Steam injection on standard ignition
Hi Greg,
I plan to build a steam injection on a standard ignition and standard spark plug. The system will be a mist water create by a high pressure water pump that spray/mist water to a water reservoir. It will make a very fine water particle in the air part in this reservoir (the reservoir filled only in half of water). The water vapour/fine mist will be sucked to a line thru exhaust manifold and then to the air intake (after the air filter). I thought this system will introduce hot steam to the engine (with standard ignition system) in small volume.
Do you think it will work to add MPG ? I mean, on just standard ignition system instead of krupa's like plug even a plasma ignition ?
Rev.
PS: I will post the picture after completed it.
Hi Greg,
Rev.
