My First Multifilar
After many, many months of experimenting with my 26" alloy rim no iron setup, and a bought PCB/Coil from rick (basic SSG), 42 cycles later I decided, ok, I will take a shot at a solid State. Especially after seeing soem videos of a fellow who goes by 49er, he really has some copper singing that fellow.
I have since taken his advice, made som modifications, including getting the protection diodes to work, and reducing my base resistors to 22 ohms each, with an additional 68 ohm resistor between my pot and trigger start. This allows for very low hertz operation, when desired.
Next on the list is a momentary switch (with a resistor?) between B & C, for a start switch. My circuit works, but doesn't like to start, easily. Been thinking about winding very fine wire at the end of the coil as a pickup to (even dimly) light an LED as an oscillation indicator.
For me, it's not about FE, at all, it's about the fact these things desulphate. I have a Yurt in the mountains and the eventual goal is to have this desulphate batteries, as they do get "left sitting a lot". This is the start anyway, my battery bank is 20 T105's and 6 Rolls. 1800 watts. Still on 12v.
As I said, I have made some improvements; noted above since this vid. It seems to have no problem charging a 27 series RV battery 100 a/H - and you know, at low amps, maybe 500 mA. So considering there isn't a charger on the market (except maybe at r-charge!) that does that... that's rather unique in itself. And offers flexibility for the "small solar panel".
One of my main goals is figure out how you can use caps to create the stability necessary to run one of these things directly off of solar.
Critique welcome, even harsh critique - I can take it.
Bedini SS SSG 2T - First Attempt - YouTube
The plan was to use #18 on a winds, including trigger this time.
