Thank you jonny and joit.
Lidmotor, I am very glad you jumped in here because my coil is just like the one you made somewhere from just the green and red radioshack wire. I used all of both spools and wound them on an empty spool. You counted them, so I was relieved that I did not need to count the turns.
ok good info.
OK I am familiar with that concept from the jtc.
I will try that.
Maybe I am combining things. Did you not get a start-up with your radioshack pack coil and the egg? Wasn't that the very noisy one?
I ordered "your" neos yesterday... soon it won't matter.
umm a battery and a voltmeter connected to what?
This circuit still makes very little sense to me, and I do not know where to put the test equipment.
thank you,
jeanna
edit add
I tried a few things with the scope.
The most voltage I saw while running a neo past the coil was with the core of nails inside and hooked up from the base at the coil to the emitter at the transistor and that was 0.224v. I must not have enough wire.
The coil only got hot yesterday when I used a 12v for source and 9v for charge.
j
Originally posted by Lidmotor
... The base resistance, like Jonny said, doesn't have to be anything but a resistor and it will run.
... See if your drive coil will push a magnet by hot wiring it to a AA. If it doesn't move the magnet then you might have to add more wire.
I use only neos on my motors but of course the snake egg is a Hematite.
On the trigger coil, if you wave a neo by the coil the transistor should do it's thing and work. You can test that with a battery and a volt meter.
thank you,
jeanna
edit add
j
It just looked like magic--- Still does and that is why I keep coming back to it. Spinning magnets are fun.
at the end of this video I clocked it at 23,900 RPM.
