I did more experiments this morning.
I added an additional diode in series with the first and increased the value of the resistor. Now the resistor is much larger, say 8.2kOhm and the idle current is much smaller, 280mA. Also in the 10MHz range the waveform appears blurred a bit for some reason... When i set the signal generator to 5Vpp, the sine wave is blurred in 10MHz. Also at 20Vpp in the same range the sine wave is blurred. Only at 10Vpp the sine wave appears normal or less blurred than before. From that point on there is a blurring of the waveform and because of this i don't think the amplifier can go any further.
Previously the idle current was way too great and the waveform was very good way after 10MHz. Now At 1MHz the sine wave is a bit bent towards right, an almost imperceptible bend, the idle current is much more acceptable and so the heating of the heat sink/.
