Hertz and magnet spin rpm.
The range of full sine wave AC pulse that will power a spinning magnet in the sound spectrum, is from around 10 Hertz to 10 Khz, The high range Retrod1 reports the magnet spin dropping off. There must be a large dead gap that reawakens at higher frequencies, becaue the full sine wave once again picks up and reactivates the spin up in the coils mega hertz resonance range. Experimentation needs to be done to find out what the lower end of the mega-hertz range is, that the spinning magnet looses its receptivity to the broadcast signal. Does anyone have any idea what the lowest megahertz spin active broadcast frequency might be? I believe it's possible that there may even be more then two ranges, perhaps mimicking some sort of Barkhausen scale, right up into the gigahertz micro wave range. It might be interesting to see what would happen if a hematite ceramic magnet sphere were spun up inside a microwave oven, with a bedini coil in resonance, near the door, then to switch the oven on and see if the magnet accelerates. Wear your helmet for that one!
You are the first i know off to run a snake egg with a quadfilar setup so comparable results may be thin on the ground but your results are very encouraging as it sounds like you are seeing a 50% increase on your output but you would also need to compare the amp draw for both rotors.That said you may be able to increase efficiency further as you are limiting your control over the motor by using just a 1k pot in your trigger circuit if you are using the standard Bedini circuit.I use a 10k pot on my snake egg(100k with the 6mm sphere's) with both air core or cored with welding rods depending on if i want a low voltage/amp draw motor or hgh rpm's with the rods but i see the speeding up effects you see and this also coresponds in a drop in amp draw but there will be a point where charging/amp draw is optimal and a bigger pot may help find it.I think the circuit i use is on the first page off this thread and it also allows for further energy recovery options.
