Reed Switch for SSG motor
Quick question... when charging a 12V lead acid Gel cell (1.3 Ahr) with the SSG motor, what should be the cut off voltage that indicates stop charging? Right now I am using 15V or so (sometimes I catch it at 16V).
I believe a reed switch would have a solid on off type action. Making the rate of change of the current supplied to and disconnected from the energized coil very very fast, and as a consequence the faster the rate of change the greater the voltage spike (radiant). Also a reed switch might have a certain amount of lag time so the time it is turned on might be longer than with the standard SSG motor configuration. With a longer time on state, greater energy could be stored into the electromagnet and thus this in combination with the very fast on off switch action would likely result in a higher voltage spike. Just my 2 cents, which might agree with previous comments.
