  • Thanks Sniky, I will try one, I've got three to get it to work otherwise I will have to wait till I order some.
    Originally posted by sniky View Post
    the 4 pins halls are
    +side output 1 output 2 GND
    you can use only one of them and will work
    when output1 is on , output 2 is of and viceversa
    (this is for alternate Poles)
    Visse, Thanks for the heads up on that. i will spend the time I have right now on the timing wheel. No one said if a infrared switching device would work or not??
    Mark P
    Mark. You should not use that circuit as I could not get it to work yet.!!
    Rather try the solid state relay circuit for now as Matt got it working real well.
    Vissie
    Today 03:53 AM
    • Coils
      While I experiment and probe around these shaped fields with the single coil challenge, I'd like to slowly work on the three coil set.
      Does anyone know of general guidelines for coil to core ratio ?
      IE: Coil length / Core Length of approximately 1: 1.66 ???
      Timm
      • Big Bedini Machine
        John Smith,
        I guess the meaning is not understood by you.
        I said if you live in the northern hemisphere the rods going through the coil core would extend 3 inches past the south pole or the base of my coil. Why did I say this because of where the energy intersects in the coil. If you live in the southern hemisphere then your rods would extend towards the north pole magnets or the top of the coil.
        The shield is then adjusted to the Bloch wall. You must learn what it is that your looking for before you build anything or failure is in your path. I have told everybody to watch the movie at www.144.com for a reason.
        I also said that you must drop through the Delta Zero to gain the energy, or what termed mass-less charge, mass-less charge is what your collecting. If you watch that movie and understand what is being conveyed to you, you will understand why the 16 poles around the wheel and the axial motor has ten poles, Ring Twice. you will only find magnetic streams and when the imbalance comes you get current to charge the batteries. (in another post here )
        ( Aaity is a saint. She is my good friend.Time spent studying her work could not be better spent.)
        We will ask you to work with energies that are invisible to you. Even as they are invisible you can see their shadow effects. Be patient with us and with yourself and all will be clear to you over time. Read as much as you can, then rest. Let the concepts be taken into your center.
        ALCHEMICAL MANUAL
        FOR THIS MILLENNIUM
        "She is right all energy comes from the Bloch wall", look at her drawings.
        As I said before this machine is to advanced. look at the three coils what do they make up? So why do I need any switch on the output?
        It's possible you are on the wrong planet .
        And I'm not screaming just running out of time.
        John B
        Originally posted by John Smith View Post
        Hello all
        Just had a thought...dangerous I know but....Here goes....
        John Bedini stated at the CDA conference that the North magnetic pole is the dominant pole...I accept that.
        Well it occurred to me that in the Northern Hemisphere I can see the reason for this being the case as the North pole of any magnet is closer to "The North pole" in the northern Hemisphere so the dominance is easy to see.
        Does it not stand to reason then that in the Southern Hemisphere that the South Pole of any magnet would be the dominant pole?
        If so....would it be fair to assume that those of us at the bottom of the globe would either have less efficient machines or could we have the same efficiency by building our machines with the south pole facing outward.....??
        Hope I am not on the wrong planet here...
        Just my 2 cents worth
        Thank you
        John Smith
        John Bedini
        www.johnbedini.net
          Here is the movie: YouTube - The Secret of the Universe 1 of 6
          • I got a fet pulsar to work on a 12v system. The circuit is between the 2 negatives. It dumps the cap (14500uF) when it reach 25.2V. The caps in parallel with the opto led and the gate , determines the on time. Without them the circuit will not work. The pulses are 1.5A nearly twice a second but that depends on your input which is the real important part of this thread.
            The fet needs a heatsink and for bigger systems we need to put more fets in parallel like in John's patent and we will have to clamp the gate voltage to 18V some or other way.
            I will post a short video later.
            Here is the diagram.
            John please let me know if you have something else in mind and some clues maybe.
            This is not as impressive as the one Matt showed.Only 12V. Cap disharging at 25V
            YouTube - Picture.avi
            • Code 144
              • Timing
                Jeremy,
                You are correct except your a little off on the outside coils as far as spacing goes.
                But with a little adjustment this will work, past TDC 23 DEG. When adding Iron you cause a resistance/delay in the magnetic field. you can cause non liner action in the field emitted. Good drawing.
                John B
                The speed of the machine is also not important, it's the overlapping of the switching that is important in the dwell angle. This is equivalent to a car distributor and it better be set right.
                Hi John
                I cannot understand how we must trigger 23 deg atdc if the magnets are only 22.5 deg apart. This is very confusing for me. Could you please try and explain this to me?
                Vissie
                  Hi John
                  Vissie
                  Nvisser,
                  I could be well wrong about this but could it be that the trigger is at 23 degrees due to the lagging effect the iron puts on the electromagnet. Since it wouldn't be very much I can see it being only half a degree of a full rotation and thus 23 degrees.
                  Just my two cents.
                  Raui
                  Scribd account; http://www.scribd.com/raui
                    John B
                    The machine I do beleive is too advanced for me at least at this time, but I am going to continue and learn all I can.
                    I have been researching Ed Leedskalnin and his work as well as finding all I can about the Bedini/Cole switch...parts ordered.
                    I have started work with hall switches and will adapt these to my current ssg.
                    As for the rest of the ferris wheel circuit, I still have much to learn.
                    But I will take a shot at what I am thinking.
                    You may not need a switch on the output as all the energy is stored in the coils (as in Ed's U-bolt magnet design) and it gets dumped to the caps after the magnets leave the cores of the outside coils. The center coil has just pulsed and following very quickly the outside coils cores are covered by magnets, all energy is contained in the 3 coils as they are all tied in parrellel, once the magnets leave all energy is released.
                    I will stress that I have no where near enough to work with yet, still learning.
                    Thanks John B. for all you have given
                    Bill H.
                    • Originally posted by Bill H View Post
                      You may not need a switch on the output as all the energy is stored in the coils (as in Ed's U-bolt magnet design) and it gets dumped to the caps after the magnets leave the cores of the outside coils. ...............
                      Bill H.
                      You'll get more energy to your batteries overall by using the cap pulser on the back end.
                      I can detail the explanation if needed.
                        Please explain Matt because with the testing that I have done I have not found that to be the case. I have found when charging batteries using a solid state oscilator they charge quicker without a cap pulser on the back end. Is there a certain ampereage or discharge rate that works better than others?
                        Mark
                        • Big Bedini Wheel
                          Vissie,
                          For what your putting in it seems it is pulsing right. what are you using to charge the cap a Mono Pole circuit ? The Bedini /Cole switch would be a little different, but you could pulse that with a opto unit instead of the hall. And yes you can use optical switching in place of the hall. Raui is right look again at the timing wheel. Also I think Mathew had a much higher voltage on his cap.
                          John
                          John Bedini
                          www.johnbedini.net
                          • I don't want to get off subject too far. and this just the opinion I am using to to further test at this time.
                            The first thing you have to do is really test a cap pulser. I have been looking at this one for a couple of days now and others posted around, and I am starting to see a pattern.
                            Most of the time people are dumping the full potential in the cap to the battery minus what doesn't come out for battery voltage. This is wrong. You need to stop discharging the cap a good bit before the battery voltage is at an equal. Your switch also needs to turn on and off faster than the switch that is driving the coil.
                            Here in my opinion is whats happening as simple as I can put it.
                            You put a few watts in the coil to charge the coil and then shut it off. The little bit of energy does what it does and heads to the capacitor. The big spike is let loose by the coil and right on the heels of the little charge. They both hit the plates of the capacitor at the about the same time. (Remember spikes move faster).
                            Referencing the cap pulser I showed...
                            If you watch the spikes at this point coming out of the diode at the collector of the transistor they steady increase in size as the potential rises on the plates of the capacitor. This is not because they are bigger but because the load of the capacitor is going away, because it is filling up. The negative energy (Reverse time) in the spike converts to positive energy(Forward time)
                            as the spike hits the plate of the capacitor.
                            Now when the final spike comes into the plate, and triggers the zener, we get a brief discharge of the capacitor into the charge battery.
                            BUT... We also get to take advantage of the spike, that just hit plate, and all the energy it pours out when it converts into positive energy.
                            Its really kinda virtual.(Example only) You've got 1 amp sitting on the plate and you have got 300 volt spike hitting at the same time you open the whole thing up to the charge battery. For just a fraction of seconds that battery is looking at an enormous potential and a bit of current coming at it.
                            Its a doorway. The battery only needs to see potential to charge. And there it is. More potential than you could generate in hour. Sitting right in front of it.
                            Now Pulse more....Simple
                            Thats the best I can explain it.
                            You do not get high amperage pulses if the spike is not present. You do not get high amperage pulses if the spike is out of time.
                            But you do get them if everything lines up.
                            Thats all I know, because that all I have seen while looking at it.
                            I keep changing the timing a bit here and bit there and it always show the same thing. No matter what going into the cap no matter how high the potential on what or amperage is. If it does not line up you do not see that effect.
                            If the relay comes on while the spike showing (on the scope) at the cap you get a big dump. If it isn't You don't. Simple.
                            Now here's the question that is more important.
                            How do you get the caps full and makes dumps often?
                            Well you better start paying attention to your wheel and its configuration. You better worry about making those particular magnetic fields that create VERY FULL SPIKES.
                            And stop worrying about a little "easy to make" cap dumper. Once you start getting the power out of those machines, then the cap dumper can help you get more.
                            • Time running out?
                              John,
                              Curious...
                              Why are you running out of time?
                              This thread is amazing! You are a true inspiration to us all and it was amazing to be apart of the November conference. I will definitely be there in July with hopefully a better understanding of what you are sharing with us. There is so much more than just circuits to wrap your head around. Intriguing how all this stuff ties together!
                              Best regards, Brent
                              John B
                              • So Like john says, why does he need any switch on the output. He doesnt. He also said he fires the pulser 3 times a second I believe. Watching the video, it appears that the bottom coils fire (in parallel) one right after the other, pulsing the next incoming magnet, as the magnetic current flows through the coils. right at about three times per second.
                                So the pulser fires and opens that flood of energy every time the magnets induce the spike in the coil? is the switching for the pulser done at the timing wheel, with the halls, or is is that definitely for the hub portion?
                                I was not able to attend the conference. If I am out of line (or league) by asking here please someone let me know. I am just trying to learn.
                                @John
                                When using the plates to shape the magnetic field of the center coil, does the angle of that plate correspond to the Masonic upside down delta symbol (sacred geometry/square and compass)? Or is that angle there purely due to the outside slave coils length?
                                Watcing the video clip there is a long pulse as the magnet passes over the plate/coil/plate then 2 short pulses as they pass over the outside coils. Correct?
