The electricity is hidden in water and when it comes out, it spreads light and provides energy(R.V 1-16-5).
Taoist Seasons - Winter - Water Element
The three months of winter are called closing and storing.
This is the winter compliance of chi
and the cultivation of the Dao of storage.
To oppose these principles injures the kidneys.
(Consequently) spring will bring paralysis and fainting
(and) there will be little to offer one's sprouting.
(Nei Jing Chapter 2)
Why is static electricity worse in winter other than the air is drier
You get a shock when electrons move from a negatively charged surface to a less negatively charged surface. You see a shock then the electrond flow through the air... and ZAP... you feel it too.
The electricity has an "easier" time moving though the air when it is dry, so you need less of a charge to get a shock. When there's more moisture in the air, it's tougher!
Answer
It's the other way around. Moist air conducts electricity better than dry air, so charge bleeds off quickly. When the air is dry, the electrons can hang around on your body for a long time, charging you up to thousands of volts. That can last until you touch something that can conduct them away, like a doorknob or your significant other.
Electronics manufacturers have a devil of a time with static jumping onto sensitive parts and damaging them. Electronic assembly areas typically have to keep the humidity above a specified level (maybe 40%) to reduce the charge on the workers.
Answer
see also : My version of Kelvin's water droplet battery - YouTube
.jpg)
