  • #31
    I just remembered a small info that most people dismiss but through what i have posted; this would make complete sense now:
    Dowsing
    Finding Water With A Forked Stick May Not Be A Hoax
    Usually, the boundary between science and science fiction is as distinct as the difference between the 6 o'clock news and "The Simpsons." Wherever the line blurs, you're bound to find contentious debates. One of the longest-running of these disagreements centers on dowsing, a supposed sixth sense that enables people to find underground water using a forked branch, pendulum or pair of bent wires. There is no scientific reason why dowsing should work. Yet, it apparently works well enough and reliably enough to keep the practice alive.
    The success of dowsers doesn't surprise the people who know the most about finding underground water, hydrogeologists for the United States Geological Survey (USGS). They point out that the United States is so water-rich you can get wet drilling just about anywhere, if you drill deep enough. Far harsher criticism of dowsing and dowsers comes from outside the mainstream scientific community. Two organizations, the Committee for the Scientific Investigation of Claims of the Paranormal (CSICOP), CSI | Skeptical Inquirer Index, and the James Randi Educational Foundation (JREF), James Randi Educational Foundation, are actually working to discourage the practice, which they both dismiss as paranormal nonsense. To make their point that dowsing is a sham each has staged demonstrations in which dowsers were asked to find buried pipes. Dowsers did no better than the laws of chance predict. JREF is so confident of its position it promises to pay $1.1 million to anyone who can "prove" dowsing works.
    Finding Water With A Forked Stick May Not Be A Hoax - Popular Mechanics
    I guess they should pay up
    The Alchemy of Capacitance - QUANTUM AGRICULTURE
    Signs and symbols -Confucius.
    • #32
      Good example of the brain being an advanced fractal antenna.
      Short Description of Dowsing by Raymon Grace from Blue print for freedom video
      YouTube - ‪Short Description of Dowsing by Raymon Grace from Blue print for freedom‬‏
      IndianaBoys
      • #33
        Thank you IndianaBoys
        Very interesting info, It is true that the use of crystal to help tune an oscillator maybe the fastest way of getting results. We do use quartz to run our watches, why not use other type of crystal to help tune a water coil
        You may not know it, but the hidden truth about wearing Jewelery or "BLING BLING" is actually a way for the wearer to tune her/his body to a certain frequency thus allowing her/him to radiate a different type of Aura thus the receiver (ie the person that would interact with the wearer) would subtly receive a different signal than otherwise. (ie: the first 10 sec effect when you meet someone).
        warning: too much "BLING BLING" Makes you look like a Christmas tree (its all in the subtlety, that is how nature works ), and you may get the reverse of the desired effect, overwhelming your own "wave emission"
        Everything in Moderation is the appropriate way of doing it (although easier said than done)
        My kind of philosophy:
        YouTube - ‪Short Description of Dowsing by Raymon Grace from Blue print for freedom‬‏ thanks IndianaBoys
        • #34
          from http://www.energeticforum.com/renewa...tml#post144626
          check out Tourmaline, I thought we could use tourmaline deposited in the receiving bucket's bottom to increase the electric potential and diminish the time it takes for the water to charge in the kelvin experiment:
          tourmaline
          Aetheric Bioelectrical Polymeric-Matrix: A Molecular Resonance Material: "Wizzers blend" Ergonite Polymeric Matrix Material EXD/XHD (read it on the right column )
          Catalyser of Mstate water anyone ?
          As i was searching for info on Tourmaline i discovered a little detail about Tourmaline:
          Tourmalines are the most colorful gemstones found in nature. A member of the quartz family, these stones are a versatile and beautiful stone for jewelry.
          Read more: How to Buy a Tourmaline | eHow.com How to Buy a Tourmaline | eHow.com
          Weren't the pyramids supposedly covered in Quartz to power something or other ?
          • #35
            I have found some quite interesting info, about the use of coils in Homeopathy
            first a review of the various coil I have showed you so far in my other thread http://www.energeticforum.com/renewa...ml#post144803:
            Chapter 5 Methods of Potentisation There are many ways of preparing a homeopathic potency. This chapter will attempt to unify and to relate all of them to the physics of water.The higher frequencies imprinted more quickly than the lower frequencies as shown in Figure 1. This suggests that the potentisation process does not necessarily require energy other than thermal excitation and that imprinting awaits the random arrival of the correct frequency component in the thermal noise to effect a potentisation.
            Figure 3. Interaction between the speed of vortexing and the magnetic field required to potentise.
            5.6 Imprinting with A- & B- fields
            The electric field (E-field) describes the mechanical force between electric charges, a magnetic field (B-field) arises when these charges are moving at a constant velocity, radiation occurs when the velocity changes. Figure 4 shows four coils in which a current flows in the direction of the arrows due to an electric field applied across the ends of the coil.
            The solenoid generates a uniform magnetic field (B-field) within the coil, the lines describing this field pass along the axis and loop around the space outside the coil. Its magnetic field occurs in closed loops and is at right angles to the direction of the current.
            The toroid contains the magnetic B-field within the torus. There is no external B-field but, there is an additional quantity called the magnetic vector potential (A-field) which is in the direction of the current and loops around and through the ring. This field can affect the phase of the wave function in a quantum system.
            The Caduceus coil is a solenoid counter-wound back on itself so that the B-fields due to each half of the winding cancel. However, the A-fields rotate in opposite directions and generate a plane wave of A-field.
            Other arrangements such as a Helical Coil or Antonine Rings give more even complicated fields and effects.
            I highly recommend reading the article, it covers a whole range of topic on water and gives us some very valuable data
            • #36
              Within a coherent system, the range of the coherence (coherence length) becomes the constant quantity instead of the velocity. This makes frequency proportional to velocity apparently without restriction, so long as one remains within the coherence length. There can be many velocities each with a proportionate frequency; there can be as many frequencies as there are possible velocities. Frequency no longer has an absolute value, the system has become fractal in frequency.
              As a consequence, effects can occur in many different parts of the electromagnetic spectrum all originating from the same source which might be chemical, biological or electromagnetic. It is this which links effects of frequencies characteristic of chemicals to technological frequencies and through to the frequencies of biological systems ( see my post#20 through 22 http://www.energeticforum.com/136257-post20.html ). It is also the reason why environmental frequencies can mimic a chemical exposure for hypersensitive patients carrying a toxic body-load of a matching chemical. Table 1 shows the fractal frequencies generated by imprinting the optical spectrum from a mercury discharge lamp into water.
              And it respect the fundamental law of:
              the Constructal/Fractal law of nature:
              The constructal law puts forth the idea that the generation of design (configuration, pattern, geometry) in nature is a physics phenomenon that unites all animate and inanimate systems, and that this phenomenon is covered by the Constructal Law stated by Adrian Bejan in 1996: "For a finite-size (flow) system to persist in time (to live), its configuration must evolve such that it provides easier access to the imposed currents that flow through it[."
              Tree frequency measured by Farmhand the system has become fractal in frequency.
              Along the same line:
              the system has become fractal in frequency May be the key to all our research, I truly believe this is a major step forward.
              so excited that i found this info ....
              • #37
                From Brain Waves to Mathematics of Fractals
                - The beauty of numbers behind irregular functions
                - (ppt presentation)
                just search fractal brainwave and you will find a loqd of info on this
                Computational Modeling of New Kinds of Fractal Antennas and
                Fractal Frequency-selective Structures Based on Them
                Abstract| Authors' realized modeling of two kinds of fractal antennas with similar structure, but different algorithms of development. The first antenna geometry is a figure "Life Flower" and the second one is series of crossed circles nested to each other. The obtained results were analyzed and conclusion of the practical applicability for these antennas was made. The obtained theoretical results allow us to conclude that synthesized fractal antennas have multi-band and wide-band features. Besides the direct usage, such fractal structures performed on micron-level may reveal an application in a wide class of new fractal frequency-selective materials and surfaces. The applicability sphere of fractal antennas in modern technologies was shown: cellular communication, wireless information transmission and reception, and radar location devices. Also application filed was described for fractal antennas in modern technology: cellular communications, wireless receiving and transmitting information devices, and radar.
                Remember : the collapsible bladder (from http://www.energeticforum.com/144601-post122.html ), it emulates your heart...
                the collapsible bladder (it may facilitate the creation/concentration of ORM in water ex:your heart ):
                YouTube - ‪Innovative micro hydroelectric turbine‬‏
                Though in video water flowing from tap is shown it works same way if there is a reservoir at starting of the collapsible bladder and if small pipe is connected to it.
                Clearly the processes of suction and pressure need to be examined.[ No beneficial, natural exchange can take place solely under conditions of pressure. . Viktor Schauberger
                Remember what Tesla said:
                Experience is made before the law is formulated, both are related like cause an effect. Nicholas Tesla
                ...once the blood leaves the heart, the arteries does something that actually i have been discussing for a while:
                Vortical flow structure identification and flow transport in arteries
                1. Introduction
                Our interest in vortices arises for two reasons. Firstly, at moderate to large Reynolds
                numbers (at least 100) which characterise flow in larger arteries, vortices are quite
                persistent. The presence of vortices in a flow may exert a strong influence on its behaviour, although tracking vortices may be difficult as they can evolve rapidly. The effects of vortices or vortical structures are particularly evident when considering both flow stability, and the processes of mixing and transport by the flow. The object of this paper is to examine the dynamics both of vortex motion and of particle transport in arteries, and to relate these to parameters such as geometry and unsteadiness. The Lagrangian particle tracking and the vortex dynamic techniques which are described should help in understanding arterial fluid dynamics and suggest new approaches to modelling.
                ps: if you think about it your body generates its own Mstate Water
                • #38
                  Human Resonance
                  Standing Wave Resonance Reflected Throughout the Cosmos
                  The Universal Om generates standing wave resonance within all cosmic and atomic bodies; in galaxies, quasars, the Sun, Earth, Jupiter, Uranus, Saturn, Eceladus, Titan and Pluto.Infrasound pulsations are reported onboard the Int'l Space Station and in the Van Allen plasma belt.Atomic decay rates of radioactive elements fluctuate in synchrony with infrasound from solar flares.
                  The electron is comprised of nonlinear standing waves revealed by quantum stroboscope imaging.resonant atomic transmutation achieves total conversion of copper into silver, gold and platinum.
                  Scientists believe that the structure of liquid water consists of aggregates of water molecules that form and re-form continually
                  so this is your adaptive fractal antenna (Liquid Antenna), and the adaptive part comes from the hydrogen bonds
                  H2O - The Mystery, Art, and Science of Water: Facts
                  Triple point of water
                  side note
                  From the info I have posted so far (and if you do a little research ), you 'll see that there is a trend that appears, and that is for every fractal structure you have seen in nature/universe, the presence of water comes hand in hand
                  • #39
                    Humans Could Have Geomagnetic Sight
                    Humans Could Have Geomagnetic Sight | Wired Science | Wired.com
                    • #40
                      MODELING WATER MOVEMENT IN HORIZONTAL COLUMNS USING FRACTAL THEORY(1)
                      Fractal mathematics has been used to characterize
                      water and solute transport in porous media (Arya et
                      al., 1999; Pachepsky et al., 2000) and also to
                      characterize and simulate porous media properties
                      (Anderson et al., 2000)
                      . From a non-fractal perspective,
                      the position of any volumetric water content within a
                      porous media column can be characterized by:
                      x = λ(θ).tn (1)
                      where x = Vertical distance within the column [L], λ
                      = Boltzmann variable [L T-n], t = Elapsed time [T], n
                      = Time exponent, and θ = Porous media water content
                      [L3 L-3].
                      Similarly, the process of one-dimensional
                      infiltration of water into a uniform soil as a function
                      of time can be characterized by the Philip (1957)
                      equation:
                      I = S.tn (2)
                      where I = Cumulative one-dimensional infiltration [L],
                      and S = Sorptivity [L T-n].
                      In both (Equations 1 and 2) the time exponent (n)
                      was fixed at 0.5 (Clothier & Scotter, 2002). However
                      in fractal characterization of water movement
                      processes in the soil, the time empirical coefficient
                      was estimated statistically, along with other hydraulic
                      properties (Guerrini & Swartzendruber, 1994;
                      Pachepsky & Timlin, 1998).
                      A Fractal Model of Mountains with Rivers A Fractal Model of Mountains with Rivers | Mendeley
                      As I said before, water is a fractal adaptive antenna and
                      The human body is about 60% water in adult males and 55% in adult females. that 's one big antenna inside you, don't you think?
                      The water molecule is not linear but bent in a special way (synergetics) . As a result, part of the molecule is negatively charged and part positively charged
                      The holy books of the Hindus explain that all the inhabitants of the earth emerged from the primordial sea
                      according to this legend, i could say that water is the master template of Nature, (think of it as the database from which nature picks the correct template to create life )
                      FYI:
                      Music and Geometry:
                      Standing Waves form Platonic Solids
                      "In 3D standing waves, a structure, with all characteristics of a platonic solid, is formed for each standing wave mode. Within an atom, which is the building block of matter, the platonic solid is not formed by salt or known particles, but by electromagnetic waves in vacuum.
                      Both the students of Buckminster Fuller and his protege Dr. Hans Jenny devised clever experiments that showed how the Platonic Solids would form within a vibrating / pulsating 3D sphere.
                      link:
                      Vibrations, Harmonics, Resonance, Waves and Reality
                      • #41
                        When Rich was asked how UFO propulsion worked, he said, The questioner responded with, Rich then said,
                        Extraterrestrial UFO Are Real : Ben Rich Lockheed Skunk Works Director Admitted In His Deathbed Confession |Latest UFO News| UFO 2011 Sightings|Alien Pictures|2011 Solar Flares|Disclosure Project|Web Bot
                        • #42
                          read my latest posts on fractal antenna and resonance in my thread: (also applicable to us humans)
                          starting at post#151
                          In the realm of physics there is a phenomenon known as a 'runaway vibration', and its destructive capabilities is not so much a matter of power or force, but a matter of precision. For this phenomenon to occur you must hit a precise frequency, and remain there for any given length of time (power builds with time at an astounding rate until the vibrating object is destroyed by the force of that power). If you go below that frequency--nothing! If you go above that frequency--nothing, even though you are utilizing more power. If you continue to increase the frequency you may eventually destroy the object, but this is not the same thing as the inherent build up/amplification of power that occurs in a genuine 'runaway' condition. In such a condition it is not unusual for a very small amount of applied power or force to destroy a huge entity! The moment you pass that frequency the destruction stops. If you miss that frequency you miss the phenomena. The basic notion behind all of these matters is that everything in nature has a resonating frequency. Everything composed of matter, or occupying matter is in a constant state of fluctuation, as the realm of quantum physics leaves us to deduce, and if you vibrate any given object at it's resonating frequency, or a harmonic (multiple) of that frequency, it's possible to destroy that object through the kind of power amplification we've been talking about. The vibration being introduced in such a situation is known in physics as the 'forcing frequency'.
                          Fractals: frequency, the heart, and cancer
                          YouTube - ‪Fractals: frequency, the heart, and cancer‬‏
                          remember this formula:
                          E=M3/4
                          It is called Kleiber's Law.
                          It states that the energy needed by an organism at rest (not doing any specific exercise), is not proportional to its mass, but sub-linear.
                          It can be attributed to many factors and one of them is that the more massive an organism is, the less surface per volume it present. If the organism is represented par a sphere of diameter D, volume scale with D^3, but surface scales with D^2. But energy produced by the body is proportional to volume, while energy lost is proportional to external surface.
                          To sum up, a little body loose a lot of heat and its little body can not sustain it. Therefore there is a lower limit to the size of hot blooded animals, which is bigger than the one for cold blooded ones.
                          • #43
                            WATER AND THE SACRED
                            Water is a primordial element which underlays creation myths and stories around the world. The Egyptian Heliopolitan creation story recounts that the sun-god Atum (Re) reposed in the primordial ocean (Nun). In Assyro-Babylonian mythology, first the gods and subsequently all beings arose from the fusion of salt water (Tiamat) and sweet water (Apsu). The holy books of the Hindus explain that all the inhabitants of the earth emerged from the primordial sea. At the beginning of the Judeo-Christian story of creation, the spirit of God is described as stirring above the waters, and a few lines later, God creates a firmament in the midst of the waters to divide the waters (Genesis 1:1-6). In the Koran are the words We have created every living thing from water.
                            Sacred Places: Water and the Sacred
                            compare the two underlined sentences,
                            Originally posted by arKzeRo View Post
                            This looks quite interesting!
                            Stanford researchers have developed a battery that takes advantage of the difference in salinity between freshwater and seawater to produce electricity.
                            Stanford researchers use river water and salty ocean water to generate electricity
                            Best Regards
                            The experiment used water (H2O), methane (CH4), ammonia (NH3), and hydrogen (H2). The chemicals were all sealed inside a sterile array of glass tubes and flasks connected in a loop, with one flask half-full of liquid water and another flask containing a pair of electrodes. The liquid water was heated to induce evaporation, sparks were fired between the electrodes to simulate lightning through the atmosphere and water vapor, and then the atmosphere was cooled again so that the water could condense and trickle back into the first flask in a continuous cycle.
                            Miller–Urey experiment - Wikipedia, the free encyclopedia
                            I would just like to add a post made by
                            Originally posted by blackchisel97 View Post
                            Yes. Particular vibration filtered from entire solar spectrum. I did some experiments with different frequencies of light spectrum and found that they have ability to speed up healing (ectodermal regeneration) as well as penetrating deeper, endodermal layers of skin. This process helps in cases of joint pain, rheumatism and arthritis also, reducing associated pain. We call this a light but really it is a vibration of EM waves. This has been long known and used in treating injuries among Special Forces members and I've seen military reports regarding this matter. Positive effect of certain nm vibrations have been proved and currently used in growing lamps. If we agree that the water is a living form, responding to the magnetic and electric flux (just in case if term Aether sounds too exotic) and we're electrical beings which suppose to live in harmony with nature, than we can understand that water can obtain charge by exposure to certain vibration and sustain this molecular rearrangement. Our body will respond to it accordingly. At least this is the way I understand this process.
                            Also as Fred posted - fluorescent lights produce so called "dirty electricity". Spectrum of high frequencies which are affecting our neurological system and capable of increasing blood pressure and sugar level - especially important for people with diabetes. This artificial frequency adds nothing good that water and we may benefit from. Rather opposite.
                            from: http://www.energeticforum.com/person...tml#post137156
                            • #44
                              FYI
                              Superconductivity in DNA
                              it insulates, it conducts, it superconducts. This molecule does it all!...
                              ...xperiments have demonstrated that DNA exhibits rare superconducting properties similar to those of carbon nanotubes (Kasumov et. al., 2001). By depositing long DNA molecules across a 500nm gap between special electrodes, scientists were able to apply voltages to the quantum wires and measure their conductivity at various temperatures. While most molecular wires become insulating at low temperatures, the DNA exhibited an increased conductance. Superconductivity refers to a complete loss of electrical resistance, and DNA is normally not a superconductor. However, by connecting it to superconducting electrodes the scientists were able to induce superconducting effects when the temperature was lowered to 1 Kelvin and below, hence the term "proximity-induced superconductivity."
                              ps: the double helix DNA is also a Caduceus Coil
                              the first pic at the bottom looks like a chromosome don't you think
                              • #45
                                Isn't he describing this:
                                Just wanted to post this info because its representation is nothing more than a Fractal representation:
                                Multiverse = Many Worlds, Say Physicists - Technology Review
                                Enjoy
