostHello Bistander,
I believe that Kevin is more likely referring to Centripetal-Centrifugal Forces, rather than Newtonian Forces:
Fc=m*V^2/r
Considering all his mechanical devices are based on rotating wheels, where radius must be scaled up properly as to balance all forces.
Which in the end is the same thing if we know that acceleration (a)= V^2/r , and then substitute (V^2/r) by just (a) then we will have what you are writing, or the known and simplified F=m*a.
However, if you notice on his drawing below, it is clearly defined that Kevin Hay knows that F=m*a as it is written on center-low side of image:
"FORCE IS MASS TIMES ACCELERATION"
And so, on image below he is replacing r by 2 on the left side of image formula F=m*v^2/2:
But what happens to acceleration "a" if the rotating speed v -of the whole System- reaches a steady RPM, which MUST take place when Machine reaches a Steady Normal Operation?
Acceleration becomes exactly zero, correct so far?
And so -and only according to math formula which directly relates v and a, but never in reality- then velocity "v" "should" also become zero...
But my question to you is:
Do you really believe that velocity of a steady spinning wheel is zero?... according to acceleration being zero at constant speed.
Anyways, my post here is not to start another argument about who is right and who isn't...but trying to reach a clear and sane discussion, trying to understand Mr Kevin Hay.
And Bistander...I do have my doubts about the Newtonian 2nd Law...as his "Free Fall" Calculation Method, but that is a topic to another post I will put together for you later...
Oh, and I almost forget...to remind you -btw- that I also came from Face Book...
Kind Regards
Thanks again
I did not said that you said it...it is written in all Newtonians and calculations of Centripetal/Centrifugal Forces sites, and it is basic math understanding.Originally posted by bistander View PostThanks Ufo,
I never said that.
No tricks, and no weird situations where axis is static while wheel spins...Originally posted by bistander View PostBut the velocity of the wheel, as a whole, can be zero if it is spinning and the axis of rotation is not moving. However the points on or parts of the spinning wheel have non zero velocity and experience acceleration even if the RPM is constant.
Is that what you're asking or is it a trick question?
OkOriginally posted by bistander View PostAs far as your subsequent post on Newton's gravitational laws, I see nothing inconsistent. I'll read your post again and see if I can figure out what your problem is.
Force equation
Thanks Ufo,Originally posted by Ufopolitics View PostHello Bistander,
Fc=m*V^2/r
Kind Regards
That's all I was asking for. But his equation, F = m*v^2 is incorrect as you point out. Maybe he did mean Fc = m*v^2/r.
I guess I did ask another question and I have yet to get a reasonable answer. It appears to be a simple machine, and scalable, so why hasn't anyone built and demonstrated it, even a small version?
I never said that. But the velocity of the wheel, as a whole, can be zero if it is spinning and the axis of rotation is not moving. However the points on or parts of the spinning wheel have non zero velocity and experience acceleration even if the RPM is constant.Do you really believe that velocity of a steady spinning wheel is zero?... according to acceleration being zero at constant speed.
About "Sir Isaac Newton"...and Galileo Galilei...
Hello,
F=m*a
0.22679 Newtons
3.8) Newton’s Second Law Explains Why Objects in free Fall have Equal Acceleration
How Newton’s Second Law explains why the acceleration of all falling objects is the same (on earth).
Weight is the force due to gravity on an object. The ratio of weight to mass is the same for any object. Although a larger mass has more weight and thus more force pulling it downward, it also has more mass.
Then:
a= weight divided mass= big weight/big mass= little weight/little mass
Taken from: Physical-Science Classes
Do you all agree with that?...and so can we all apply it to reality?...I do not think so!!!A free-falling object is an object that is falling under the sole influence of gravity. That is to say that any object that is moving and being acted upon only be the force of gravity is said to be "in a state of free fall." Such an object will experience a downward acceleration of 9.8 m/s/s.
Physics Class Room
UfopoliticsLast edited by Ufopolitics; 01-26-2018, 06:14 PM.
Originally posted by bistander View PostF = M * a. Force is equal to mass times acceleration. Can we agree on that? It is known as Newton's second law of motion. Acceleration is the rate of change of velocity. Acceleration has units of m/s^2, or meters per seconds squared. A Force of one Newton equals one kilogram times a meter divided by one second squared. N = kg*m*s^-2.
Your equation of F = M * v^2 units reduce to kg*(m/s)^2 or kg*m^2/s^2 or kg*m^2*s^-2.
Obviously units are different between your equation and Newton's. I say Sir Newton is correct and you are wrong.
Your turn. Prove your equation correct.
Note: I have used upper case M for mass and lower case m for unit of meter to avoid confusion between the two.
Hello Bistander,
Fc=m*V^2/r
Kind Regards
UfopoliticsLast edited by Ufopolitics; 01-26-2018, 04:45 PM.
Hi LesOriginally posted by Les Banki View PostGuys,
Since I am NOTNOT take part in your NEVER ENDING arguments about formulas and the like.
To me, the issue is very clear.
Those who argue have ZERO understanding of this subject.
Period.
End of story.
From now on, all I will do is look out for your announcements about YOUR WORKING free energy machines!
Les Banki
Been enjoying the hell outta you taken the upper hand.
Thanks for the Hays stuff. I get content offline.
When you speak I try to listen with more faith because i known you
are a man who has been thru the handbooks more than me. In fact the
average fellow probably has not been thru every page of the EE handbooks,
let's face it that would take years and decades.
I am looking forward to any and all further entries that you might deem of
value so drop more in the fishbowl, I love learning.
God Bless you Les
PS Sounds like you got one working? Well not in this thread no way.
Wasting your breath. Is anyone asking? That's because they already
know. You are being corrected for an example that has not yet been
offered. Does anyone care? I do, but you understand.
I had to jump in and give you one.Last edited by BroMikey; 01-26-2018, 11:13 AM.
