  • mklimesh
    Bedini S1GT
    Was able to get enough shop time in today to put a shaft in a 33inch plastic wheel and attach 16 magnets to it.
    Hope to get time tomorrow to make the timing wheel.
    Mike Klimesh
  • John_Bedini
    Bedini Big Motor
    John K ,
    Lets start over, The motor I presented in the pictures.
    I said that if you live in the northern hemisphere that the south pole of the coil must extend through the coil, and no do not turn the motor upside down.
    John you live in the southern hemisphere so the pole piece must be extended towards the wheel for the geometry to work with the shield.
    I don't know this device may be a little to advanced to work with here.
    I have moved the pole piece out of the core so that the right angles meet at the shield, so what I'm doing is causing a delay in the magnetic field by closing it in. I said that four coils are wound on one coil form two #15 wires and two #18 wires. The # 18 wires are control wires the two 15 wires are power wires, look up the definition for Mag Amp. understand what a Mag Amp is and how it control's energy, self biased inside the coil.
    The Magnetic Amplifier is a lost art but controlled things very well including power. The side coils are at 1/2 the impedance of the main coil but are nothing more then slaves. When I started this project I wanted to know if ED's theory worked, my answer is it does.
    Now if I control the magnetic amplifier ("Main Coil Center") I can control the power to the main coil for recovery. ( you must have experience in magnetic amplifiers to do it my way but I do not know how many do have that)
    Just build a simple SG with a Bedini /Cole switch and collect the charge then pulse it back to the secondary battery using a reed with a fet while the motor is off. You must also remember I'm an Analog guy not a Digital guy so I'm not doing anything with digital chips here.
    Do not put the bridge on the out side of the switch make sure that the single diode bridge is connected right inside the switch and the wires go directly to the capacitor.
    Hope this helps.
    John
    Thanks John,
    Soething like this? (see pic below)
    John K.
  • uusedman
    Second part of the Machining section of motor done. I took off blades and now I have a nice rotor. The rotor seems to have alot of friction and a little not centered. I need helped of how to clean the rotor and decrease the friction. What is the next step?
    Also, I want to start ordering coils, magnets, and maybe a better bearing/shaft to the back of the rotor to run a large wheel. John, can you pour some of your suggestions?
  • sucahyo
    Do 16 pole relate to 45 degree interaction?
    Precession
  • John_K
    John K,
    You would do the reverse of me your in the southern hemisphere,so your core will be out the top. and your shield would be mounted right to the bottom of the coil touching if you wish..
    John
    Thanks John,
    John K.
  • sucahyo
    He said I have generated more electricity with iron then copper. but The real clue was sweet sixteen and it's about the magnetic streams that come and go. It is depicted in the pictures of how it works but to use it you must create a imbalance in the streams. It's not what everybody thinks it is.
    About the time of the magnetic stream spike with the coil powering, would the magnetic stream spike enter the coil before or after the coil being turned off?
    Or we have to turn the coil off during in between magnetic stream spike?
    coil switch off do not relate to magnetic stream spike?
    I hear you read walter russel, what kind of aether energy is needed by the coil, male or female (south or north)? or is it extreme aether polarity at the coil?
  • Ecoman11
    John B.
    Would your Ferris Wheel work the same way if it was flipped upside down? Does gravity play any role?
    Ecoman
  • John_Bedini
    Big Bedini Motor
    John K,
    John
    Thanks John for explaing that the core goes 3 inches below the shield. So if I were to build a smaller coil (for the first experiment) I would need to extend the core below the coil so that the shield creates an imaginary right angle where the tip lines up with the bottom of the core?
    John K.
  • redrichie
    8 positive and negative connecting magnets/poles? red/blue= pos/neg=north/ south?
  • John_K
    I must say Armagden03 has posted something very important in this quote. However ED may have used it without saying it "drop below zero". Running one magnetic stream agents the other give rise to current in one direction, change it, it goes the other direction.
    The potential across the load gives rise to current and the condition ends up as heat in the machine. Reverse that condition and we end up with cold in the machine. I have not used any heat sinks in this machine.
    Did anybody touch the charging batteries as they were being stressed to max, no heat. The large wires were used to lower the impedance of the DC on the input, the output were much smaller wires because it did not make any difference. One other question answered. The shield is adjusted to right angles as that indicates the Bloch wall of the big coil in the north hemisphere the south pole is extending below the coil by 3 inches for a reason to gain that right angle. so the cores goes right through the shield. I have debated with Aaron on what I would say here, time to see what your going to build.
    John B
    John K.
  • John_K
    THE SUN 16 POLES. What do you see in the center?
    John B
    John,
    The "neutral" zone, or where all the aether energy enters (magnetic particles) and couple to form a North or South pole. The Bloch wall if you will.
    John K.
    P.S. Enjoying the challenge and making me think.
  • John_Bedini
    Big Bedini Motor
    John B
    Originally posted by mklimesh View Post
  • Aaron
    Bedini S1GT
    Here is a diagram of the recommended experiment that should be done
    first. I think the 3GT (the 3 references the 3 coils) - I think Tony Craddock
    came up with that name.
    Anyway, with 1 coil perhaps it is a 1GT and S1GT is simplified. Not
    simplified in the same way as the SSG but simplified in the way of
    not dealing with the regauging motor yet.
    @All, it is obvious I don't put food on the table by using graphics
    programs so anyone that wants to put this into a single nice drawing
    full with 16 magnets on the wheel, etc... go for it! In any case, I think
    it is clear enough what the first experiments should be.
    Of course the trigger winding that is partially visible on that coil is not
    needed - so pretend you don't see that.
    @John - if anything needs to be changed for the proposed first
    experiment that you already mentioned days ago, let me know.
    And if the S1GT nickname makes sense.
  • John_Bedini
    Big Bedini Motor
    John B
  • John_Bedini
    Big Bedini Motor
    Armagdn03,
    I know this is off subject but.
    People also speak highly of you. Also I do after reading your posts on capacitors, but boy I could tell you some story's about FM Transmitters with those big capacitors. I know because I had to repair them and had to bypass them during a lighting storms, yes 100000 watt station at 4300 ft. The one engineer blew his fingers right off his right hand. I was left all alone to keep the WW2 Collins on the air. I was running compressed air up the coax because I lost the nitrogen bottle to keep the coax from shorting out. I also got hit by lighting the next day and lived to tell you about it, it blew me right off the tower good thing for safety lines.
    So to everybody that is trying to build this machine you need to figure how I'm switching the power to the secondary batteries, do I have any takers....... forget page 43 I just said you could do it that way.
    Thank you for the post we will talk....
    John B
    Originally posted by Armagdn03 View Post
    Mr. Bedini,
    Here is an interesting quote I thought you might like. The author of it speaks highly of you.
    "Some researchers are looking for a "particle monopole". No such configuration exists, as it is a contradiction in terms. Every attractive or repulsive force has a spherical radius, The center point together with the radial circumference of its force field define a condition of two poles." -Aaity Olson-
    Andrew
