Water Sparkplug
This topic is closed.
  • ground lead
    Originally posted by xpskid View Post
    Way cool Greg !
    Looks like your ground lead is sparking too ! Be Careful !
    All electronics really run on smoke not electrons, and it just a matter of time before you let it out. Mike sprung a leak in his inverters and let all the smoke out.
    No no. That's the reflection of the spark plug on the side of the coil. Nothing is arcing except the plug and the coil secondary ... sometimes. What you think is a ground wire is sitting a full inch off of the coil in the foreground.
    Greg
    • Greg
      Is there a version of your circuit that I could use on my 10HP generator?
      It doesn't have a coil or distributor obviously but it produces 110v that I want to feed back into the circuit once it's running.
      So I'd use a 12 vdc battery and inverter to get it running. Then have a manual switch that would take the battery & inverter out of the circuit and add in the 110 v ac from the generator.
      I plan to have an external timing & switch gear setup similar to what Jetijs has to use for eliminating the waste spark and allow easy access to timing changes. I plan to combine water and HHO in the intake so I have to eliminate the waste spark.
      I was thinking of something along the lines of 2 switches (maybe), 1 to charge the capacitor and a second to release it to the spark plug.
      Both switches would be on this external gear.
      But I'm not sure how to go about changing your circuit to work without a coil and distributor.
      Any ideas would help.
      DonL
      Don
      • Mirror, mirror
        Originally posted by dllabarre View Post
        Greg
        DonL
        Hi Don,
        That's exactly what I'm doing too. Did you see the picture of my 2:1 gear reducer on my generator set?
        The picture is at:
        The plate with the slots is the timing plate and that will have the reed switches for the charge and discharge components. The driven gear will have the rotor with the magnet on it. I'll eventually go to Hall or Opto but for now it's reed switches.
        All of these systems that use inverters have a potential 'speed limit' because of the 60 Hz. You can reach resonance. I solved that with my latest Mod. The first diagram is the original circuit using an isolation transformer plugged into the wall. The second diagram is for multiple plugs but shows the swap out of the charge Triac with a power Mosfet package with integral opto isolated trigger. It is a Crydom D2D12 ... 200VDC & 12A - expensive $60.00 ... I didn't want to design any of the trigger electronics for a cheap Mosfet so I used the Crydom. Never allow the charge and discharge components to fire at the same time or you'll have a Crydom paperweight. Once the reed switches were too close together, I set a magnet down near them and bzzzzz - pooof "@#$%!".
        I don't recommend building any of this ... blah, blah, blah, but if you do use the first diagram with the swap out of the second. The third diagram is the equiv. circuit of the second diagram. And you can use long strings of cheap 1000VDC-3AMP diodes (like everyone else) instead of the expensive NTE517 I use.
        Peace,
        Greg
        • Nexus replication
          Hi everyone
          I have had some success with the nexus circuit , I followed the schematic except instead of 60 in5408 diodes used 3 parallel strings of 7 also used a full wave rectifier on grid power and a 25uf capacitor (start) , It produces 1/4" spark .In 6 hp test engine ran well until spark plug center electrode and ground electrode fused together . Will try with hho addition this weekend.
          Will
          • The Nexus PDF 09|18|08
            Originally posted by Wilber View Post
            Hi everyone
            Will
            Congrats Wilber Keep us posted on the HHO tryout... exciting!
            @ all
            This is a cut and paste from Bill/Nexus .pdf.... just the verbage... I don't know if it's been updated since he first posted but I post it here as reference for the thread.
            The Nexus Plasma Arc Circuit
            Copyright © 2008
            All information is hereby released into the public domain for public use.
            "Ere many generations pass, our machinery will be driven by power
            obtainable at any point in the universe. . .it is a mere question of time when
            men will succeed in attaching their machinery to the very wheelwork of
            nature." - Nikola Tesla
            What follows is what I did. I don’t recommend that you do it. It’s dangerous. So don’t do it. But if you do and you (or anybody in your vicinity) gets zapped, it’s your own fault. Read Everything, then read some more - - - -
            The inverter is physically and electrically isolated from vehicle ground. Because of this, the only path for 120 VDC is through the dipole created across the spark plug gap.
            OK, the Nexus hot wire is connected directly to the engine block, but it’s relative. Just don’t use your inverter for making coffee.
            120 VAC from the inverter is directed through a MOT (microwave oven transformer) primary to a half wave rectifier.
            The MOT secondary is not used. A MOT secondary has one side tied to the transformer core, so I placed a wire nut on the secondary HV output
            and gave it a few coats of tool dip – just to make sure.
            Without the MOT in series with the input, the plasma arc shoots out two or three inches and welds the anode and cathode of the plug together in short order.
            So if you decide to disregard my advice and play with this, be careful.
            The MOT can easily be configured into a saturable reactor, which should allow for variable control of the current.
            The diodes are all 1N5408 rated at 800V and 3 amps each. They are available through
            Newark: http://www.newark.com/58K9608/semiconductorsdiscretes/
            product.us0?sku=fairchild-semiconductor-1n5408&_requestid=75114
            for a very reasonable cost – like 150 diodes for around twenty bucks. Newark provides quick shipping and excellent customer service.
            The capacitor is 12.5 uF, 250 volt and was taken from the same microwave as the MOT. I don’t think the capacitor values are critical. It’s just in there to keep DC from going away for half an input cycle.
            The negative side of the rectified 120 V is directed through a string of diodes sufficient enough to block the ground path through the circuit that the HV from the engine coil will see (remember, nearly anything looks like ground to HV).
            The lazy HV will take the easiest path, you know. This will vary with the application. Too few diodes and we don’t get a spark across the plug.
            I have two strings of 60 diodes in parallel to provide 48KV of blocking at 6 amps current. I don’t need two strings because the max current I’ve seen through the Nexus circuit is quite a bit less than an amp even with a two inch arc shooting out the plug.
            I’m running four plugs in the VW camper van, and all those anodes are connected to the same dipole feed wire from the Nexus supply, which results in spark plug cross fire.
            To eliminate crossfire, I installed 7 diodes in series with each individual dipole feed wire. The dipole created across the plug gap creates a nexus to the void – but you knew that, right?
            That’s where the energy comes from, and that’s why the current drain on the
            Nexus supply is so low. I can explain all this (from my perspective, of course) if you’re interested, but before you ask, you should resolve the question:
            What has less resistance than a short?
            If you understand the dipole and the nexus contained therein, you’re on your way to even more interesting things, like free energy from magnets, what E=MC2 really means, what happens after we ‘die’ and much more.
            Yeah – it’s all very simple. That’s it. Let’s work together on this. I don’t do politics, but it would be nice to get out from under terrorism and back to a free country again.
            So, if you make improvements, please share them with everyone so we can get off fossil fuel. I’ll be happy to post your links to relevant stuff and we have a forum that you’re welcome to use.
            • Hi all
              Today I made some more tests with the voltage quadrupler array. I found out that the circuit I posted yesterday is wrong. Here is two circuits I used today:
              Circuit A is exactly what I used yestarday and if the variac was attached to the red wires, the RPM's increased. I measured the RPM's on my bigger reductor wheel, but there is probably a mistake in the laser tachometer readings, because if the bigger wheel rotated at 5k RPM, that means that the reals RPM's of the engine should be 10k and it just did not sound like it was going so fast. Anyway, when I used circuit A, I had to attach the red leads to the variac for the RPM's to increase. I noticed, that every time I did this, the small voltmeter needle on the variac jumped a little. Then I tried to short the read leads using a screwdriver, a small spark appeared when shorting the leads (not like a HV spark, more like an ordinary spark from shorted LV capacitor) and the RPM's increased again. That means that the coil in the variac does not make any noticeable difference.
              Then I tried the circuit B and when I started the generator engine, the RPMs quickly jumped to the same value as with the circuit A and shorted red wires.
              Interesting indeed
              • Thanks man, ill change the doc right now, that variac video made me run up a tree, this combined with the spark gap experiment, shows that there is more going on here then the laws can explain, the panacea spark video is being filmed next weekend, we have a solid state 555 timer circuit to add too, you have inspired us and Luc, ground loop and Greg and ALL to run the genset with the smacks and a circuit..will have it edited and done next week guys.
                This is what we need, practical do now energy savings and OU R and D.you guys are the best, and deserve grants, public awareness/thanks that's why my none profit org started. you guys are elite.
                KEEP GOING!!! WE ARE CLOSE!
                sincerely
                Ash
                • This HV reaction in the compressed combustion
                  chamber is not healthy to the engine. The piston
                  is aluminum, 275 degree melt, crumbles, destroys
                  everything.
                  You are going to have to deliver pre-ignited
                  compressed HHO, not pre-ignited H20. To do this,
                  you are going to need ultrasonic H20 vaporiser
                  with vapor injectors, not liquid, and no massive
                  sparks. Meyers device appeared to do just that,
                  to take a quantity of water, ultrasonic convert,
                  and then inject.
                  Meyers device is a converter/injector!
                  The Truth Will Set You Free,
                  SM
                  • Nice Vid.
                    Way cool Greg !
                    I think that was the reflection of the spark plug off the coil.
                    • Hi all
                      To solve the frequency problem I searched all over the web for already commercial available dc to dc step up converters but with no luck. So I decided to use my trifilar coil form a Bedini SSG and make it into a self oscillator with the third winding used for charhing. This way I can step up the voltage from 12v to 350V and the trifilar coil acts like an isolation transformer in the same time. This setup can charge up three 450V 100uF caps in series to 350v drawing 12v 0.4A form the battery. I did not connect a scope to the transistor, but form what I hear, the switching frequency is in the KHz range. Here is a Bedini self oscillator circuit I used:
                      To increase the frequency and lower the amp draw, you can increase the base resistor. I used 1K, but it heated up quickly, so I switched to 4k and everything seems to work fine now and the amp draw dropped to 0.1A
                      Jetijs.
                      • Hey Wilber,
                        That's awesome news!! After all the trouble I had with it yesterday, could you PLEASE post a pic of your circuit setup so I can maybe figure out where I went wrong in my circuit test. I would really appreciate any description of how your circuit is wired up exactly. I too intend to try to use this, or similar, circuit in conjunction with HHO on an engine. The sooner the better! I tried using a full wave bridge yesterday too, couldn't get mine to work any different than using the half wave. All the different schematic variations are kind of confusing to me, as new as I am to electronic circuits and all. I really like the "gmeast" circuit as well, I may also build one of his for testing. Thanks in advance and CONGRATULATIONS on your progress with this Nexus circuit. Hopefully we will all have a working model soon! Later.......................Mike
                        IF IT DOESN'T EXIST, CREATE IT!!!
                        • Jetijs
                          WTG!
                          Nice progress!
                          Please post your detail componets and include the number of windings on each set of wires in your trifiler coil. What type of coil did you wind your transformer on? Paper coil? ferrite core or rod? toriod?
                          Thank you for keeping us all posted.
                          DonL
                          Don
                          • Just looked up the tracking number from UPS, my 1N5408 diodes will arrive today!! Looks like the rest of my day will be spent soldering together diodes. Just a wierd thought, will this Nexus circuit even work on the bench Or does it have to be hooked up to an engine for the circuit to perform it's assigned task? Just thinking out loud. Bill never did operate the circuit in his video except with the engine already running, hmmm..............
                            • arc
                              Originally posted by CPU3rother View Post
                              Nice Vid.
                              Hi CPU3rother,
                              Yup, That's exactly what it is ... a reflection.
                              Thanks. Peace,
                              Greg
                              • Originally posted by jstadwater View Post
                                I believe that the circuit requires the engines ignition system in order for it to work properly. Don't quote me on that though. I still have not completed my circuit for testing. I plan on testing it on a vehicle with a single plug first, and then if it functions as stated, I will build the cross talk preventer and implement on all cylinders.
                                LapperL
