  • OverUnity
    ive done some tests these days, and for as far as i have seen, most natural things give about 0.5v and some amp,
    all we need is something like cells, cause from a small piece of Patatoe (4example) i got 0.5v, from a whole patatoe i got 0.5v. from a liter of water i got 0.5v but amps i dont know. with tiny drop of water i get the same 0.5 avg. on all materials that contain some liquid, atleast default household things i get 0.5v. so we need smaller cells as our main source, like feeding a Bedini with remains of food, and other natural things
    like Bodkings is doing, is great work (my compliments), and is the same as taking the -energy from our body/earth and hooking it up the right way, that also produces power in negative way, but useable when handled, its all about conduction, and fine tuning.
    in a way i think we all have already produced overunity. but we havent hooked up all yet together, solar, earth,water, fire/heat
    but we have it, but how are we going to use it when we have accoplished it, will we be sadisfied of our good doing, what hapens then ?
    Greets JB
    http://youtube.com/johnnblade
    • First at all Grats to another selfrunner to you, Johnnblade.
      Other Thing, you can try to use Lemonjuice or vinegar essence instead Water.
      Its like a Acid and actually disbands the 'negative' Pole faster,
      what means, more Electrons willl move in a shorter Time, therefor you got more Voltage and Current.
      And actually its prooven, that the Earth is the positive Pole, so you dont take negative Energy, actually you get positive Charge.
      They only did miss till now, to correct the Direction.
      Thats why we have now a physical and a technical Direction.
      Discussion of it. Post #3
      But you see, that at the galvanic Batterie, where your Meter shows '-', it dissapears after all the Charge is gone. Coal or Graphit from a Craftsman pencil are good Potentials too for the 'Pluspole' and you can see, they dont carry really anything, its more like dead Stuff, and they dont change her Volume after using them a long Time for a Batterie.
      With the electrostatic Aspect, i am still not sure, if there will be a different between a galvanic Batterie or a Earthbatterie.
        Hi Bodkins and Gadget----Welcome to Jonny's party! He has a good one going on here. With all these brillant minds at work here we will have the Earth's energy problems solved in just a few days.
        @ Bill---I am with you about where the free energy comes from----I don't care. I'll take it from the earth, the sun, the wind, or EMF out of the air. If it makes our life easier then who cares.
        @Xenomorph & Comwarrior---- The circuit that I am now using loops the BEMF. Right or wrong it seems to work just like you guys found out. It makes for a very low amp draw. The one wire charging is something that I worked with on the Dr. Stiffler's SEC project. It is the AV plug idea. Slayer007 and I played around with it
        @Retrod---Dave I really like the idea of using a signal generator to run this. It would really add alot more control. The question is: How is that degaussing coil wound?
        @Lidmotor-----Yes, I agree, lot's to explore and understand the seemingly complex interactions of the coil, magnet and frequencies. I posted a new vid and show some of what can happen by changing frequency.
        YouTube - Bedini / Davro One Magnet motor with degaussing coil control Part 1
        • Magnetic Suspension
          A test to use a magnetic suspension that a guy on youtube reported to be outperforming even levitation regarding friction:
          Hard to quantify that i guess, but gravity for sure decreases friction and if a screwtip is used the friction area is minimal.
          Video : YouTube - Magnetic Suspension
          A video that demonstrates that the main rotor can also be spinning sideways of the coil increasing the magnetic flux change inside the coil area a lot.
          YouTube - 90 degrees axis
          • Earth charging
            @Bodkins: I have no success with the one wire cap thing connected as in the diagram i posted before with the earth wire hooked to the negative of the cap.
            and the positive of the source going to the diode single end.
            Maybe i have the diodes poled in the wrong direction?
            I use a 22000 uF, 63 Volt cap, you use 1.2uF 1200 Volt.
            Does this require a high voltage cap?
            Also since i live in the 3rd floor of a residential building i had to
            be inventive and shoot a 25 m cable down the trees next to the house
            and have buried a galvanized steel ground rod 1m into the ground.
            Maybe the resistance of the wire is too high at 25 m (~0.5mm thick) ?
            Not sure if that matters because impulse technology is more about potential
            than currents.
            What would you say?
            • sorry to here that you where not sucessfull, I was trying today and i think the volt of the onemagnet may be to small for a kickback with one ground!!!
              Im going too post all on the earth battery thread until i get a jonny up and running
              here is a picture to clean things up
              I think the cap is important too!
              • Earth Ground.
                @Xenomorph and Bodkins:The Earth has a posative charge, right? Now, when we attach the negative pole of a Bedini run battery to a ground, power is pumped into the circuit from the ground. When we turn the motor off, the power will leak from the negative pole back into the Earth, draining the battery, unless there is a diode attached between the ground and the negative pole of the battery; right? This has been my experience. Judging from Bodkins drawing of his capacitor, the Earth ground to the negative pole of his capacitor is on the wrong side of the diode. This should work only one way, with the motor running. The second you turn the motor off, there is nothing to prevent the negative pole of the capacitor from discharging it's power back into the Earth, with the ground wire on the wrong side of the diode, right? Perhaps this has something to do with xenomorphs' operating failure. It might help to start the motor with a battery in the system, then switch over to that configuration, or simply wire a second diode in between the ground and the negative pole of the capacitor.
                • Well the earth is not optimal outside my house.
                  While digging it i had to realize that there is rubble from a house right under the surface that got hit by a bomb in world war II.
                  So lots of stones and light-coloured sand. (found no bones though )
                  I have filled my 1 m hole with dark good turf, but maybe thats not enough, i am no expert on earth grounds hehe. Its a wonder that so many trees managed to grow on top of that.
                  I realized a change in the cap when stopping the motor indeed, but we are talking microamps here. Hard to differentiate from memory effect-like phenomena.
                  • Earth Ground.
                    Watch out you don't set off any unexploded duds down there. Lidmoter has an [url]www.youtube.com-Earth ground & antenna CFL experiment video on youtube. He has five supercaps between an Earth ground and an Antenna, pumping power into his capacitors. The diode from the Antenna to the positive pole of his super caps is reversed from the direction of the diode from the ground to the negative pole of the same capacitor array. He mentions it did not work the other way around, and that Tesla has an explanation for this. Take note of his Earth Ground to capacitor diode schematic.
                    • Xenomorph's Suspended Magnet Rotor
                      I replicated Xenomorph's suspended magnet rotor and it works really well!! I tried it out on my TOP CHARGER setup using JonnyD's cylinder magnet as the rotor.
                      YouTube - Xenomorph's Suspended Magnet Rotor---My Replication
                      Lidmotor
                      • Tiny distance booster
                        @Joit: thnx for your response, and sharing your knowlegde
                        sofare i have only tested patatoes, and water, and water + salt, i was thinking of mayb placing a small cell container and try to capture rain as a backup source.
                        Hi All,
                        i got all my parts in today, and i could not wait to put it all together.
                        ive been tesing now, (but not wurth of a vid sofare). but my motor doesnt run yet on the Bedini circuit, i can see that my motor wants to turn but then it slows down and stops. next thing i did was place a tube in the coil with a sphere in it, and it allowed me to place my coil more further away(like 3 to 5 cm) from the rotor, cause my main rotor makes the sphere move in the send and receiving coil whereby the pulse get amplified in a way, and makes my rotor now move a few seconds longer. not much but im trying (without my homemade magnetic switches, or adaptor/inverter/acdc coil).
                        so if you maybe got a small tube with a sphere and can place that in your main (Bi)coil - lets see what happens for you
                        im using the same hanging disk as in YouTube - homemade magnetic switch speakerwire 2 batteries part 3 JB
                        but now i have my holder holding the coil, with the tube and sphere in it
                        Q: when you measure yr caps with a multimeter do you hook it up in series or paralell
                        cause sofare i think ive been hooking up my mulitM in paralel with my caps, whereby its like my MM(multimeter) also draws more power then some caps can charge, but when i disconnect the MM and hook it up later again, i get like high voltage peaks of max 13v and going down. when i add the biggest caps that i have it charges more slowly, and it keeps the power more longer
                        so what im testing is i have some caps in paralell. from smallest UF to biggest, its like the smaller caps slowmotioning the high pulses from unloading
                        whereby the big cap hase time to store that energy. before its gone normally without a smaler cap
                        Who thinks about adding a basic stamp chip (Boe-Bot Robot Information) to the circuit, cause since my Bedini Davro/magnet motor project
                        it has all been without coding a chip, while for me im a Coder in life, and i can hook up my Bedini to a chip controlling, or atleast get measurements
                        cause sofare im using my Boe-Bot Robot Kit - Serial (with USB adapter and cable) but only for the bread board i use for for testing in Bedini
                        but sofare with this Bedini project i have seen that i can make a electro magnet motor run in other ways whereby i dont need a Bedini circuit.
                        so i gues this Bedini concept is not as efficient as i thought it would be, but its still a challenge to furfull makin it more efficient untill we all have overunity, and our wife/girlfriend can chill/enjoy of the romantic candles we power with our OU motors :P
                        i had a strange Phenomenon YouTube - Bedini not hookep up rotor magnet turning JB i tried like somany times to get my rotor to spin for a longer time, but while my main rotor stopped, and i saw no volt reading on the MM, my tiny sphere kept on going on for some time, but MM not showing any volts
                        thanks to this strange Phenomenon i had, could we not find a way to make receiving coil more sensitive for collecting power, and then the working/pushing coil to do its default work. cause with these strange progress/ YouTube - Sphere Magnet Spinning with Degaussing coil & function generator. Part (2) (Retrod)
                        and his weird way of less Nrg with his deGausoil. and what happenend to me.
                        its almost like we only need a simple, circuit, and default earth elements, and caps from small 2 big to store , and then in a permanent store for over unity and reuse.
                        i think a fact for overunity, is a running motor without batteries, charging a battery
                        and like coding, we all are OO, when we put it all together like classes, we have a system that works (inc tested till proven)
                        when we do it alone, it works, but not for mass, but we all here have it for mass - when we do like now work together and test as much out of the blue
                        Greets JB
                        • synchro@ its not a postive charge
                          YouTube - Earth Battery (rods)
                          YouTube - Self Running Bedini Oscillator
                          thank you lidmotor for the video, I lost all my old ones
                          YouTube - Earth Ground & Antenna CFL Light Experiment
                          • Finally got it working
                            Hi All,
                            i finally got my Bedini circuit running
                            YouTube - Bedini magnet motor testing new circuit JB
                            in a way the transistor 2n2222 works better for me then the 3055
                            Greets JB
                            • Posative charge.
                              @Bodkins. What do you believe the difference is between the charge Lidmoter pumps into his capacitors in his Earth Ground & Antenna CFL experiment video, and the energy that is charging the capacitors in the energetic forum video? I've been tawt that a capacitor needs a combination of opposite charges to store power.
                              • Originally posted by synchro View Post
                                @Bodkins. What do you believe the difference is between the charge Lidmoter pumps into his capacitors in his Earth Ground & Antenna CFL experiment video, and the energy that is charging the capacitors in the energetic forum video? I've been taught that a capacitor needs a combination of opposite charges to store power.
                                the lidmotor one was potenical difference moving to = out the two.
                                arrons is charging a cap with just one wire negative to ground,is sounds like magic but it works, nothing on the postive.
                                In the Oscillator video he charged the front from the backend but not letting the backend see the front, the backend is negative the front postive. Im still working on that bit
                                The Tom Bearden Website
                                I dont now is all synchro and i dont now how to use it but Im trying
