    Hi blackchisel, thanks for info. Yes I have tried to charge primary cells also and have charged a few, but some pop or simply start oozing fluid out. I wonder if there is a way to modify these to withstand gentle recharging to get more cycles from them, like some kind of reinforcement to prevent the bursting effect.
    peace love light
    Tyson
    With SSG you can change the wave to charge or desulfate -
    this is a charging mode. In desulfating mode, "h" roundish part of a wave will be straight diagonally to the right and down to the bottom. This can be adjusted by changing base resistance (lowering). In solid state version you can adjust discharge timing thus, lowering voltage on dumping cap. For example; if you want to desulfate battery, you set timing for the cap to discharge @ 19 -25V. For charging you can go with 2 - 3V above battery or even less. However, alkaline batteries were never meant to be recharged
    Vtech
    General D.Eisenhower
    http://www.nvtronics.org
    • Hi chisel, not sure if you meant this jokingly as if to say, so they say "However, alkaline batteries were never meant to be recharged", but from what i've read the only difference is because the shell is not strong enough to handle the pressure built up inside and that makes it cheaper to build. Maybe you already know this.
      peace love light
      Tyson
      • That' what I meant -
        Vtech
        • I have a sense of humor too!
          Hi Tyson.
          Of course I was joking. But seriously, if we use a gentle charge without building pressure inside, which cannot escape than we can extend their life while protecting our assets. I want to get small solar panel to power them. Even solid state can be easily run by 12W sp.
          Vtech
          • Hi chisel ,ok I thought you were joking . Makes me want to try and charge some non rechargeables again.
            peace love light
            Tyson
            • I guess pop happen because alkaline based bubble more than acid based just like Bedini video show. This bubble make the battery pop.
              Voltage reading charging gel SLA 12V 7Ah:
              start at 12.37V, using output current at about 0.25A. input current is 0.7A at 10.5V.
              00.00 -> 16.88V
              00.30 -> 18.05V
              01.00 -> 17.71V
              01.30 -> 17.42V
              02.00 -> 17.30V
              07.30 -> 16.49V
              22.00 -> 14.80V
              40.00 -> 13.54V
              50.00 -> 13.47V
              1.20.00 -> 13.46V
              2.00.00 -> 13.49V
              2.23.15 -> 13.50V
              3.17.00 -> 13.50V
              4.33.00 -> 13.56V
              4.55.00 -> 13.60V
              5.24.00 -> 13.66V
              6.05.00 -> 13.79V
              6.34.00 -> 14.55 -> stopped
              12.98V after two minute rest.
              6 hour 30 minutes of 0.25 should equal to 81 minutes of 1.2A load.
              Voltage during 1.2A (9V) load is:
              in the first minute -> 10V -> 9.5V -> 8.0V -> 7.5V -> 9.0V
              05.00 -> 9.40V
              08.00 -> 9.42V
              09.45 -> 12.00V -> at 1.4A, sudden increase of voltage during load???
              17.00 -> 11.94V
              20.00 -> 11.82V
              31.00 -> 11.53V stopped
              change of mind discharging again
              jump of voltage happen again after one minute of discharging???
              00.00 -> 9.25V
              01.00 -> 11.70V
              03.30 -> 11.00V
              08.40 -> 9.25V
              17.30 -> 8.48V stopped.
              charging again
              00.00 -> 13.00V -> 12.94V
              01.00 -> 13.01V
              03.00 -> 13.10V
              11.30 -> 13.18V
              32.30 -> 13.22V
              1.01.30 -> 13.58V
              1.44.30 -> 13.53V stopped.
              Sudden voltage increase during load is weird.
              Good thing previous voltage only charge gone after 1 charge of direct radiant. It seems to also make the battery refuse the charge by climbing voltage at the first hour of charging before it start show normal charging voltage. Second charging has much smaller increase before actual charging.
              On alkaline, just trying some charging. I discharge 2.9V alkaline (two) until voltage during load is 2.20V. After charging for 10 minutes it become 3.2V with voltage during load is 2.70V. I guess this time the alkaline do take the charge. Since 10 minutes store some 0.5V of usable charge, I guess I should never push it to hard since 1.6V is the maximum suggested cell voltage for alkaline.
              • Tuning getting closer
                Hi folks.
                My tuning of John Bedini Solid State is getting better. After numerous changes of pulsing capacitor, finally settled with 2.0MF 400VDC poly cap. Dumping fully adjusted from 0.8V - 190V+ above charging battery. I don't think I would want to approach upper value. I can visualize couple gallons of sulfuric acid allover my bedroom Output current 0.050A on very sulfated battery. Below couple scope shots from my circuit:
                555 oscillator duty cycle
                Oscillating transistor - base
                Switching transistor - collector
                Switching transistor - base
                Vtech
                  Is it true that your capacitor charging frequency is capacitor dumping frequency too?
                  • Scope across battery
                    Hi folks.
                    There is another "step" in the upper wave part. I need attenuating probe. Pulsing 30V over battery. Battery reading 13.2V. Spent another night tweeking
                    V
                    • Hi folks, Hi sucahyo, I noticed your thread over at rcgroups when i was search engining anyone radiant charging primary alkaline cells. Definitely an up hill battle in that forum, notice most replies you received were almost religious and some there seem set on there belief in lack and limitation and you weren't even mentioning free energy or anything. At any rate, I'm radiant charging 3 alkaline C cells in series from my led flashlight and are taking a charge nicely, made a quick test putting them back in led light and is working nicely, brightly lighting the 3watt led. We'll see how these cells work over time.
                      peace love light
                      Tyson
                      • Hi Tyson,
                        Just remember, be gentle with them
                        Vtech
                        • Hi Tyson, I use that forum as a test wether I should ever mention this to rc community here. I don't dare mentioning OU or COP. They think coil collapse current is no different than other trickle charger, while every trickle circuit I found dispose the coil collapse current with either 5 watt (get very hot it seems lol) resistor after diode or worse, just diode.
                          I found that pushing too much current (1A) do not make the charge stay on nicad or on alkaline. I just found out that charging 100mA would also take an hour too for nicad. It also make the charge stay at alkaline. I gues I have to reduce the output current until charging 1000mAh require more than an hour.
                          Hi V-tech, I wonder how fast your transistor CE voltage fall time is? is it in micro seconds, since I see your scope show in mili seconds.
                            Hi Tyson, I use that forum as a test wether I should ever mention this to rc community here. I don't dare mentioning OU or COP. They think coil collapse current is no different than other trickle charger, while every trickle circuit I found dispose the coil collapse current with either 5 watt (get very hot it seems lol) resistor after diode or worse, just diode. Some time ago people believed that the Earth was flat. For some, still is
                            I found that pushing too much current (1A) do not make the charge stay on nicad or on alkaline Battery will take what she needs. If you force energy into it she will eventually die.
                            That would be correct.
                            I work continuously for the past 5 nights. Mainly on this circuit. It would never cross my mind (if I still have any left) that such simple circuit may involve so much thinkering
                              I know what you mean lol.
                              I just charge 12V 7Ah with maximum output of my circuit, 220mA at 30Volt. This also heat up the battery as well. I guess even an gel SLA can heat up too. I think the ideal charging is not related to output current, but also to output signal quality. For my circuit I think it is when the transformer sing the clearest. At max output the transformer sing with some crackling.
                                I just charge 12V 7Ah with maximum output of my circuit, 220mA at 30Volt. This also heat up the battery as well. I guess even an gel SLA can heat up too. I think the ideal charging is not related to output current, I remember John Bedini saying - it's all in the right waveform. Don't get distracted by IN/OUT ratio. I'm trying to find this waveform somewhere to compare.. but also to output signal quality. For my circuit I think it is when the transformer sing the clearest. At max output the transformer sing with some crackling.
                                Vtech
