3 Battery Generating System
    Majestic81,
    If all batteries are holding voltage you just need to put an additional load on battery 3 to keep it pulled down and maintain your potential difference. Figuring out HIWMUCH of a load will be the problem. Too much or two little and it goes to pot. You have to balance everything.
    Thanks ; getting familiar with the system.
    I am awaiting my 12AWG wire order before upgrading to larger loads.
    Here is a showcase of the battery sequencer board cycling when the source battery goes below 11 Volts.
    [VIDEO]https://www.youtube.com/watch?v=XakAbwHZnqk[/VIDEO]
    • You're making the claims
      When you prove to me that you can turn a rotor with 12 one inch neon magnets on it with a small electric motor past 12 generating coils with over a thousand feet of wire on them as YOU claim you are able to do...(since you have said speed up under load and magnetic neutralization make NO difference) I will drop everything I am doing and prove inputs and outputs. But I already know that you
      CANNOT
      , because such a setup would stop your motor DEAD. The difference here is I have already built this stuff, and you are just talking through your hat.
      I don't know what you're talking about.
      I am just calling you out. Anybody who is skilled in the field and knows what they're doing can easily see you don't know what you're talking about. I am not making claims of incredible performance. Just stating accepted scientific facts. I have nearly 200 years of proof behind me.
      Again, why would I build something I know won't work? You make the claims, you need to prove what you claim. You can't, so you just double talk about irrelevant things.
      Show us the 1800 watt output/300 watt input generator.
      • The system does in fact give extended run times. However I am not sure if you can truly take any battery's stated storage as fact.
        -Altrez
        • In a word...
          Nah. Not gonna show you anything.
          I take that back.
          I will show anyone ANYTHING they want to know about how to build the generator the best way I know how based on having built like 13 different versions so far.
            Get off the thread man ; go harras in your own threat ; some people are building and sharing ; don't wanna keep reading through your garbage / constant disappointment and challenging of Turion.
            • Oh!
              In a word...
              • Silly Season.
                Problem thought : how to keep a potential difference and thus running the load when all batteries are topping up at 14.4 volts?
                • Jeepers now yous have got me wondering if there is enough energy stored in a generator coil, while on it's approach to tdc, that if released in a timely fashion, could neutralize the magnetic attraction that caused it. If so that looks like an imbalance of force that could play out favorably.
                  • Originally posted by Iamnuts View Post
                    This is a very real issue ; when also impulse charging the batteries on the negative side ; seems that it all needs to be balancaed with the LOAD used.
                    • Balance
                      You can always put a load on battery 3 to draw it down and maintain the potential difference.
                      If all 3 batteries are staying up, you should still have a potential difference. Not sure I understand the problem.
                      • Pinched.
                        I borrowed this from another thread.
                        The boundary must be clearly defined, so one can clearly say whether a given part of the world is in the system or in the surroundings. If matter is not able to pass across the boundary, then the system is said to be closed; otherwise, it is open. A closed system may still exchange energy with the surroundings unless the system is an isolated one, in which case neither matter nor energy can pass across the boundary.
                        John.
                        • Comment
                          • Link
                            Here ya go. Try this.
                            • Hi Dave,
                              I sent you a pm.
                              cheers,
                              Mario
                              • The new kilogram.
                                Look at this!!!!
                                There is a quantity that relates weight to electrical current, called Planck's constant - named after the German physicist Max Planck and denoted by the symbol h.
                                But h is an incredibly small number and to measure it, the research scientist Dr Bryan Kibble built a super-accurate set of scales. The Kibble balance, as it has become known, has an electromagnet that pulls down on one side of the scales and a weight - say, a kilogram - on the other.
                                The electrical current going through the electromagnet is increased until the two sides are perfectly balanced.
                                By measuring the current running through the electromagnet to incredible precision, the researchers are able to calculate h to an accuracy of 0.000001%.
                                This breakthrough has paved the way for Le Grand K to be deposed by "die kleine h".
                                I can't possibly see any scope for any design of generator to cheat nature
                                when the whole world (bar a certain few) agrees on something like this.
                                John.
