  • Another word for Principle of Correspondence:
    SCALABLE
    Signs and symbols -Confucius.
    • here is another Spiritual Nugget
      This big dolmen is situated in Draguignan city. It's an important megalith with a 25 tons HM 7 capstone. Lateral supports are 2.50 metres high. HM 7 and Three Pillar HM 3
      Legend about this dolmen talks about a fairy living under the monument. Locally it is called
      This dolmen was a burial ground directly connected with a settlement nearby. It has been classified as a "Monument Historique" since 1889. Despite this the dolmen is spoiled. There are modern carvings along with painted graffiti that ruin it. The monument is easily reachable by car and is well signposted on the main roads
      ....Dimensional Door ....what do you think happens to the quartz inside the Pillars when you put so much weight .....on them
      a smaller version of this times 3 (3 pillars ):
      The primary use of this Symbol is to increase Reiki power (enhanced by Granite remember the composition of granite ...quartz...mica...etc ). It draws Energy from around you and it focuses it where you want to (Principle of Mentalism : Universe is All Wave / Source Field ).
      just a thought the above Pyramid (and all the other Pyramids ... Principle of Correspondence ) coupled with this
      Stonehenge ... the 15 th ....Idles Of March
      15 th = HM 6 but also 15 th = HM 5 * HM 3
      hence HM 6 = HM 5 * HM 3
      • Have you ever heard of:
        Shugborough inscription
        The Shugborough inscription is a sequence of letters - O U O S V A V V, between the letters D M - carved on the 18th-century Shepherd's Monument in the grounds of Shugborough Hall in Staffordshire, England, below a mirror image of Nicolas Poussin's painting, the Shepherds of Arcadia. It has never been satisfactorily explained, and has been called one of the world's top uncracked ciphertexts.[1] The inscription became widely known after being mentioned in the 1982 book The Holy Blood and the Holy Grail (have not read it but i think it came up in our discussion ) by Michael Baigent, Richard Leigh, and Henry Lincoln.
        let's play with it : two version : HM1 + HM 9 and the Mirror Version (think Star of David )
        a link to a website linking the inscription to Oak Island
        templarstreasure.com
        made of Granite the stand
        • a sequence of letters - O U O S V A V V, between the letters D M
          numerology of ancient alphabets
          The sacral sum 21+43=64 HM 3 + HM 7 (see megalith ) = HM 1
          Now in the Latin alphabet there are 26 letters HM 8 but originally in the Latin alphabet was 21 letters( HM 3 ): A B C D E F Z H I K L M N O P Q R S T V X, that differs from the modern Latin alphabet: A B C D E F G H I J K L M N O P Q R S T U V W X Y Z.
          O U O S V A V V = 7 6 7 3 6 1 6 6 = 36 = HM 9. ...oooops... correction it is 42 = HM 6
          Also D = HM 4 and M = HM 4 ..............which gives you 4 4 bottom of 639 triangle
          and 36 + 4 + 4 = 44
          used Chaldean table as it was mentioned in Fulcanelli's Book
          from: Chaldean Numerology, Chaldean Vibrations, Compound Numbers
          36 HM 9. ...oooops... correction it is 42 = HM 6
          Has the same meaning as the number 27 HM 9 , which is the one next to it in its own series of "compound" numbers.
          27. HM 9
          This is a good number and is symbolized as "the Sceptre." It is a promise of authority, power and command. It indicates that reward will come from the productive intellect; that the creative faculties have sown good seeds that will reap a harvest. Persons with this "command" number at their back should carry out their own ideas and plans. It is a fortunate number if it appears in any connection with future events.
          Chaldean Compound Number Vibrations
          Here are some of the vibrations in Chaldean numerology. You can calculate your vibration with the Chaldean Numerology vibrations table pictured above and find out if your first, last name or first and last name together have a good or bad vibrations.
          Here are only few vibrations listed. YOu get all the vibrations in the Numerology Analysis.
          Single numbers denote what you appear to be in the eyes of others, while the double or compound numbers show the hidden influences that play a role behind the scenes and some mysterious way often foreshadow the future.
          All the numbers from 10 upwards HM 1 , become compound numbers and have a meaning of their own distinct from the root number. We do not know how and in what age these compound numbers were discovered. We can only say that they appear to have always existed. The meanings ascribed to the numbers 1 to 9 belong to the physical or material side of things and compound numbers from 10 onwards belong to the more occult or spiritual side of life. Distinct symbolism has been given to the compound numbers up to that mysterious number of 52. HM 7
          The universally accepted symbolism of the compound numbers in ancient times was given in pictures and may still be found in the Tarot Cards which have been handed down to us from ancient times and whose origin is lost in antiquity.
          • was thinking about the Number 52 and why so mystical
            All numbers, whether found under this system or the Pythagorean one, have basically the same meanings, symbols, nature, and character. This seems to be the universal rule of all number systems.
            However, under the Chaldean Numerology system, it isn't enough to know what the single numbers mean. One must also know what the "compound," or "double," numbers mean is well. The single Chaldean Numerology number simply represents the physcal outward appearance of a person's name, whereas the compound Chaldean Numerology number represents the deeper, metaphysical, hidden influences or forces behind the name.
            what is 52 ?
            52 /2 = 26 HM 8
            26 / 2 = 13 HM 4
            if you pay close Attention to the the structure of numbers you'll find a male and female pole in these Numbers
            13 = 1 and 3 = HM 4 (above )
            26 = 2 and 6
            52 = (poles switch ) 5 and 2
            Three are the natures of Mind,
            carrier it of the Will of the Great One.
            Arbitrator of Cause and Effect in thy life.
            Thus is formed the threefold being,
            directed from above by the power of four.
            Four is it in qualities,
            shining in each of the planes of existence,
            but thirteen in one (HM 4 ) ,
            the mystical number.
            Based on the qualities of man are the Brothers:
            each shall direct the unfoldment of being,
            each shall channels be of the Great One.
            so what do the Chaldeans say about 13 and 26
            13.
            This is a number indicating change of plans, place and such-like and is not unfortunate, as is generally supposed. In some of the ancient writings it is said, "He who understands the number 13 will be given power and dominion". It is symbolized by the picture of a "Skeleton" of "Death," with a scythe reaping down men, in a field of new-grown grass where young faces and heads appear cropping up on every side. It is a number of upheaval and destruction. It is a symbol of "Power" which if wrongly used will wreak destruction upon oneself. It is a number of warning of the unknown or unexpected, if it becomes a "compound" number in one's calculations
            also 52 = 13 * 4 or HM 7 = HM 4 * HM 4 .
            26.
            This number is full of the gravest warnings for the future. It foreshadows disasters brought about by association with others; ruin by bad speculations, by partnerships, unions and bad advice. If it comes out in connection with future events one should carefully consider the path one is treading.
            52.
            Has the same meaning as 43.
            We have now completed the 52 numbers which represent the 52 weeks of our year, and for all practical purposes there is no necessity to proceed further.
            43.
            This is an unfortunate number. It is symbolized by the signs of revolution, upheaval, strife, failure, and prevention and is not a fortunate number if it comes out in calculation relating to future events.
            looks like 26 and 52 are red flags for change ...after chaos ....order
            36 / 2 = 18 HM 9
            18.
            This number has a difficult symbolism to translate. It is pictured as "a rayed moon from which drops of blood are falling; a wolf and a hungry dog are seen below catching the falling drops of blood in their opened mouths, while still lower a crab is seen hastening to join them." It is symbolic of materialism striving to destroy the spiritual side of the nature. It generally associates a person with bitter quarrels, even family ones, also with war, social upheavals, revolutions; and in some cases it indicates making money and position thorough wars or by wars. It is however a warning of treachery, deception by others, also danger from the elements such as storms, danger from water, fires and explosions. When this "compound" number appears in working out dates in advance, such a date should be taken with a great amount of care, caution and circumspection.
            red Flag
            • Week Numbers for 2012
              this week we are the 10th week of the Year HM 1
              Next week it is the 11th Week of the Year HM 2
              and since the number 36 came up ...let's see what it is :
              Week 36 September 3, 2012 September 9, 2012
              09/03/12 - 09/09/12 = HM 9 / HM 3 / HM 3 - HM 9 / HM 9 / HM 3 = 15 - 21 = HM 6 - HM 3 on Week 36
              now this is quite a Fractal Resonance
              a fractal construct has an 'efficient function', it has a fractal ergonomy to them, they function on multiple levels and in multiple dimensions:
              42.
              Has the same meaning as the number 24.
              24.
              This number is also fortunate; it promises the assistance and association of those of rank and position with one's plans; it also denotes gain through love and the opposite sex; it is a favorable number when it comes out in relation to future events.
              Week 42 October 15, 2012 October 21, 2012
              10/15/12 - 10 / 21 /12 = HM 1 / HM 6 / HM 3 - HM 1 / HM 3 / HM 3 = HM 1 HM 7 = HM 8
              • dissect this statement using the 7 Principles: time to Practice
                (i'll just be using my favorite of the moment...Principle of Mentalism
                a repost (it is always important to reread information as it is also fractal )
                Gnostic.Org: The Kybalion
                But the Hermetic Teachings go much further than do those of modern science. They teach that all manifestations of thought, emotion, reason, will or desire, or any mental state or condition, are accompanied by vibrations, a portion of which are thrown off and which tend to affect the minds of other persons by "induction." This is the principle which produces the phenomena of "telepathy"; mental influence, and other forms of the action and power of mind over mind, with which the general public is rapidly becoming acquainted, owing to the wide dissemination of occult knowledge by the various schools, cults and teachers along these lines at this time.
                In the phenomena of Telepathy it is seen how the Vibratory Energy of the Masculine Principle is projected toward the Feminine Principle of another person, and the latter takes the seed-thought and allows it to develop into maturity. In the same way Suggestion and Hypnotism operates. The Masculine Principle of the person giving the suggestions directs a stream of Vibratory Energy or Will-Power toward the Feminine Principle of the other person, and the latter accepting it makes it its own and acts and thinks accordingly.
                Our Conscious Mind Could Be An Electromagnetic Field
                Are our thoughts made of the distributed kind of electromagnetic field that permeates space and carries the broadcast signal to the TV or radio.
                see previous post http://www.energeticforum.com/renewa...tml#post150684
                  The Buddhabrot Technique
                  [IMG][/IMG]
                  • Archive 2011 - Interview with a contacted Ummite
                    see also http://www.energeticforum.com/psychi...ntenna-31.html
                    here is a link to recent interview of a contactee...where
                    an excerpt Archives 2011 - Interview d'un contacté Ummite - Le Blog Insolite et Ufologique de Sedona (use google to translate )
                    Interview made by Olivier de Sedona May 26, 2011:
                    Olivier de Sedona: You have entrusted me to have met several times in 30 years the aliens that we know better under the name of ummites, can you tell me how this story began and where she started at?
                    Marc: Regarding the Oummains, I know they prefer to be appointed as well, it started in 1975 in Toulouse (Pyrenee ), where a person told me that I should be aware of what might come out of the ordinary. He was a gentleman of uncommon kindness and I had a sense of telepathy when he left.
                    • A very Interesting phenomena ... you may want to check it out:
                      Cavitation - YouTube
                      Water cavitation in an antique singing bowl with a large neodymium magnet submerged in the center of the bowl. YoungTesla
                      Dont' they do the exact same thing if you take the magnet out? I have one of these bowls, and the water droplets do the same thing without a magnet in it. . .
                      TheSmashedup 1 year ago
                      @TheSmashedup No, they do not do the same thing without a magnet. Once a magnet has been placed in the bowl, the cavitation droplets will appear and move toward the center of the bowl. When the magnet is then taken out of the water and flipped over, the cavitation droplets will not form at all. It's quite an interesting phenomenon and this video does not demonstrate the experiment to its full extent. If you have a bowl, I highly recommend trying it out for yourself. Let me know what happens!
                      ps: you are made of water too
                      -------------and this one ...falls also in step with our Discussion: using a Rodin Coil with ...my fav Crystal ....Quartz
                      VORTEX WITH CRYSTALS - YouTube
                      ADDING SIX QUARTS CRYSTALS TO THE COIL BOOSTED UP THE INTENSITY OF THE MAGNETIC VORTEX IN A BIG WAY, THE LEVITATING SPHERE DOSEN"T WANT TO SHAKE LOOSE AND THE COIL SEEMED TO SUCK THE MAGNET OUT FROM MY FINGERS. BIG IMPROVEMENT WITH THE CRYSTALS, I'LL ADD A BUNCH MORE!
                      to be replicated.... easy to test ......compare a normal Rodin Coil as a Speaker with one that has the Quartz in it
                      and if it pans out to be true a logic mash up with: 6 Vogel Crystals
                      -------------------- from: http://www.energeticforum.com/renewa...netism-22.html
                      Review of ExtraOrdinary Technology 2011
                      Jamie started off with a call for using an older A-432 tuning standard rather than the Nazi mandated A-440 tuning used by most musicians today. He pointed out that the foremost advocates of the newer tuning standard were high officials in Hitler's government, and that it creates a form of tension in most people.
                      Then he brought up conference Technical Director, John Fiala, who had suffered a severe wound from a practice mortar round last October that involved second and third degree burns. Healing had expected to take about two years. John described using a multi-frequency Rodin Coil built by his son and finding his healing time reduced to about four months!
                      Jamie then stated, "Marko's work is in coherence with Pythagorean tuning."
                      see also: http://www.energeticforum.com/158041-post659.html
                      • to search this Thread using Google , just type in the title of the thread and key word you are looking for :
                        for instance :
                        type in : The Brain is an Advanced Fractal Antenna + Myrrh in Google Search Bar
                        • You should read Again the Introduction of Fulcanelli's book:
                          Mystery of the Cathedrals
                          here is an Excerpt :
                          'You will have understood what this Sky is, from the following little commentary of mine and by which the alchemical sky will have been disclosed. For:
                          'This sky is immense and clothes the fields in purple light,
                          'In which one has recognised one's stars and one's sun.'
                          It is essential to consider well that the sky and the earth, although they are confused in the original cosmic Chaos, differ neither in substance nor in essence, but become different in quality, quantity and virtue (Principle of Polarity and Principle of Vibration ). Does not the alchemical earth, which is chaotic, inert and sterile, contain nevertheless the philosophic sky? Would it then be impossible for the artist, the imitator of Nature and of the divine Great Work, with the help of the secret fire and the universal spirit, to separate in his little world the luminous, clear, crystalline parts from the dark, coarse and dense parts? Further, this separation must be made, consisting in the extraction of light from darkness and accomplishing the work of the first of the Great Days of Solomon. It is by means of this process that we are able to know what the philosophic earth is and what the Adepts have named the sky of the wise.
                          The decay of radium into lead with the release of radioactivity is alchemy. Nature is an alchemist.
                          The explosion of a nuclear bomb is alchemy. The scientist is now an alchemist.
                          All such energy transformations are fraught with great danger and the secrecy which has always surrounded Hermeticism is concerned with this aspect among others.
                          Nuclear energy was undoubtedly foreseen thousands of years ago. Chinese alchemists are said to have told their pupils that not even a fly on the wall should be allowed to witness an operation. 'Woe unto the world,' they said, 'if the military every learn the Great Secret.'
                          The wave of Islam's expansion reached Spain where two streams appeared to have joined up. In Seville and Granada there were initiated Jews who carried the Egyptian transmission. They met Arab initiates who carried the Greek transmission and the latter were perhaps reinforced from a permanent powerhouse from which all evolutionary operations are directed.
                          Spain where Maimonide and Averroes Studied and developped some of their theories
                          The current which flowed from the beads of mercury (the tears of the Moon ) which were reunited in Spain flowed into an immense invisible force shield over Europe. The nature of this noumenal structure can never be glimpsed and its functions in a higher dimension cannot even be imagined. It externalized into the common life in a series of culture components which in aggregate constitute a large part of Western civilization.
                          The House of Light:
                          • Chaldean Numerology, Chaldean Vibrations, Compound Numbers
                            18.
                            --------Tears of the Moon
                            17 - Moon
                            Motto:
                            Roris Nutrix Benigna (Bountiful Nurse of the Dew)
                            Deities:
                            Hecate; Artemis, Diana; Selene, Luna.
                            Dice:
                            4+5 = Celestial Eternity + II.Change/Female (Water); 6+2 = Eternity + 2.Change/Female (Fire).
                            Astragali:
                            3+3+4 = Eternity + II.Change/Female.
                            Greek Letter = Qoppa:
                            Qolpos = womb, depth, bosom; Quon = dog, *****.
                            Trigram:
                            :I: Name: K'an = the Abysmal. Image: Water, Rain, Moon. The Second Daughter, associated with passion, danger, repetitive bending, penetration. West in Earlier Heaven.
                            Description
                            We are looking from the edge of a dark sea towards its shore, which is lit by the narrowest crescent of a young, pale yellow moon shining in the dark blue sky. Glowing tear drops (15 white, 15 reddish) fall in three streams (5 reddish and 5 white each) from the recumbent crescent, which is open to the upper left.
                            A scorpion, with a scarab-shaped, crab-like body and its tail raised, has paused half in and half out of the dark blue water; silvery sparkles of light dance across the surface of the sea and glow like fish eyes in its depths. An encrustation of dried salt is visible at the water's edge.
                            On the reddish-brown sand of the desolate shore two canines stare at the moon, a dark wolf or jackal stands baying on the left and a white, domesticated dog, wearing a collar, lies on the right. Just beyond them, on either side of the path, are two plants. Their stems are red and veined in black, and each plant has thirty small yellow flowers, like those of marjoram. In the distance are two tall, square towers (light on the left, dark on the right), beyond which the grassy twin-peaked eastern mountain is visible in the misty distance. There is a hint of a sunrise between the peaks.
                            Three indistinct paths meet near the scorpion. One follows the shore to the left (north), another to the right (south). The third path (east) winds from the scorpion, becoming more distinct as it passes between the dogs, plants, and towers, until it disappears in the misty distance.
                            it is highly recommended to read the article... much convergence to our Discussion
                            In our image there are fifteen white dew drops and fifteen reddish. "Fifteen ( HM 6 )represents the zenith of lunar power" (Schimmel 213) since it is half of a lunar month (as reflected in the 30 flowers of the moon-plants; see below). Red and white represent male and female respectively (Cooper s.v. colours), and the duality of Sulphur and Mercury, the primal substances of alchemy, principles of coagulation and dissolution (Biedermann s.v. color). We see these, the fixed and volatile spirits, descending to earth, where they are united and embodied in the alchemical Salt, which comes from the Lunar Sea and the Moon Plants (Jung, MC 133; for Salt and the Moon Plants, see below). In this way soul and spirit come to be embodied in matter.
                            In Middle and Neo-Assyrian orthography, dating back at least as far as the 13th century BCE, the principal gods were denoted by numbers, and the number for the Babylonian moon god, Sin (Sumerian Nanna-Suen), was thirty. Sin's number is twice fifteen HM 2 * HM 6 , the number of Ishtar/Inanna (16.Star), Sin's daughter, and it is thrice twenty ) HM 3 * HM 2 , the number of the sun god, Shamash/Utu (18.Sun), Sin's son. Thus, in the sequence of trumps, the Moon/Sin is surrounded by its two children, Star/Ishtar and Sun/Shamash. The shields of the Three Lamps of Heaven (Ishtar, Sin, Shamash) are often found together in Mesopotamian art, wherein the usual sign for Sin is a crescent moon. (Black & Green s.v. Inana, Nanna-Suen, figs. 7, 73, 90; Parpola 182; Schimmel 213)
                            Notice that 19.Angel/20.Justice form a male/female pair, as do 18.Sun/17.Moon, and their mystical numbers differ by 10 HM 1 . Further, across the central Pillar of Equilibrium, 19.Angel/17.Moon and 18.Sun/20.Justice form male/female pairs, and the mystical numbers differ by 30 HM 3. The figures down the center (21.World, 0.Fool, 13.Death) tend to be androgynous (12 & 16 are exceptions).
                            17.Moon is dominated by the color dark blue, which is especially associated with Hecate and the Moon (see 4.High Priestess). Blue symbolizes the cool lunar mind: emotional detachment, contemplation, the intellect and spiritual concerns. In our image these qualities permeate the sky and the sea - the Zenith and the Deep. Blue (kuanos) is also the color especially associated with Persephone.
                            The Salt of Wisdom is a cold, lunar spirit, the Wise Serpent, Nous (Mind), Agathodaimon (Good-demon), Serpens Hermetis (the Hermetic Serpent), the Lapis Occultus (Occult Stone); as a spirit it is the Avis Hermetis (Hermes Bird), which ascends to the Heavens. It is the White Dove (the Spiritus Sapientiae = Spirit of Wisdom), the pure, chaste, wise and rich Queen of Sheba (known for her combination of wisdom and femininity). (Jung, MC 131, 192, 194-6, 238, 241, 245, 257)
                            • follow up:
                              Kerenyi (Goddesses of Sun & Moon 32) say, "Seven is a lunar number: seven days signifies a quarter moon: twice seven signifies the moon's waxing or waning." (See also Schimmel 129-30.) Therefore 17.Moon corresponds to Seven in the second Hendecad of the Major Arcana: The numerical value of TRIODOS H QEA (Triodos He Thea, The Goddess Trivia, Hecate) = 777, which reduces to 7-7+7 = 7. Also, DESPOINA EKATH H QEA (Despoina Hekate He Thea, Mistress Hecate, The Goddess) = 777, which also reduces to 7.
                              you can also look at the Structure of the number 17:
                              17 = 1 7
                              the Union between the Sun (HM 1 ) and the Moon (HM 7 )
                              The journeyer through the lunar landscape might find it helpful to repeat the following "Hymn for the Nascent Moon," which I've paraphrased from the Carmina Gadelica (306):
                              Whene'er I see the Nascent Moon,
                              With upturned eyes I sing this Rune,
                              And bend my knee upon the ground,
                              And bow my head in thanks profound.
                              For Thee my praises, Guiding Light,
                              That Thee I've seen this very night,
                              That Thee, the Nascent Moon, I've seen,
                              Thou glorious Guide on whom I lean.
                              I think on those who've left us, too,
                              'Tween now and last the Moon was new,
                              While in the earthly realm I've stayed,
                              Thou Moon of Moons and Holy Aid.
                              • ♥ ♫ ♪ Gary Wright: Dream Weaver, Album/Studio Version HQ ♥ ♫ ♪ - YouTube enjoy
                                Dream Weaver lyrics
                                I've just closed my eyes again
                                Climbed aboard the dream weaver train
                                Driver take away my worries of today
                                And leave tomorrow behind
                                (chorus)
                                Ooh dream weaver
                                I believe you can get me through the night
                                Ooh dream weaver
                                I believe we can reach the morning light
                                Fly me high through the starry skies
                                Maybe to an astral plane
                                Cross the highways of fantasy
                                Help me to forget todays pain
                                (chorus again)
                                Though the dawn may be coming soon
                                There still may be some time
                                Fly me away to the bright side of the moon
                                And meet me on the other side
                                (chorus again, then fade out with the following
                                Repeated several times...)
                                Dream weaver
                                RELIGIONS AND CULTURES OF MOON WORSHIP
                                Although. Moon worship is founded on the belief that the phases of the moon and the growth and decline of plant, animal, and human life are related. In some societies food was laid out at night to absorb the rays of the moon, which were thought to have power to cure disease and prolong life. Among the Baganda of central Africa it was customary for a mother to bathe her newborn child by the light of the first full moon. The moon was frequently equated with wisdom and justice, as in the worship of the Egyptian god Thoth and the Mesopotamian god Sin. In general, however, the moon has been the basis for many amorous legends and some superstitions (madmen were once considered to be moonstruck, hence the term lunatic) and is particularly important in the practice of astrology.
                                more info in the link
                                also: Sun today — solar flares online
