Bedini SG
  • Sounds like you got it right.
    As for the magnets, Ceramic magnets are good because they have a large magnetic field, neos whilst they are very strong have a smaller field. with a small neo the gap between the rotor and the stator will be more important.
    • Originally posted by mbrownn View Post
      The gap between core and magnet is less than 3 mm .
      I would like to post some suggestions and alternative things that I used for construction, where do I do that?
      • small problem with ssg
        After initial failure and success, the battery voltage does not rise above 12.99 volts , has been there for a very long time.
        1, what should the input voltage be?
        2, should I discharge the battery and recharge again, or should i wait for it to climb to 14.4 volts before discharging?
        i'm sure the battery was gassing because one of the caps popped and a tiny amount of liquid fell on my hand, i tasted it and it was very acidic. (i know because i had put distilled water in there)
        the ssg is not changing and adjusting resonance anymore, just a fixed constant hum without variation, hence no increase in voltage.
        what should i do ? my ssg is built around a hdd platter, reaching extremely high rpm. ( like it is about to lift off). the centrifugal force is stretching the tape and the magnet are hitting the core at a certain rpm, (tiny 2-3 mm by 1 mm depth, stretching the tape, had to bind it tightly to prevent them from doing that). It goes higher without any load attached,
        3, should i reduce the rpm? how do i do that?
        current drawn is between 70 ma and 170 ma
        voltage produced is extremely high, (got a nasty shock).
        coil winding is above 800 turns,but within 900 turns, (stopped counting when the wire started running out, just wound till it got over)
        do I need to load the rotor to decrease speed?
        i can hear some sounds coming from the battery, high pitched, like something cracking.
        • It sounds to me as if your battery is fully charged on 5 cells and one cell is dead. Check the electrolyte level on all the cells and top up if required.
          Leave the battery to stand for one hour and remeasure the voltage, I expect you will be at around 10v. If so discharge the battery by 10% of its voltage ie down to 9v using a 12v bulb then recharge the battery. Cycling the battery like this may bring back the dead cell.
          The motor speed is not important, just tune it until you get the highest output voltage.
          Sounds from the battery should be off gassing, it should sound a bit like a glass of coke and occurs when the battery is fully charged.
          • Originally posted by sudhirpaul View Post
            Hey Sudhirpaul,
            I'll try answer for ,
            1.) 12V input and a battery works best to match the impedance to the
            input/output of the SSG
            2.) You are correct in that the battery is gassing due to hydrogen bubbles
            being produced and will generate more bubbles at the fully charged state.
            I would discharge down to 12.2V and let rest for hr, then make sure can
            reach 12.99V or higher. (if needed, add more distilled water)
            3.) There is 2 ways that I reduce rpm on my small SSG, the easiest is to add
            resistance untill the SSG will just sustain revolutions.
            The other and more time consuming is increase mass/dimensions until you
            obtain the flywheel effect and thus longer, slow rpm from the rotor and a few
            minutes free spin time.
            I would glue the magnets in place and use the tape as secondary safety
            measure.
            I have charged a drill battery that was gassing and lost charge after reaching
            12V, not the 17V obtainable.
            You have to just replace the electrolyte if you expelled a significant amount
            during the gassing phase you spoke of.
            Zero
            • improvement
              thank you mbrownn and ZeropointEnergy for quick reply
              voltage has risen to 13.44 in 8 hrs. did some tweaking with the pot, to the point where it just starts to self oscillate.
              12 volt 7 ah still gassing (all of them, but 2 are more than the others, caps keep popping every minute, for those 2 cells) waiting for it to reach 14.4 volts. battery is not hot, primary battery voltage is 12.38 - 12.40 for the past 8 hrs.
              thanks.
              I've asked my friends to bring in their old batteries, one battery for me in return for rejuvenating one battery for them, people are agreeing, better than dumping them and polluting the environment.
              one of my friend said that there are 40 batteries in one place, that needs to be disposed, just thinking.......
              this is the first time that i posted in any forum and i think the experience has been a good one, thanks again
              • Nice work
                thanks.
                Hey Sudhirpaul,
                That is great news and sound like you have obtained the desired result
                I have seen a small amount of cold bubbling in the larger flooded cell I have
                RE charged, I used brand new SLA 12V 7AH for initial testing, the results
                were an increased capacitance.
                Great news that you will rejuvinate batteries obtained from people to save
                from recycling or landfill.
                I found 2 Trojan 6V 420AH batteries that were dry and 1 heavily sulfated
                cell and heavy corrosion on the terminals.
                Success, here is a clip of them in a parallel 6V 840AH bank that measured
                2.9V and a conventional charger would not deliver charge.
                After 30hrs they were over 4V, then the conventional 12V 20A charger was
                able to raise them to 6V.
                ‪Dan's Bedini SSGCharging 6V 420AH x2 Batteries in parallel at 200mA .AVI‬‏ - YouTube
                Zero
                • Q about the magnets
                  I have a question about the magnets.
                  Which way must they be magnetized? This is what the shop here is asking me.
                  They can be magnetized in three ways. (front to back, top to bottom, left to right) So which is it?
                  Sorry if this is a silly question, but I only have a part number of the original in his plans, and I don't see which way it is magnetized.
                  ‎"It's all in the MIND"
                  • Originally posted by StweenyA View Post
                    Hello Stweeny
                    the most important thing is to have the North pole facing AWAY from the rotor, and towards the coil core. all magnets on the SSG are North out. you can use regular ceramic magnets for this application, and really shouldn't need to have special magnets made, but either way, it's all North pole motor.
                    hope that answers your question
                    N8
                    The absence of proof is not proof of absence
                    • the voltage was not rising above 13.66, seems to be stuck there for more than 24 hrs,
                      I had the magnets wrong, south of the compass should point towards the magnets! and coil!
                      now voltage is 13.70,
                      upgraded to trifilar, current consumption has gone to 580 ma, from 150 ma,
                      using both the coils offset by approximately 100 degrees . both are firing, independently, (13.71 volts), i'm watching the meter as i type this. (13.72 volts) the speed decreases and increases, and so does the voltage, (13.73 volts), i have a good battery that reached 17.1 volts.
                      @zeropoint
                      how many days did it take for you to desulfate the batteries, could you post steps here, detailed info, from cleaning to keeping it to charge and what you did to them, i have a dialup so unable to watch,
                      thanks
                      • steps
                        @zeropoint
                        thanks
                        Hey,
                        @Sudhirpaul
                        The batteries are still in the process of being desulfated and 1 plate is
                        heavily sulfated with a large crystaline mass about 20x20mm.
                        I hope that will vanish with a combination of charge/discharge cycles and
                        try multi-coil SSG/or a 7 transistor circuit bikewheel as JB utilizes in his
                        demonstrations will completely rejuvinate them.
                        (also, HV low uF cap-pulser to try instead of LV high uF that have in circuit)
                        My process thus far for rejuvinating 2 x 6V 420AH Trojan's L16H:
                        1.) Added demineralized water due to dry plates when found.
                        2.) Cleaned off the corrosion arond the terminals and tested on 12V 20A
                        conventional charger.
                        Battery A = 3.85V and could not obtain charge by conventional means.
                        Battery B = 4.51V could obtain charge at 6V 8A.
                        3.) Connected both Trojan's in parallel and when they settled was 2.9V
                        and charged for 60hrs on my SSG until they reached 4.2V.
                        4.) 24hrs rest, then topped up battery B on conventional charger to 6.9V.
                        Battery A, was charged again with the SSG to work the sulfation from the
                        plates.
                        The unit is tuned ATM to run at 3350-3400rpm @ 200mA with 2 PPM and
                        will have to desolder circuit to lower base resistance for these batteries,
                        but more likely will make a SSG/or SS SSG for this function
                        5.) Well, battery A will need this many times over and still reading up on the
                        best way to rejuvenate such "LARGE" amp hr batteries, and can it be done
                        for 200mA input in a reasonable time frame
                        Hope this answers your questions and ask if more needed, I'm new to SSG
                        technology I build first model 3 months ago, then 2nd few weeks ago.
                        Zero
                        • @zeropoint
                          Have you seen/noticed any change in the white stuff coating the plates?
                          what time frame are you hoping for?
                          I have similar battery and i can see the white stuff in 2 cells. Added magnesium sulphate to try and dissolve it but no improvement .
                          should i empty the battery and fill with distilled water before connecting it to ssg?
                          I was about to give up on ssg, bcoz the voltage hung at 13.77 for more the 6 hrs, did some modification to my setup, and the voltage has risen by 2 volts in the past hour and still climbing, ie 16.14 volts.
                          at what voltage should i disconnect? will the battery explode if left to continue? the battery is not hot, it is a sealed 12 volts 7 ah ups battery. 1 year old . was in regular use, but its capacity had gone down.
                          • Desulfation
                            @zeropoint
                            Hey,
                            On the desulfation process, still a white mass and needs more cycles to
                            remove and I wouldnt leave that in there, empty and refill with distilled
                            water.
                            I would'nt charge a 12V 7AH battery to over 14.5V due to the damage you
                            cause to the battery and if there gassing and boil away the electrolyte, there
                            is no way replace in a SLA battery.(if flooded cell, replace water and hope
                            there is no mechanical deformation of the plates)
                            Zero
                            • stumped
                              what is the all important criteria for ssg?
                              what is the one thing that charges batteries?
                              i joined the monopole group 3, and they say that "mine is a non standard build" and so they cannot help or support, ie tune it, or maintain the tuning, coz it seems to vary.
                              one day it is charging to 17.10 volt and today it is not going over 12.77 volts. every thing is the same, did not make any changes. {later on i did}
                              so again. what is the all important thing?
                              i watched imhotep's video, {here "http://www.energeticforum.com/renewable-energy/2003-free-energy-last-step-step-must-see.html#post19462"} and his is a non standard build doing fine,
                              so from what i understand, it is the collapsing magnetic field, that induces a voltage or spike it the winding, [that is natural] that is tapped and directed towards the battery.
                              if all this is happening correctly, why is the battery not getting charged? {not a sulfated one but a good one that is being charged correctly with a 3 stage microprocessor controlled charger}, even after charging conventionally to 14.4 volts, when it is connected to ssg, the voltage drops slowly to 12.77. why?
                              it is not the wheel material - see imhotep [it is a fan]
                              it is not the magnets - see imhotep [it is not all north]
                              it is not the size of the magnets - see imhotep
                              it is not the shape of the magnets - see imhotep [it is round]
                              it is not the strength of the magnets - see imhotep
                              it is not the free spin time - see imhotep [quite less]
                              it is not the gauge of wire - see imhotep [#30 or something]
                              it is not the number of turns - see imhotep [maybe 100 turns]
                              it is not the use of non magnetic material because 2N3055 is iron! the case is.
                              it is also not the resistance of the wire - see imhotep [40 ohms]
                              it is not the components also, because i changed my transistor to BC547. and the diode to IN4148, ie the base diode, and the hard disk platter spins consuming only 56mA. [ reaching the same rpm as before in a much shorter time!] before is was between 150 - 200 mA, disconnecting charging battery also does not blow the transistor, bcoz the neon is not connected. allowing it to self oscillate also does not heat the transistor, the way i see it , there is no need to use a 15 amp transistor to switch 200 milliamperes of current!
                              OK so i have reached the criteria of the lowest current consumption {56mA} for a bifiler, 850 turns, swg 23 and 26. battery still does not remain at the float voltage with my non standard build, i can even go as far as saying that if i connected an oscilloscope, it would show the exact same wave, that the so called standard builds achieve!!
                              one more thing to ponder here, if this is a current-less voltage charging batteries, then, why do you need trifilar, quadfilar or 10 coils? why else but to multiply current!
                              200mA x 10 coils is 2 amps, the exact amount required to charge 100ah batteries, in 12-24 hrs.
                              somebody shed some light here, everybody Input, i/ we need input!! somebody put your finger on the dot!
                              finally a note to all those who are about to build ssg. the most non standard build is right here in the link above, just get your wheel spinning, nothing else matters, and come back here to see if anybody is taking us to a new level.
                              sorry for rambling on. i just had to get things off and make people think why, instead of just following instructions,
                              • Hmmm, all my SSG's and fans have been non standard. Your circuit must be wired correctly or the thing would not run. the only times i had problems with charging is when the resistor in the trigger circuit was too low. Im not being bad here but did you check the polarity of your output diodes. Another possibility is a partially damaged transistor.
                                I think using multifilar coils is to lower the coil impedance as the impedance matching to the battery gives better results also multiple coils can be used to increase power to match the C20 of a larger battery or battery bank. If the device you are using is poorly matched to the battery it may be poor at charging.
                                A100ah battery would ideally require 5A input but anything in the range of 1 to 10 amps would work, I am using 200mA to charge 60Ah batteries but it is very slow and not good at desulphating.
